Standard Claims List For Model Year 2006
1FTSW21P06EB03042 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 25-AUG-2005 27-APR-2006 141774 USA 4 7S02 180102 * 14401 * E29 30 3889
AWS Claim Key: 1438678 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 20101 - * Name: RON ALPEN FORD, INC. Ph: 563-7854466 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2006 Doc #:03876001
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: VERIFY CONCERN CHECK FOR CODES FOUND P0299 CHECK OASIS FOUNDSSM 18898 FOUND CHAFE AT EP SENSOR REPOSITION CLAMP AND REPAIR WIRE ROAD TEST OK
1FTSW21P06EB03042 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 25-AUG-2005 27-APR-2006 141774 USA 9 2E03 030008 * 9E527 * D13 42 11353
AWS Claim Key: 2534563 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 20101 - * Name: RON ALPEN FORD, INC. Ph: 563-7854466 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2006 Doc #:03989501
Cust Comments: MISSES IN MORNING WHEN COLD
Tech Comments: VERIFY CONCERN MISSES IN THE MORNINGS CHECK OASIS FOUND TSB 06 22 03 REFLASH PCM AND RECHE CK OK
1FTSW21P06EB03042 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 25-AUG-2005 27-APR-2006 141774 USA 15 2H01 030407 5C3Z 6K682 A E29 42 20249
AWS Claim Key: 4171016 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 20101 - * Name: RON ALPEN FORD, INC. Ph: 563-7854466 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2007 Doc #:04136901
Tech Comments: VERIFY CONCERN CHECK FOR CODES FOUND P0299 PERFORMTSB 06 23 02 REPLACE TURBO CHARGER AND E XCHANE VGT SOLENOID
1FTSW21P06EB03042 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 25-AUG-2005 27-APR-2006 141774 USA 44 2E03 030402 4C3Z 9E527 BRM D02 01 76638
AWS Claim Key: 8743426 Trx Code: S07 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 01586 - * Name: BURNETT-THIEL FORD INC Ph: 563-6526161 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2009 Doc #:6935801
Cust Comments: ENGINE STALLED ,TOWED IN
Tech Comments: PERFORM DIAGNOSTIC SHEET,ICP TO LOW,PERFORM PINPOINT TEST AO,PERFORM HIGH PRESSURE OIL PUMP TEST,DEAD HEAD EACH BANK AND HIGH PRESSURE OIL PUMP, RIGHT BANK FAILS,REMOVE BOTH VALVE COVERS TO CHECK,FOUND #5 INJECTOR SEAL LEAKING, TOP OF INJECTOR BLEW APART,REPLACE #5 INJECTOR,REASSEMBELED, RETEST, CLEAR CODES,TEST DRIVE,O.K. NOW PINPOINT TESTS,A01 Y
Reactions: newman1281
