General Contractor
The truck is an 05 F-350 Vin # 1ftww33p05ec35464.
Thank You.
General Contractor
Sorry they put the wrong Vin on the Insurance card
Correct vin 1FTWW33P05EC35494
Thank You again.
OASIS RESULT:
1FTWW33P05EC35494
07/17/2006
22:12:41
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/01/2005 BUILD DATE
02/16/2005 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/13/2006
DEALER: Brandon Ford
WARRANTY CLAIM NUMBER: 063879 ODOMETER: 022223M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6701A D8 FAILED GASKET/SEAL
000 6007D
LEAKING SEAL - CRANKSHAFT REAR MAIN (FULL CIRCLE TY PE) - REPLACE
03/02/2006
WARRANTY CLAIM NUMBER: 062902 ODOMETER: 021509M
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
05B32 COMPLETED
03/02/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B35B
END OF OASIS REPORT FOR 1FTWW33P05EC35494
Standard Claims List For Model Year 2005
1FTWW33P05EC35494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-FEB-2005 01-MAR-2005 124222 USA 13 * * * * * * * 21509
AWS Claim Key: 3916165 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04963 - * Name: BRANDON FORD Ph: 813-2463673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:06290240
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 05B32 COMPLETED
AWS Claim Key: 4038430 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04963 - * Name: BRANDON FORD Ph: 813-2463673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:06290241
Cust Comments: 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: 05B35 COMPLETED
1FTWW33P05EC35494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-FEB-2005 01-MAR-2005 124222 USA 13 1D01 03XXXX 3C3Z 6701 AA L65 D8 22223
AWS Claim Key: 4105845 Trx Code: E84 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 04963 - * Name: BRANDON FORD Ph: 813-2463673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2006 Doc #:06387951
Cust Comments: CUST STATES VEHICLE HAS OIL LEAK
Tech Comments: LEAKING SEAL CRANKSHAFT REAR MAIN (FULL CIRCLE TYPE) REPLACE
