OASIS RESULT: 1FTWX31R78EE45323 USA: EN 22-JANUARY-2013 / 00:31:05 EST/ APP1
Local Time: 21-JANUARY-2013 / 10:31:11 PM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES
BODY STYLE: F-350 S/CAB PICKUP 4X4
ENGINE: 6.4L Diesel V8 Twin Turbo
TRANSMISSION: M6HD-W 6 Speed Manual Transmission
AXLE CODE: 3L
ENGINE CALIBRATION: 8F726E0A
PAINT COLOR: Ebony WB C/C
PAINT CODE: UD
RADIO: Prem AM/FM Stro/CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 8 X 20" Prem Forged Pol Alum Wheel
FRONT TIRE: LT275/65R 20E A/T OWL Tire
GROSS VEHICLE WEIGHT: 11,400 LB. GVW
CLAIMS:
Customer Comments 08B07 CERTAIN 2008 MODEL YEAR F SUPER DUTY VEHICLES EQUIPPED WITH A 6.4
Tech Comments REPROGRAM PER 08B07
Customer Comments 09B08 FUEL INJECTOR REPLACEMENT
Tech Comments REPLACE #S 1,3,4,5,6,7 & 8 INJECTORS PER 09B08
Customer Comments CHECK ENGINE LIGHT IS ON, HARD START AT TIMES, COUGHS AT TIMES
Tech Comments CHECK ENGINE LIGHT IS ON HARD TO START AT TIMES, COUGHS PERFORM DIAGNOSIS P042E P0404 P1335 PERFORM PINPOINT TESTS PID MONITOR DIAGNOSE AS EGR VALVE STUCK OPEN REPLACE EGR VALVE CLEAN ANY CARBON RERUN TESTS PASS ROADTEST CLEAR CODES
Customer Comments CHECK DRIVERS FRONT HEATED SEAT INOP
Tech Comments DRIVERS FRONT HEATED SEAT INOP SUBLET TO DOUGS #161 R&I DRIVERS SEAT,PANEL,BACKREST & COVER,FOAM,TRACKS,CUSHION COVER TO REPLACE BACK & BOTTOM ELEMENTS BURNT & REPAIR FOAM
Customer Comments CUSTOMER STATES COOLING FAN RUNS MOST OF THE DAY, SEEMS TO LOSE POWER
Tech Comments PERFORM IDS DIAGNOSIS P0528,P0529 FAN CLUTCH SPEED ERROR CHECK OASIS TSB 08 5 14 APPLIES REPLACE THE FAN CLUTCH ASSY.CLEAR CODES RETEST PASS
Customer Comments 11B23 POWERTRAIN CONTROL MODULE RECALIBRATION
Tech Comments REPROGRAM PCM PER 11B23
Customer Comments 11B24 CONTINENTAL TIRE INSPECTION
Tech Comments INSPECT TIRES PER CSP 11B24 TIRES ON VEHICLE NOT CONTINENTAL TIRES SPARE TIRE AFFECTED ORDER SPARE TIRE
Customer Comments CHECK WHISTLE TYPE NOISE IN ENGINE AREA , SEEMS TO HAPPEN ON ACCELERATION
Tech Comments VERIFY NOISE INSTALL CHASSIS EARS VERIFY INNER AC BELT TENSIONER PULLEY BEARING CAME APART, NOISY REPLACE INNER TENSIONER & SHREDDED BELT ASSY.& RECHECK
Customer Comments CHECK CLUTCH PEDAL SNAPS AFTER BEING RELEASED, STICKS DOWN AT TIMES
Tech Comments CUDL CASE 1417033352 P18 CLP VERY LOYAL CUSTOMER W MULTIPLE VEHICLES VERIFY CONCERN DIAGNOSE CLUTCH SLAVE CYLINDER MASTER CYLINDER BYPASSING & LEAKING IN VEHICLE REPLACE SLAVE ASSY. & RECHECK
