Standard Claims List For Model Year 2006
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 3 6Y05 000001 * MAINT * A99 82 5112
AWS Claim Key: 435424 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:600827A
Cust Comments: PERFORM MAINTENANCE PER FORD MAINTENANCE GUIDE, USE 5K INTERVAL SERVICE SCHEDULE UNLESS OTHERWISE SPECIFIED.
Tech Comments: PERFORMED 5K SERVICE;LUBE,OIL,FILTER SERVICE TIRE ROTATION & ADJUSTED AIR PSI 65X75,MP INSPE CTION ALL OK.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 4 5K04 040402 * ALBAL * N24 D9 5853
AWS Claim Key: 542528 Trx Code: 1 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:602516A
Cust Comments: CUSTOMER STATES VIBRATION AT 60 AND PULLS RIGHT SINCE ROTATE LAST VISIT
Tech Comments: TEST DROVE VEHICLE VARIFIED CONCERN CHECKED OASIS FOR MATCH FOUND 05 26 24 CHECKED ROAD FORCE ON ALL FOUR TIRES FOUND TWO TIRES THAT HAD EXESSIVE ROAD FORCE RE INDEXED TIRE AS PER TSB AND BROUGHT THEM FROM 73LBS AND 86LBS TO 24LBS AND 29LBS. TEST DROVE AND VIBRATION IS GONE AS WELL AS THE PULL.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 7 6Y05 000001 * MAINT * A99 82 10309
AWS Claim Key: 1027669 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:610708A
Tech Comments: PERFORMED 10K SERVICE;LUBE,OIL,FILTER SERVICE TIRE ROTATION & ADJUSTED AIR PSI 65X75,MP INSPE CTION ALL OK,TOP OFF FLUIDS.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 11 6Y05 000001 * MAINT * A99 82 15104
AWS Claim Key: 1846270 Trx Code: 0712S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2006 Doc #:622645A
Cust Comments: PERFORM MAINTENANCE PER FORD MAINTENANCE GUIDE, USE 5K INTERVAL SERVICE SCHEDULE UNLESS OTHERWISE SPECIFIED. *** 15K ***
Tech Comments: PEROFRMED 15K DIESEL LUBE OIL AND FITER SERVICE TIRE ROTATION INSPECTED BRAKES AND REPLACED FUEL FILTERS
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 15 6Y05 000001 * MAINT * A99 82 19983
AWS Claim Key: 2884840 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2007 Doc #:634174A
Tech Comments: PERFORMED 20K SERVICE;LUBE,OIL,FILTER SERVICE. TIRE ROTATION & ADJUSTED AIR PSI,TOP OFF FLUIDS LEVELS,MP INSPECTION;TRANSMISSION FLUID LEVEL & COLOR OK,TIRE,BRAKES 9MM ALL,FILTER,LIGHTS,SIG NALS,BOTH BATTERY, ALL OK.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 20 6Y05 000001 * MAINT * A99 82 25187
AWS Claim Key: 3832364 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2007 Doc #:644677A
Tech Comments: PERFORMED LOF CHECK TIRE PRESSURE TOP OFF ALL THE FLUIDS PERFORMED TIRE ROTATION F BRAKE OK R BRAKE OK
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 23 7F02 011601 YF1Z 17528 AB W05 82 29837
AWS Claim Key: 4530933 Trx Code: 0712D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2007 Doc #:652814B
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 23 6Y05 000001 * MAINT * A99 82 29837
AWS Claim Key: 4509525 Trx Code: 0712S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2007 Doc #:652814A
Cust Comments: PERFORM MAINTENANCE PER FORD MAINTENANCE GUIDE, USE 5K INTERVAL SERVICE SCHEDULE UNLESS OTHERWISE SPECIFIED. 30 K SERVICE PLESE CHECK TIRE BALANCE ON FRONT TIRES
Tech Comments: PERFORMED MAINTENANCE PER FORD CHANGED OIL AND FILTER CHANGED BOTH FUEL FILTERS CHANGED TRANNY FLUID AND TRANNY COOLER FILTER ROTATED TIRES AND BALANCED FRONT TIRES REPLACED WIPER BLADES REPLACED AIR FILTER TOP OFF ALL UNDER HOOD FLUIDS PERFORMED MULTI POINT INSPECTION
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 26 6Y05 000001 * MAINT * A99 82 34781
AWS Claim Key: 5723471 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2008 Doc #:661341A
Tech Comments: PERFORMED 35K SERVICE CHANGED OIL AND OIL FILTER,LUBE,CHECKED TIRES AIR PRESSURES,ROTATED TIRES,CHECKED BRAKES SYSTEM OK,CHECKED ALL FLUIDS AND TOPPED OFF ALL FLUIDS,CHECKED TIRES WILL NEED ALL 4 TIRES,CHECKED BATTERIES OK, CHECKED LIGHT OK.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 26 1D05 030008 6C3Z 9448 A E41 42 34781
AWS Claim Key: 5723472 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2008 Doc #:661341C
Cust Comments: CUSTOMER STATES EXHAUST LEAK FROM ENGINE AREA
Tech Comments: RUN OASIS.ROAD TEST.INSPECTION.DIAG.EXHAUST LEAK BETWEEN HEADS AND EXHAUST MANIFOLDS.HAS NO GASKETS.M TIME TO INSTALL EXHAUST GASKETS ON BOTH SIDES.REROAD TEST.REINSPECTION.OK NOW. .9 M TIME TO INSTALL EXHAUST GASKETS ON BOTH SIDES.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 26 1C03 031001 5C3Z 6079 D L65 D8 34781
AWS Claim Key: 5732833 Trx Code: E84 Labor Hrs: 17.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2008 Doc #:661341B
Cust Comments: CUSTOMER STATES CHRIPPING TYPE NOISE FROM ENGINE AREA UNDER LOAD SEEMS TO HAPPENS PULLING GRADES OR GETTING ON FREEWAY NOISE SEEMS TO BE FROM ENGINE AREA ADVISE
Tech Comments: INSTALL BELT RUN OASIS.ROAD TEST.PREFORM TEST PER DIAG SHEET HAS NO CODES.ROAD TEST WITH CUSTMER.OIL TEMP IS 31 DEGR HOTER THAN COOLANT TEMP.COOLANT LEVEL WAS NORMAL BEFORE ROAD TEST.COOLANT COMING OUT OF OVER FLOW TANK AND MAKING NOISE.HAD CALLED HOT LINE ON A TRUCK MAKING SAME NOISE.HAS BLOW HEAD GASKETS BOTH SIDES.OIL COOLER CLOGED UP. PRESSURE TEST COOLING SYS.INSPECTION OF EGR
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 26 6Y20 000000 * TAP5 * A99 82 34781
AWS Claim Key: 5732834 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2008 Doc #:661341D
Cust Comments: RENTAL CAR FOR CUSTOMER SATISFACTION
Tech Comments: LOANER FORD CUST SAT
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 30 6Y05 000001 * MAINT * A99 82 39874
AWS Claim Key: 6117957 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2008 Doc #:670822A
Tech Comments: 39874 PERFORMED 5K SERVICE PER FORD MAINTENANCE GUIDE.CHANGED ENGINE OIL AND FILTER. ROTATED TIRES AND SET TIRE PRESSURES.TOPPED OFF ALL UNDERHOOD FLUIDS.PERFORMED MULTI POINT INSPECTION.
1FTWW31P66EB67903 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2005 19-NOV-2005 172206 USA 32 2G02 030707 8C3Z 12K073 A L65 D8 41501
AWS Claim Key: 6432168 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 08245 - * Name: FUTURE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2008 Doc #:158057A
Cust Comments: CUSTOMER STATES ENGINE IS LEAKING OIL AT TURBO AREA, REAR SIDE OF ENGINE, OIL PAN
Tech Comments: 41507 42K073 ADD OIL DYE TRACE OIL LEAKAGE TO CAM SENSOR REPLACE CAM SENSOR AND RE TEST OK, ROAD TEST OK. 6007D 0.5 3674A 1.9 12650D60 0.5
Reactions: Eric.Larson
