OASIS RESULT:
1FTNW21P34EB48566
08/02/2006
23:08:26
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/31/2004 BUILD DATE
11/21/2003 SALE MILEAGE
ARN MESSAGES
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
05/23/2006
DEALER: Joe Cooper Ford of Yukon
WARRANTY CLAIM NUMBER: 408215 ODOMETER: 037892M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6C640AA CONNECTION A/C DUCT 001 VERIFY60 01 BROKEN/CRACKED
F3AZ 6766B CAP ASY OIL FILLER 001 6005F
000 6005F1
000 6005F1X1
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F2
000 6005F20
000 6005F6
000 6005F8
000 6646AH
000 MT6766
37892 CAC BOOT TORN ROAD TEST VERIFIED LOW POWER SMOKING AND IMPROP ER SHIF TS CONNECT WDS 6.0 PERF DIAG STEPS RETRI EVED P0299 0478 PPT KA VISUAL INSP ECTION FOUND HOT SIDE CAC BOOT AT TURBO TORN AND LEAKING REP LACED BOOT AND OIL FILL CAP DUE TO HOT SIDE CAC TUBE MELTED CAP AFTER BOOT TORE. CLEARED DTCS ROAD TEST OK RETEST AFTER REPAIR ALL PASS CC 30 JAK
01/17/2006
DEALER: O'Meara Ford Center Inc
WARRANTY CLAIM NUMBER: 192244 ODOMETER: 034629M
LABOR OP
CONDITION CODE
CONDITION DESC
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D D8 FAILED GASKET/SEAL
VC 7B 002 9424A
9P456 COOLER - EGR 000
34637 FOUND EGR COOLER HOSE LEAKING. 8005D 0.4 9424A 4.7 4903 PRESSURE TEST COOLING SYSTEM, FOUND EGR COOLER HOSE LEAKING. R&R INTAKE MANIFOLD TO ACC ESS AND R&R EGR COOLER HOSE. PRESSURE TEST AND ROAD TEST TO VERIFY REPAIRS. ALL OK AT THIS TIME.
01/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F836BA PEDAL & SENSOR ASY 001 MT9F836 01 BROKEN/CRACKED
34629 (01) ACCELERATOR PEDAL. REPLACED BROKEN ACCELERATOR PEDAL.
01/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 14A099A SHIELD WIRING 001 05S34D
34629 4694 PERFORMED RECALL 05S34D, INSTALLED FICM HARNESS REPAIR KIT.
01/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15F
34629 4694 PERFORMED RECALL 05E15F, REPLACED EBP SENSOR AND REPRGRAMMED PCM , FICM, TCM.
01/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
34629 4694 PERFORMED RECALL 05B01, ROAD TEST.
END OF OASIS REPORT FOR 1FTNW21P34EB48566
Standard Claims List For Model Year 2004
1FTNW21P34EB48566 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 31-JUL-2004 152208 USA 18 1H03 030804 * 9P456 * L65 D8 34629
AWS Claim Key: 8305421 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 03294 - * Name: O'MEARA FORD CENTER INC Ph: 303-4511331 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:192244A
Cust Comments: CUSTOMER STATES OIL IS LEAKING NEAR PASS SIDE OF ENGINE, DRIPS ON GROUND, SMELL BURNING SMELL NEAR OIL CAP. L65
Tech Comments: 34637 FOUND EGR COOLER HOSE LEAKING. 8005D 0.4 9424A 4.7 4903 PRESSURE TEST COOLING SYSTEM, FOUND EGR COOLER HOSE LEAKING. R&R INTAKE MANIFOLD TO ACCESS AND R&R EGR COOLER HOSE. PRESSURE TEST AND ROAD TEST TO VERIFY REPAIRS. ALL OK AT THIS TIME.
1FTNW21P34EB48566 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 31-JUL-2004 152208 USA 18 5T01 031801 3C3Z 9F836 BA B19 01 34629
AWS Claim Key: 8319044 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03294 - * Name: O'MEARA FORD CENTER INC Ph: 303-4511331 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:192244D
Cust Comments: ACCEL PEDAL RUBBER PAD IS LOOSE AND FALLS OFF ALL THE TIME. B19
Tech Comments: 34629 (01) ACCELERATOR PEDAL. REPLACED BROKEN ACCELERATOR PEDAL.
1FTNW21P34EB48566 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 31-JUL-2004 152208 USA 18 * * * * * * * 34629
AWS Claim Key: 8305422 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 03294 - * Name: O'MEARA FORD CENTER INC Ph: 303-4511331 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:192244E
Cust Comments: RECALL 05S34 FUEL INJ CONTROL MODULE
Tech Comments: 34629 4694 PERFORMED RECALL 05S34D, INSTALLED FICM HARNESS REPAIR KIT.
AWS Claim Key: 8305423 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03294 - * Name: O'MEARA FORD CENTER INC Ph: 303-4511331 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:192244F
Cust Comments: RECALL 05E15 EXH PRESS SENSOR
Tech Comments: 34629 4694 PERFORMED RECALL 05E15F, REPLACED EBP SENSOR AND REPRGRAMMED PCM, FICM, TCM.
AWS Claim Key: 8305424 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03294 - * Name: O'MEARA FORD CENTER INC Ph: 303-4511331 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:192244G
Cust Comments: RECALL 05B01 TEST DRIVE
Tech Comments: 34629 4694 PERFORMED RECALL 05B01, ROAD TEST.
1FTNW21P34EB48566 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 31-JUL-2004 152208 USA 23 2H01 031202 5C3Z 6C640 AA N12 01 37892
AWS Claim Key: 9438428 Trx Code: E72 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 03036 - * Name: JOE COOPER FORD OF YUKON Ph: 405-3541111 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2006 Doc #:408215A
Cust Comments: C S WHILE UNDER A LOAD BLACK SMOKE AND TRANS WILL NOT SHIFT CORRECT; BUZZING TYPE NOSIE CAN BE HEARD
Tech Comments: 37892 CAC BOOT TORN ROAD TEST VERIFIED LOW POWER SMOKING AND IMPROP ER SHIFTS CONNECT WDS 6.0 PERF DIAG STEPS RETRI EVED P0299 0478 PPT KA VISUAL INSPECTION FOUND HOT SIDE CAC BOOT AT TURBO TORN AND LEAKING REP LACED BOOT AND OIL FILL CAP DUE TO HOT SIDE CAC TUBE MELTED CAP AFTER BOOT TORE. CLEARED DTCS ROAD TEST OK RETEST AFTER REPAIR ALL PASS CC 30 JAK
