1FTSW21P76EC70577
OASIS RESULT: 1FTSW21P76EC70577 USA: EN 16-JANUARY-2013 / 04:56:12 EST/ APP1
Local Time: 16-JANUARY-2013 / 2:56:16 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2006 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION
PAINT COLOR: Oxford White WB C/C
PAINT CODE: Z1
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.5 X 17 Polished Alum Wheel
FRONT TIRE: LT265/70/R17E A/T OWL
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
WARNING MESSAGES
CLAIMS:
Customer Concern Code F06-PEELED PAINT (EXCLUDES TRIM/BUMPER)
Condition Code 70-CHIPPED/SCRATCHED
Technician Comment VERIFIED CONCERN FOUND EMBLEM PEELING REPLACED F 250 EMBLEM ON LEFT FRONT FENDER
Customer Comment F 250 EMBLEM ON DRIVERS SIDE FRONT FENDER IS PEELING
Customer Concern Code L65-ENGINE LEAKS OIL
Condition Code D8-FAILED GASKET/SEAL
Technician Comment VERIFIED CONCERN PERFORMED ENG OIL LEAK DIAG ADDED DYE TO SYS FOUND CAM SENSOR CRANK SHAFT SENSOR O RINGS LEAKING REPLACED CAM SENSOR O RING AND CAM SENSOR RECHECK FOR LEAKS
Customer Comment CUSTOMER STATES ENG LEAKING OIL
Customer Concern Code D50-OTHER ENGINE TROUBLES Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment VERIFY CONC COOLING SYS TESTELEC FAN TST TST PIDS R&R FAN SHROUD, TURBO REPLACE ERG COOLER REASSEMBLE RETEST OK
Customer Comment VEHICLE SMOKING VERY BADLY AND OIL LEAKING OUT EXHAUST
Customer Concern Code L87-COOLANT LEAK
Condition Code 55-PLUGGED/RESTRICTED
Technician Comment TEST COOLING SYSTEM PER TSB 09 08 03 REPLACE CAP HELD FOR MORE THAN 15 MINUTES ROADTEST MONITOR TEMPS STAY WITHIN 10 DEGREES OF EACH OTHER TEST TURBO FOR OVER BOOST OK TEST FAN OK VEHICLE NEEDS HEAD GASKETS REM AC EVAP CASE RECOVER EVAC AND RECHARGE AC REPLACE BOTH HEAD GASKETS REASSEMBLE TEST DRIVE FLUSH COOLOING SYSTEM TEST DRIVE VERIFY REPAIR
Customer Comment VEHCILE IS LEAKING ANTIFREEZE
Condition Code 28-OPEN CIRCUIT
Technician Comment VERIFY CONCERN.PINPOINT TEST P FOR CODE PO266. SEE ATTACHED SHEET DIAG SHUTS FOR TESTS AND RESULTS FOR STEPS P1 P19.REPLACE #2 INJECTOR ON LEFT BANK PER HOT LINE APPROVAL. CLEARED CODES CHANGE OIL, FILTER AND RETESTED HAD TO REPLACE FUEL PRESSURE REGULATOR TO RESTORE FUEL PRESSURE TO SPECS FAXED OVER ALL REQUE
Customer Comment CUSTOMER STATES HE HAS A CODE OF PO266NIJ CYLINDER #2 CODE ON TRUCK
