Vin# 1FTWW31P66EB56044
Standard Claims List For Model Year 2006
1FTWW31P66EB56044 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-OCT-2005 21-AUG-2006 147015 USA 47 1B03 030204 3C3Z 6A642 CA L87 55 60741
AWS Claim Key: 9204931 Trx Code: E72 Labor Hrs: 26
Dlr Cd-Sub Cd: 02019 - * Name: LEBANON FORD LINCOLN MERCURY, INC. Ph: 513-7210837 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2010 Doc #:01631101
Cust Comments: C/S TRUCK IS LOSING COOLANT CUSTOMER HAS TO ADD COOLANT DAILY
Tech Comments: VERIFIED CONCERN PERFORMED TSB 09 08 03 DEGAS BOTTLE RELEASES PRESSURE AT 16PSI NO CRACKS FOUND IN DEGAS BOTTLE TEST WITH RADKITPLUS SYSTEM WAS NOT ABLE TO MAINTAIN VACUUM PERFORMED TEST DRIVE WHILE MONITORING EOT AND ECT MAX TEMP DIFFERENTIAL WAS 22 DEGREES F REMOVED AND REPLACED OIL COOLER SUBMERGED COOLER IN DUNK TANK FAILED COOLER COULD NOT MAINTAIN PRESSURE REPLACED EGR COOLER T/DROVE MONITOR
1FTWW31P66EB56044 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-OCT-2005 21-AUG-2006 147015 USA 47 1D01 03XXXX 3C3Z 6710 CA L65 D8 60741
AWS Claim Key: 9199704 Trx Code: E72 Labor Hrs: 11.4
Dlr Cd-Sub Cd: 02019 - * Name: LEBANON FORD LINCOLN MERCURY, INC. Ph: 513-7210837 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2010 Doc #:01631102
Cust Comments: C/S OIL IS LEAKING ON DRIVEWAY
Tech Comments: VERIFIED CONCERN PERFORMED OIL LEAK DIAG ADD DYE TO SYSTEM PINPOINT TO FRONT CRANK SEAL REAR MAIN SEAL REAR COVER AT T JOINTS LEAKING AND UPPER OIL PAN GASKET LEAKING OIL REPLACED FAILED GASKETS AND SEALS OIL CHANGE WAS ON LINE 1 RETEST AFTER REPAIRS OK
Reactions: Ohio Eddie
DEALER: Lebanon Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 016311 ODOMETER: 060741M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6051EB GASKET CYL HEAD 002 090803A 55 PLUGGED/RESTRICTED
VC 9 001 090803B
VC 7B 003 090803D
3C3Z 6731AA ELEMENT ASY OIL FILT 001 090803F
XO 15W40QSD 015 090803G
3C3Z 6A642CA COOLER CRANKCASE OI 001
4C3Z 9P456AF COOLER - EGR 001
3C3Z 6C683AB FLTER-ENG OIL 001
6C3Z 5A231AA CLAMP-MUFFLER 001
VERIFIED CONCERN PERFORMED TSB 09-08-03 DEGAS BOTTLE RELEASES PRESSURE AT 16 PSI NO CRACKS FOUND IN DEGAS BOTTLE TEST WITH RADKITPLUS SYSTEM WAS NOT ABLE TO MAINTAIN VACUUM PERFORMED TEST DRIVE WHILE MONITORING EOT AND ECT MAX TE MP DIFFERENTIAL WAS 22 DEGREES F REMOVED AND REPLACED OIL COOLER SUBMERGED C OOLER IN DUNK TANK FAILED COOLER COULD NOT MAINTAIN PRESSURE REPLACED EGR CO
they billed out head gaskets so apparently they did them too.
