Standard Claims List For Model Year 2003
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 7 1F03 030304 * 8260 * L87 07 14682
AWS Claim Key: 5348117 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:02-APR-2004 Doc #:21775901
Cust Comments: REPAIR LOWER RAD HOSE IS RUBBING THUR
Tech Comments: PRESS TEST COOLING SYST. BOTTOM RAD HOSE RUBBING ON STRG BOX. R&R AIR FILTER& INLET AIR TUBES. R&R TURBO AIR COOLER TUBE. WAS ABLE TO ACCESS UPPER CLAMP ON BOTTOM RAD HOSE. RPLC HOSE AND RD TEST. OK.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 8 2G05 031405 * RECAL * D42 07 15389
AWS Claim Key: 5963690 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:05-MAY-2004 Doc #:21881601
Cust Comments: REPAIR THE ENGINE FOR VERY SLUGGISH ON ACCEL HOT
Tech Comments: VERIFIED LACK OF POWER. EEC TEST WDS NO CODES. CHECK OASIS. SSM 16839.PID MON/RECORDER DATA LOGGER. NO PID CONCERNS. CHECK CALIBRATION LEVEL. REFLASH TO 3U7A 12A650 FTC. REROAD TEST OK.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 12 5G04 040100 1C3Z 5K483 BA N50 42 25558
AWS Claim Key: 7428453 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:21-AUG-2004 Doc #:22250102
Cust Comments: CHECK FOR KLUNK IN FRT END
Tech Comments: RPLC SWAY BAR LINK.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 15 5G03 040103 4C3Z 3050 BA N58 42 33661
AWS Claim Key: 8657797 Trx Code: E84 Labor Hrs: 2.6
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:26-NOV-2004 Doc #:22553702
Cust Comments: DIAG FOR CLUNK NOISE IN FR END. WORSE ON TIGHT TURNS.
Tech Comments: RD TEST FOR CLUNK ON TURNS CAN HEAR OVER EVERY BUMP. RAISE ON HOIST. CHECK FR END. FOUND ALL BALL JNTS SLOPPY. RPLC ALL 4 BALL JOINTS.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 15 2H01 030008 3C3Z 6K854 DA E41 07 33661
AWS Claim Key: 8657796 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:26-NOV-2004 Doc #:22553701
Cust Comments: DIAG FOR VERY STRONG EXH SMELL IN CAB.
Tech Comments: CHECK FOR EXH SMELL IN CAB. RUN TRUCK CAN HEAR EXH LKG FORUND Y PIPE OFF TURBO LKG. R&R TURBO. RPLC Y PIPE, WILL NOT SEAL OFF TURBO.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 15 2H01 030008 3C3Z 6K854 DA E42 D8 33662
AWS Claim Key: 8657798 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:29-NOV-2004 Doc #:22559001
Cust Comments: DIAG EXH WHISTLE NOISE, JUST RPLCD Y PIPE.
Tech Comments: R&R TURBO, INSTALL NEW INLET PIPE. PARTS WARR TO 225537, 1KM, 11/26/04.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 15 5G04 040105 2C3Z 5484 AA N50 41 33662
AWS Claim Key: 8657799 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:29-NOV-2004 Doc #:22559002
Cust Comments: RPR FOR FR END CLUNK OVER BUMPS.
Tech Comments: VERIFIED NOISE. RPLC BOTH FR SWAY BAR RUBBERS. RPLC RT SWAY BAR LINK.LUBE FRONT SPRING INSULATORS.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 15 7B02 140201 * 10346 * D02 42 33662
AWS Claim Key: 8634335 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:29-NOV-2004 Doc #:22562401
Cust Comments: RPR FOR NO START & LOSS OF ELECTRICAL COMPONENTS
Tech Comments: CHARGE BATTERY. AVR TEST. FAILED TEST, NOT CHARGING. RPLC ATERNATOR. RETEST. OK.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 16 5T03 070603 4C3Z 7210 BA P82 42 35408
AWS Claim Key: 9002507 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:28-DEC-2004 Doc #:22634001
Cust Comments: RPR FOR VEHICLE SLIPS OUT OF 4X4 LOW GOING DOWNHILL
Tech Comments: RD TEST AND CONFIRM CONCERN. R&R TRANSFER CASE SKID PLATE FOR INSP. TRY TO ADJ T/CASE SHIFTER. WORN OUT. RPLC SHIFTER ASSY.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 28 2E06 030008 3C3Z 9E527 AE D03 42 62912
AWS Claim Key: 13014251 Trx Code: E72 Labor Hrs: 7.5
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-JAN-2006 Doc #:23774201
Cust Comments: REPAIR HARD START WHEN COLD
Tech Comments: COLD START TEST WDS TEST LOTS OF CODES DO ENGINE PERFORMANCE DIAGNOSTIC SHEET REPLACE EGR VALVE AND VACUUM INTAKE REPROGRAM PCM, FICM, AND TCM TO LATEST UPDATES RETEST FAILS 6 INJECTORS REPLACE INJECTORS# 1, 2, 3, 5, 6 AND 8 RETEST OKAY
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 31 * * * * * * * 69975
AWS Claim Key: 13558630 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-MAR-2006 Doc #:24007902
Cust Comments: PERFORM RECALL 06E17 ENGINE CONTROL MODULE RECALIBRATION
Tech Comments: RECALIBRATE MODULE AS REQUIRED.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 31 2E01 030008 3C3Z 9F838 EA L65 D8 69975
AWS Claim Key: 13579887 Trx Code: E72 Labor Hrs: 3.4
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-MAR-2006 Doc #:24007901
Cust Comments: REPAIR FOR OIL LEAK SEEMS TO BE COMING FROM THE REAR OF THE ENGINE
Tech Comments: CHECK FOR OIL LEAK. CLEAN. INSTALL DYE IN OIL. TEST DRIVE. RETEST WITH BLACK L IGHT. NOT MUCH OF A LEAK. CUSTOM TO DRIVE. RECHECK AT NEXT SERVICE. PREV RO 237742 IS FOR A DRIVEABILITY CONCERN. THIS CLAIM IS TO REPAIR AND OIL LEAK.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 31 2G02 031201 * 12B579 * D36 42 69975
AWS Claim Key: 13608227 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-MAR-2006 Doc #:24007904
Cust Comments: CHECK FOR LACKS POWER AND ALMOST QUITS
Tech Comments: WDS TESTS OK. FUEL PRESS OK AT 55 PSI. DO ALL TESTS AS PER ENG PERF DIAG SHEET. DATA LOGGER PID DATA MONITOR ON RD TEST. FOUND WIRING AT MASS AIR FLOW SENSOR CONNECTOR BROKEN. NOT ALWAYS MAKING A CONNECTION. R&R AND RPLC HRNSS CONN AND WIRING. REASSEMBLE. TEST DRIVE. RUNSGREAT. RESET KAM.
AWS Claim Key: 13558631 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-MAR-2006 Doc #:24007903
Cust Comments: PERFORM CUSTOMER ASSURANCE ROAD TEST
Tech Comments: CUSTOMER ASSURANCE ROAD TEST.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 35 2E06 030008 3C3Z 9E527 AE D13 42 74307
AWS Claim Key: 14203034 Trx Code: E72 Labor Hrs: 6.8
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:25-JUL-2006 Doc #:24354401
Cust Comments: REPAIR FOR VEHICLE RUNS ROUGH SEE HISTORY
Tech Comments: CHECK FOR RUNS ROUGH, DO ALL TESTS AS PER DIAG SHEET. WDS TESTS, NO CODES, FU EL PRESSURE OK AT 54 PSI. PID DATTA MONITOR ON TEST DRIVE, #7&8 INJECTOR SHOW S MISFIRE, RELATIVE COMPRESSION SHOWS OK. PASSES BUZZ TESTS FOR INJECTORS. R EQUIRES #7&8 INJECTOR. RE & RE RIGHT SIDE VALVE COVER, INSTALL NEW INJECTOR # 7 CYLINDER, REASSEMBLE. RE & RE LEFT SIDE VALVE COVER, INSTALL NEW INJECTOR
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 35 1F05 030306 * 8A616 * E23 42 74307
AWS Claim Key: 14203035 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: B7009 - * Name: DEARBORN MOTORS LTD Ph: 250-3727101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:25-JUL-2006 Doc #:24354402
Cust Comments: REPAIR FOR VEHICLE IS RUNNING HOT.
Tech Comments: CHECK FOR OVERHEATING, P0480 COOLING FAN WIRING ALL BROKEN. RE & RE RAD, FA N SHROUD AND FAN ASSEMBLY, INSTALL NEW ELECTRIC VISCUS FAN CLUTCH ASSEMBLY. R EASSEMBLE, CLEAR CODE, TEST DRIVE, WORKS GREAT.
1FTSW31P53ED41096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-MAY-2003 25-SEP-2003 4B7009 CAN 54 2I04 030703 * 12B533 * D03 42 86577
AWS Claim Key: 15814050 Trx Code: E72 Labor Hrs: 4.3
Dlr Cd-Sub Cd: B7160 - * Name: JACOBSON FORD SALES LTD. Ph: 250-8322101 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:08-FEB-2008 Doc #:11435801
Cust Comments: ADVISE FOR HARD TO START HOT OR COLD
Tech Comments: VERIFY CONCERN PERFORM DIESEL DIAGNOSTICS AS NECESSARY REPLACE FAULTY GLOW P LUG CONTROLLER RUN UNTIL WARM DO SEVERAL STARTS AND FOUND ICP/IPR FAULTY RE PLACE IPR SOLONOID AND OIL SOAKED ICP HARNESS RETEST WITH DATA LOGGER NORMAL READINGS NOW
Reactions: sooperdooty65
