really wanna buy this truck!! just need to know its background info. Thanks ahead of time!!
VIN#1ftsw21p86ed33041 06 sd harley edition
Standard Claims List For Model Year 2006
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 4 7D01 170101 6C3Z 13008 CB L29 D8 4781
AWS Claim Key: 1776572 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:02550551
Cust Comments: C S HEADLIGHTS GET FOGGED UP WHEN IT RAINS. C S THERE IS A CLICK CLICK NOISE COMING FROM THE FRONT PASSENGER FOOT VENT
Tech Comments: WATER INTRUSION REPLACE BOTH HEADLAMP ASSEMBLIES
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 4 6C06 010502 5C3Z 2531458 AAB N17 07 4800
AWS Claim Key: 1980493 Trx Code: 2 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2006 Doc #:02902251
Cust Comments: SPO PART IS IN DAMAGED AND POOR FITTING COVER FOR BAR.
Tech Comments: COVER FITS POORLY REPLACE COVER ON A PILLAR
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 16 6N07 010801 5C3Z 8213 AA B66 33 20097
AWS Claim Key: 4418555 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2007 Doc #:829501B
Cust Comments: B66 CUSTOMER STATES FORD EMBLEM ON GRILL PEELING BUBBLING, ALL TIMES.
Tech Comments: 20097 W TECH 1945 VERIFIED CONCERN REMOVED GRILL TO REPLACE FORD EMBLEM AUTH PAAHU
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 16 6N04 011803 5C3Z 9942528 AAA B66 33 20097
AWS Claim Key: 4418556 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2007 Doc #:829501C
Cust Comments: B66 CUSTOMER STATES DRIVER SIDE POWER STROKE STICKER COMING LOOSE, ALL TIMES.
Tech Comments: 20097 W TECH 1945 REPLACED DOOR STICKER ON L F DOOR AUTH PAANU
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 16 7N02 011105 6C3Z 7823394 AA G07 42 20097
AWS Claim Key: 4418554 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2007 Doc #:829501A
Cust Comments: G07 CUSTOMER STATES BACK REAR SLIDER WINDOW WORKS SLOW, SOMETIMES GETS STUCK.
Tech Comments: 20097 W 1901 VERIFIED CONCERN.R.I.REAR POWER SLIDER BACKGLASS TO REPLACE MOTOR AND CABLE ASSY. 20097.
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 17 5I01 110204 3C3Z 3A674 AARM H22 42 21964
AWS Claim Key: 4729728 Trx Code: E84 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:835860A
Cust Comments: H22 CUSTOMER STATES POWER STEERING INOP, WILL NOT TURN, ALL TIMES.
Tech Comments: 21964 W 5.5 HR. VERIFY CONCERN. NO POWER STEERING. PERFORM POWE R STEERING PRESSURE FLOW TST OP. 3674D 0.7 HR. FOUND HYDROBOOS LEAKING. REPLACED HYDROBOST ASSEMBLY OP. 2005AA 1.0 HR. FOUND RUBBER COMING APART FROM POWER STEERING LINES AND CONTAMINATE D THE SYSTEM. REPLACED POWER STEERING PUMP OP. 3674A 1.9 HR. REPLACED LINE FROM PUMP TO HYDROBOOST OP. 3674A5 0.3 HR.
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 17 7N02 011105 6C3Z 7823394 AA G07 42 21964
AWS Claim Key: 4688194 Trx Code: E89 Labor Hrs: 1
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:835860C
Cust Comments: G07 CUSTOMER STATES BACK REAR SLIDER WINDOW WORKS SLOW, GETS STUCK WHEN TRYING TO CLOSE AND CUSTOMER HAS TO MANUALLY HELP IT CLOSE, ALL TIMES. ADVISE...SEE RO#829501,8 22 07,20100
Tech Comments: 21964 W 1901 SERVICE PART VERIFIED CONCERN.R.I.POWER SLIDER ASSY TO REPLACE MOTOR AND CABLE ASSY. UNDER SERVICE PART POLICY. 21964.
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 17 6N07 010801 6C3Z 8200 DC B66 33 21964
AWS Claim Key: 4729729 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:835860B
Cust Comments: B66 CUSTOMER STAETS TOP OF FRONT GRILL WARPING, ALL TIMES.
Tech Comments: 21964 W 1901 PAAQN VERIFIED CONCERN.REPLACE GRILL ASSY DUE TO DISTORTED. ACES CODE PAAQN. 21964.
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 27 5B03 050300 8C3Z 4L616 B L88 D8 33534
AWS Claim Key: 6911683 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:869691B
Cust Comments: CUST STATES FT DIFF LEAKS ALL TIMES
Tech Comments: 33539 42 9272 VERIFED CONCERN FOUND FRONT PINION SEAL LEAKING. REMOVE FRONT DRIVE SHAFT AND YOKE. INSALL NEW SEAL AND TOPOFF FLUID LEVEL. REINSTALL DRIVE SHAFT. ROAD TEST OK AT THIS TIME.
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 27 2E01 030408 4C3Z 9B246 C D42 42 33534
AWS Claim Key: 6911682 Trx Code: E84 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:869691A
Cust Comments: CUST STATES VEH CRANK NO START ALL TIMES
Tech Comments: 33539 42 9272 TRY TO START VECHILE VERIFED CONCERN. CRANK NO START. PERFORMED PERFORMANCE DIAG SHEET. KOEO TEST FOUND P2291 ICP TOO LOW. CHECK OASIS FOUND TSB 08 9 9. PERFORMED TSB 08 9 9. PERFORMED IDS TEST MONITOR ICP, ICPDES, IPR, RPM, REFV, AND SYNC. FOUND ICP WHILE CRANKING GET TO 235 PSI. REMOVE TURBO TO GET TO AIR TEST PORT AT REAR OF ENGINE. AIR TEST FOUND BAD LEAKING
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 31 7A01 140101 BXT 65 750 D02 28 34999
AWS Claim Key: 7474303 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-NOV-2008 Doc #:877192A
Cust Comments: CUST STATES NO CRANK AT TIMES AND BATT LIGHT COMES ON
Tech Comments: 34999 BATTERIES WARR. 9804 PERFORMED BATTERY TEST. FOUND BOTH BATTERIES FAILED TEST. REPLACED BATTERIES. OK AT THIS TIME. DRIVERS SIDE DTCS 15OJT OK3SO 999 ACES XE8EN. PASSENGER SIDE DTCS 1OSJT 1JBSO O1K. ACES XE1EN
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 31 7H10 120303 F6RZ 19E561 AA C20 42 34999
AWS Claim Key: 7467005 Trx Code: E83 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04820 - * Name: MAROONE FORD OF MARGATE Ph: 954-9727200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-NOV-2008 Doc #:877192B
Cust Comments: CUST STATES AC BLOWS WARM ALL TIMES
Tech Comments: 34999 SWITCH WARR. 9804 PERFORMED A C DIAG. FOUND SYSTEM LOW ON FREON. PERFORMED LEAK DYE TEST. FOUND SYSTEM LEAKING FROM LOW SIDE CYCLING SWITCH. REPLACED SWITCH. EVACUATED AND RECHARGED SYSTEM. OK AT THIS TIME
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 47 1B02 030401 3C3Z 9C065 AA E65 42 50321
AWS Claim Key: 9056463 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 04908 - * Name: SAWGRASS FORD Ph: 954-8519000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2010 Doc #:825201B
Cust Comments: CUST STATES VEH LEAKS FUEL ALL TIMES
Tech Comments: FUEL LEAKING FROM PRESSURE REGULATOR ON SECONDARY HOUSING REPLACED O RING AND CLEANED NO MORE FUEL LEAKING AT THIS TIME
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 47 1D05 030008 3C3Z 6020 CA L65 42 50321
AWS Claim Key: 9056462 Trx Code: E72 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 04908 - * Name: SAWGRASS FORD Ph: 954-8519000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2010 Doc #:825201A
Cust Comments: CUST STATES VEH LEAKS OIL ALL TIMES
Tech Comments: INSPECTED VEHICLE LARGE OIL LEAKING COMING FROM BEHIND POWER STEERING PUMP BETWEEN FRONT COVER AND BLOCK REMOVED AND REPLACED GASKET ON FRONT COVER CLEANED THOROUGHLY AND VERIFIED NO MORE OIL LEAKING AT THIS TIME
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 50 1B03 030204 3C3Z 6A642 CA L87 55 54991
AWS Claim Key: 9215954 Trx Code: E72 Labor Hrs: 9.5
Dlr Cd-Sub Cd: 06169 - * Name: SERVICE MOTORS, INC. Ph: 920-9212120 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2010 Doc #:26918901
Cust Comments: CHECK FOR VEHICLE IS USING COOLANT
Tech Comments: PRESSURE CHECKED THE SYSTEM AND FOUND EGR COOLER AND OIL COOLER BAD, DISASSEMBLED AND REPLACED BOTH COOLERS AND INTAKE PLUGGED BAD, SENT INTAKE OUT TO BE CLEANED, REASSEMBL AND FLUSHED OUT COOLING SYSTEM PER TSB
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 50 1H03 030008 5C3Z 9F452 AA D42 42 54991
AWS Claim Key: 9208132 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 06169 - * Name: SERVICE MOTORS, INC. Ph: 920-9212120 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2010 Doc #:26918902
Cust Comments: CHECK FOR VEHICLE HAS A LACK OF POWER
Tech Comments: TESTED THE SYSTEM AND FOUND EGR VALVE STUCK, REPLACED THE EGR VALVE AND RETESTED GOOD
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 51 1B03 030204 * 6A642 * L87 55 55026
AWS Claim Key: 9273796 Trx Code: E72 Labor Hrs: 18.4
Dlr Cd-Sub Cd: 06169 - * Name: SERVICE MOTORS, INC. Ph: 920-9212120 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:15-JUL-2010 Doc #:27023901
Cust Comments: CHECK FOR COOLANT LEAKING AGAIN
Tech Comments: PRESSURE TESTED THE SYSTEM PER TSB 9 8 3, FOUND PRESSURES BAD AND CHECKED HEADGASKETS, FOUND HEADGASKETS LEAKING DISASSEMBLED AND REPLACED THE HEADGASKETS CHECKED HEADS FOR STRAIGHTNESS, ALL OK, REPLACED THE INJECTOR SEALS AND GLOW PLUG HARNESS, REPLACED EBP SENSOR AND FLUSHED COOLANT TESTED TURBO OK, REASSEMBLED AND RETESTED CODE P0528 REPLACED THE FAN CLUTCH AND EBP SENSOR, CLEARED CODES AND R
1FTSW21P86ED33041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-MAR-2006 24-MAY-2006 124013 USA 51 6N07 010801 6C3Z 8200 AAA B66 D4 55326
AWS Claim Key: 9295748 Trx Code: OTC Labor Hrs: 0
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2010 Doc #:00975651
Cust Comments: CUST STATES DEFECTIVE CHROME
Tech Comments: CHROME PEELING SPW GRILLE CHROME PEELING
