Standard Claims List For Model Year 2006
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 7 6Y05 000001 * MAINT * A99 82 7474
AWS Claim Key: 3494959 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2007 Doc #:22687601
Cust Comments: ESP 7.5K SERVICES
Tech Comments: 1 PERF 7.5K SERVICE.LOF.15 QTS.15W 40 OIL.ROTATED TIRES.8 LUG.
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 9 2I04 NANANA YC3Z 12B533 AA E29 07 10155
AWS Claim Key: 3943577 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:22972901
Cust Comments: CUST. STATES CHECK ENGINE LIGHT IS ON
Tech Comments: 1 EEC SELF TEST CMDDTC PO670,683 GLOW PLUG CIRCUITS. RAN PINPOINT TEST AF. FOUND DEFECTIVE GLOW PLUG MODULE. REPLACE MODDULE.
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 13 6C06 0105XX * 2531406 * T53 33 14890
AWS Claim Key: 4839847 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2007 Doc #:23605704
Cust Comments: CUST. STATES PASSENGER SIDE GRAB HANDLE PULLED OUT
Tech Comments: VERIFY CONCERN REINSTALL GRAB HANDLE REPLACE 1 SCREW
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 13 7F02 011601 YF1Z 17528 AB W05 42 14890
AWS Claim Key: 4863985 Trx Code: 0712D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2007 Doc #:23605702
Cust Comments: CUST. STATES WIPERS DO NOT CLEAR WINDSHIELD
Tech Comments: VERIFY CONCERN WIPERS DRIED UP INSTALL 2 NEW WIPER BLADES
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 13 6Y05 000001 * MAINT * A99 82 14890
AWS Claim Key: 4839848 Trx Code: 0712S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2007 Doc #:23605701
Cust Comments: LOF, TIRE ROTATION, BRAKE INSPECTION FUEL FILTER
Tech Comments: 15 QTS 15W 40 PERFORM LOF INSTALL NEW FUEL FILTERS ROTATE TIRES INSPECT BRAKES TIRES GREEN BRAKES GREEN
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 21 6Y05 000001 * MAINT * A99 82 22457
AWS Claim Key: 6452081 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2008 Doc #:24680901
Cust Comments: PERFORM 22500 MILE SERVICE
Tech Comments: NORMAL MAINTENANCE ENGINE OIL AND OIL FILTER CHANGED ; CHASSIS LUBED AS REQUIRE USED 15QTS OF 15W40
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 21 7F02 011601 YF1Z 17528 AB W05 42 22457
AWS Claim Key: 6452080 Trx Code: 0712D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2008 Doc #:24680903
Cust Comments: WIPERS DO NOT CLEAR WINDSHIELD
Tech Comments: INSTALL NEW WIPERS
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 21 7W04 190201 * 15K601 * L20 42 22457
AWS Claim Key: 6461766 Trx Code: E83 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2008 Doc #:24680905
Cust Comments: KEYLESS ENTRY REMOTE DOES NOT WORK UNLESS YOUR RIGHT NEXT TO VEH.
Tech Comments: INSTALL NEW BATTERY AND TESTED
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 27 7F02 NANANA XF1Z 17528 AA W05 42 28673
AWS Claim Key: 7590054 Trx Code: 0712D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2008 Doc #:00595903
Cust Comments: WIPER BLADES REPLACE WIPERS STREAK ON WINDSHIELD PLEASE REPLACE WIPER BLADES CUST. STATES WIPERS DO NOT CLEAR WINDSHIELD
Tech Comments: REPLACED WIPER INSERTS
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 27 6Y05 000001 * MAINT * A99 82 28673
AWS Claim Key: 7597172 Trx Code: 0712S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2008 Doc #:00595902
Cust Comments: MAINTENANCE 30,000 MILE SERVICE LOF, TIRE ROTATION, BRAKE INSPECTION CHECK AIR FILTER MINDER
Tech Comments: PERFORMED 30,000 MILE SERVICES
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 27 6N04 010802 5C3Z 16720 SA B63 07 28673
AWS Claim Key: 7590055 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2008 Doc #:00595904
Cust Comments: SEAT/TRIM/UPHOLSTERY CUST. STATES F350 EMBLEM DELAMINATING, SOP HERE??
Tech Comments: REPLACED RIGHT FRONT F350 EMBLEM
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 27 7H11 120305 7C3Z 19D850 A C02 42 28673
AWS Claim Key: 7590056 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2008 Doc #:00595905
Cust Comments: ENGINE REPAIR CUST. STATES TURBO BOOT LEAKING, HOSE CLAMP RUBBING ON A/C LINE
Tech Comments: INSPECTED AND FOUND TURBO BOOT RUBBING ON AC LINE. EVAC AND RECHARGE AC SYSTEM FOUND TUBE LEAKING REPLACED TUBE AND ORDER BOOT.
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 28 1G03 030507 3C2Z 8620 HB N12 01 30104
AWS Claim Key: 7784526 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08532 - * Name: ****'S MACKENZIE FORD Ph: 503-6931133 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2009 Doc #:00738202
Cust Comments: ENGINE REPAIR CUSTOMER STATES:WHILE DRIVING SERP.BELT CAME APARTCHECK AND ADVISE
Tech Comments: SERP BROKE AND DAMAGED FAN STATOR ASY REPLACE SERP BELT AND FAN STATOR ASY
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 39 2G05 031405 * RECALEM * D03 04 36948
AWS Claim Key: 8799284 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08547 - * Name: VANCOUVER FORD INC Ph: 360-6948501 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2009 Doc #:123727I
Cust Comments: REPROGRAM THE PCM FOR COLD START
Tech Comments: VERIFIED CUSTOMER CONCERN. PERFORM KOEO ON DEMAND SELF TEST, NO CODES. REFER TO OASIS FOUND TSB 09 24 3. CHECK FOR LATEST PROGRAMMING, VEHICLE DOES NOT HAVE LATEST PROGRAMMING. REPROGRAM FICM, PCM AND TCM. REASSEMBLE AND RETEST FOR OPERATION, ALL OK AT THIS TIME.
1FTWW31P26EC39860 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-DEC-2005 15-OCT-2006 174406 USA 39 1D01 03XXXX 5C3Z 6710 AA L65 D8 36948
AWS Claim Key: 8799283 Trx Code: E72 Labor Hrs: 16.5
Dlr Cd-Sub Cd: 08547 - * Name: VANCOUVER FORD INC Ph: 360-6948501 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2009 Doc #:123727G
Cust Comments: OIL LEAK UNDER ENG
Tech Comments: 4X4 AUTO TRANS, DUAL ALTENATOR 6.OL VERIFIED CUSTOMER CONCERN. PERFORM OIL LEAK DYE TEST, FOUND OIL LEAKING FROM CAM SENSOR O RINGS AND BEDPLATE SEAL. R&I ENGINE. RESEAL BEDPLATE. REPLACE REAR MAIN SEAL AND CAM SENSOR O RINGS. REFILL WITH 16QTS 15W 40. CLEAN CAC TUBE FITTINGS, REASSEMBLE AND RETEST FOR OPERATION, ALL OK AT THIS TIME.
