1FTSW21P45EB28623
thanks!
OASIS RESULT: 1FTSW21P45EB28623 USA: EN 16-JANUARY-2013 / 04:41:33 EST/ APP2
Local Time: 16-JANUARY-2013 / 2:41:37 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION
PAINT COLOR: Ebony WB C/C
PAINT CODE: UD
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 8X18" Forged Polished Alum Wheel
FRONT TIRE: LT 275/70R18E A/S BSW
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Concern Code
G29-OTHER WARNING LIGHT/GAUGE TROUBLES (VOLT/AMP)
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment WATER IN FUEL LIGHT ON DRAINED & CLEANED MODULE STILL ON REPLACED CONTROL MODULE RETEST OK
Customer Comment WATER IN FUEL LIGHT COMES ON
B66-OTHER EXTERIOR TRIM TROUBLES
Condition Code 81-TARNISHED/FADED
Technician Comment REPLACED LEFT FRONT F250 EMBLEM DUE TO PEELING
Customer Comment DRIVERS F250 PAINT FLAKING
Customer Concern Code *-N/A
Condition Code *-[N/A]
Technician Comment INSTALL COOLANT DEGAS BOTTLE LABEL PER RECALL 05B32
Customer Comment 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Technician Comment CUST ASSURANCE TEST DRIVE PER RECALL 59B01
Customer Comment 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
N11-UNUSUAL ENGINE NOISE AT IDLE/STARTUP
Condition Code 01-BROKEN/CRACKED
Technician Comment REPLACED BROKEN DIPSTICK HANDLE BROEKN MTIME NOT IN LTS
Customer Comment OIL DIP STICK END BROKE
Technician Comment REPLACE EP SENSOR & REFLASH PCM FICM & TCM PER RECALL 05E15
Customer Comment 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Customer Concern Code C20-OTHER TEMPERATURE CONTROL TROUBLES
Technician Comment 65370 EATC DIAG CUTS OUT INTERM CHECK CONNECTIONS CONNECTIONS OK REPLACE EATC RETEST
Customer Comment CUST STATES THAT EATC HAS WENT OFF SEVERAL TIMES
A85-OTHER ELECTRICAL ACCESSORY TROUBLES
Technician Comment 65370 CLUSTER INTERMITTANTLY INOP PERFORM PINPOINT TEST & REPLACE CLUSTER PER SER VICE MANUAL
Customer Comment CUST STATES THAT INTERM CLUSTER WILL NOT WORK INTERM
