Recently bought an '05 6.0 and would appreciate an Oasis.
Vin # 1FTWW33P75ED01295
Thank You!!
Standard Claims List For Model Year 2005
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 9 * * * * * * * 11833
AWS Claim Key: 3348518 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05079 - * Name: BILL WOODS FORD Ph: 816-4544200 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:240947B
Cust Comments: RECALIBRATE PCM
Tech Comments: 11833 REPROGRAM PCM AS PER RECALL
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 21 7M01 150102 5C3T 18C869 AH A07 42 28573
AWS Claim Key: 6904145 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2006 Doc #:78367000
Tech Comments: REQUESTING DEALER'S P/A CODE 05079
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 21 7V01 180101 * 14290 * A37 33 28573
AWS Claim Key: 6759045 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05079 - * Name: BILL WOODS FORD Ph: 816-4544200 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2006 Doc #:256116A
Cust Comments: A37 C S SITTING STILL SPEEDO SHOWS 30MPH
Tech Comments: 28573 LOOSE G105 COMPLETE CHECKOUT, FOUND ABD HAD CODE U1900 FOR LOSS OF CAN NETWORK COMMUNICATION, RAN OASIS, PERFORMED SSM 18445, INSPECTED, CLEANED AND RESECURED G105 THAT WAS A LITTLE LOOSE CAUSING ABS TO STOP SENDING VSS SIGNAL TO PSM AND IC, ROAD TEST WITH SERVICE MANAGER AND MONITORD VSS PIDS AND ALSO MONITORED CLUSTER, CLUSTER IS WORKING PROPERLY AT THIS TIME.
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 21 7M01 150102 * 18805 * A16 42 28573
AWS Claim Key: 6759046 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 05079 - * Name: BILL WOODS FORD Ph: 816-4544200 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2006 Doc #:256116B
Cust Comments: A16 CD PLAYER TROUBLES INOP
Tech Comments: OSL BROADWAY RADIO REPAIR
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 22 * * * * * * * 29325
AWS Claim Key: 7107962 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2007 Doc #:285577D
Cust Comments: RECASLL 05B32
Tech Comments: PERFORM RECALL
1FTWW33P75ED01295 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 05-MAY-2005 153007 USA 24 3A06 070101 * 7A248 * P67 30 34000
AWS Claim Key: 7498965 Trx Code: E84 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:287908A
Cust Comments: CORRECT TRANSMISSION SHUDDERS WHEN SHIFTING
Tech Comments: 34000 481 ROAD TESTED RUN WDS 0766 2703 RU PRESS TEST D2 35 PSI RUN PEN POINT TEST OK REMOVED TRANSFE CASE & TRANSMISSON & DISSASSEMBLED FOUND FIRECT & OD CLUTCHS BURNT CONVERTER DEBRIS & ALL SYLS MADE EST REASSEMBLED FOR CORE FLUSHED COOLER REASSEMBLED R&R OTA COOLER REPLACED INLINE FILTER
Reactions: HillbillyDeluxe
Thank You!
