starting to have trouble with my truck I would very much appreciate an OASIS report for it VIN is 1FTSW31P16EC28248 . Thanks for you time.
Standard Claims List For Model Year 2006
1FTSW31P16EC28248 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-DEC-2005 16-FEB-2006 171171 USA 0 * * * * * * * 3
AWS Claim Key: 378013 Trx Code: TDE Labor Hrs: 5.8
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:21-DEC-2005 Doc #:31411201
Cust Comments: LEFT QUARTER PANEL SCRATCHED UPON ARRIVAL.
Tech Comments: REPAIRED LT. BEDSIDE DENT 9927841 B TIME 2.0, NECESSARY TO REMOVE AND INSTALL LT. TAILLAMP 13405 B TIME .2, AND TOP LT. BEDSIDE RAIL MLDG. 99291A40 B TIME .4, SANDED, PRIMED, AND REFINISHED LT. BEDSIDE 7027840 P33 2.3, P101 .5, ALSO NECESSARY TO REPLACE 4X4 DECAL 9925622 B TIME .2 .
1FTSW31P16EC28248 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-DEC-2005 16-FEB-2006 171171 USA 17 2H01 030407 5C3Z 6K682 CARM D42 42 72657
AWS Claim Key: 4171208 Trx Code: S07 Labor Hrs: 9.4
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2007 Doc #:49455301
Cust Comments: REPLACE TURBOCHARGER ASSEMBLY C S THE TRUCK HAS A LACK OF POWER,CAT TUBE IS LEAKING,BLACK SMOKE COMING FROM THE TAIL PIPE AND A INTERMITTENT CRANK
Tech Comments: PERF DI DIAG,VEHICLE LACKS POWER AND SMOKES.DTC P0299, P0401,P0404 PRESENT.PERF. VGT PERF DIAG,TURBO STICKING EGRVP AT .88,EGR VALVE FAILED POSTION TEST.REC EGR VALVE TURBO,UPPER CAC TUBE INSTALLED NEW CAC TUBE BOOT,EGR VALVE,TURBO AND REFLASHED PCM,TCM,FICM TO LATEST LEVEL.RETESTED,VEHICLE OP NORMAL.
1FTSW31P16EC28248 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-DEC-2005 16-FEB-2006 171171 USA 17 2E01 03XXXX 4C3Z 9B246 A D03 42 72657
AWS Claim Key: 4132067 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2007 Doc #:49455304
Cust Comments: HARD START NO START
Tech Comments: PERF DI DIAG,VEHICLE HARD TO START ITT.MONITOR RECORD ICP,ICP DROPS TO 170 PSI.AIR TESTED SYSTEM,OIL LEAK AT PUMP REC STC KIT PER TSB 06 17 06.AND IPR REMOVED HIGH PRESSURE OIL PUMP AND INSTALLED STC KIT AND IPR.PER TSB 06 17 06.REASSEMBLED VEHICLE ANDRETESTED VEHICLE OP NORMAL.E
1FTSW31P16EC28248 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-DEC-2005 16-FEB-2006 171171 USA 26 1H03 030804 4C3Z 9P456 AF D50 42 99323
AWS Claim Key: 5849007 Trx Code: S07 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:12-MAR-2008 Doc #:65351601
Cust Comments: DIAGNOSIS OF DIESEL ENGINE CONCERNS, INCLUDING TESTING AND COMPONTANT DISASSEMBLY C S THE TRUCK IS BLOWING BLACK CHECK AND ADVISE
Tech Comments: PERFORMED DIESEL PERFOMANCE DIAG. FILLED OUT DIESEL DIAG SHEET.MOINTOR AND RECORD.FOUND EGR VAVLE STICKING AND OIL COOLER LEAKING.REC NEW EGR VAVLE AND OIL COOLER ALSO EGR COOLER REPLACED EGR VALVE, COOLER AND OIL COOLER. POST ROAD TEST VERIFY.ALL OPERATION NORMAL AT THIS TIME RETEST OK REFLASHED PER TSB 07 05 04
1FTSW31P16EC28248 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-DEC-2005 16-FEB-2006 171171 USA 26 2E03 0304XX 5C3Z 9C968 CA D02 42 99463
AWS Claim Key: 5849008 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 20337 - * Name: HOLMES TUTTLE FORD, LINCOLN-MERCURY Ph: 520-2923600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2008 Doc #:65885301
Cust Comments: C S HARD START AFTER SITTING
Tech Comments: 9C968 CC D8 PERFORMED HARD START DIAG SHEET.PERFORMED PRESSURE TEST AND FOUND IPR LEAKING AND DENTED.REPLACED IPR SENSOR AND RETEST.FOUND BANK 2 OIL RAIL PLUG LEAKING. REPLACED OIL PLUG AND RETESTED. ALL OPERATION NORMAL AT THIS TIME
