Could you please help me out with the report on a 2002 F-350 with the vin#
1FTSW31F22EA42414
Thank you very much,
Doug
OASIS RESULT:
1FTSW31F22EA42414
08/02/2006
23:09:48
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/30/2001 BUILD DATE
08/22/2001 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
09/20/2005
DEALER: Jerome-Duncan, Inc.
WARRANTY CLAIM NUMBER: 298314 ODOMETER: 037119M
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 12A650DF PROCESSOR ASSY 001 12650D 42 DOES NOT OPERATE PROPERLY
000 12650DX1
000 12650D6
000 12651D2
37119 INSPECTED NO START.VEHICLE CRANKS.EEC TEST NO COMMUNCATION.FOUND NEC TO CHECK POWER AND GROUNDS.PERFORMED NO COMUNCATION PINPOINT TEST FOUND NE C TO REPLACE PCM RETEST OK ROADTEST PASS
END OF OASIS REPORT FOR 1FTSW31F22EA42414
Standard Claims List For Model Year 2002
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 4 2E06 030008 F6TZ 9F838 A E29 42 3273
AWS Claim Key: 479477 Trx Code: 1 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 02746 - * Name: ROMEO FORD INC Ph: 574-7525500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2001 Doc #:02424301
Cust Comments: INSPECT FOR WHEN ENGINE IS COLD VECHILE IDLES ROUGH CHECK ENGINE LIGHT IS ON WILL NOT ACCELERATE
Tech Comments: PERFORM DIESEL DIAGNOSIS CODE P1280 PRESENT REPLACEICP SENSO R CLEAR CODE TEST DROVE RETEST OK
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 26 5R01 110401 * 3C611 * C50 42 21155
AWS Claim Key: 7770591 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 10386 - * Name: STU EVANS LINCOLN-MERCURY, LAKESIDE, INC. Ph: 586-8402000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2003 Doc #:50347101
Cust Comments: CUST STATES HEARS RUBBING NOISE FROM STEERING COLUMN WHEN MAKING SLIGHT TURN
Tech Comments: CCC 42 BASIC 3C611 ROAD TEST VEHICLE FOR RUBBING NOISE. INSPECT VEHICLE, HEARD RUBBING NOISE COMING FROM STEERING COLUMN
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 26 5I01 110204 F1TZ 3A674 DBRM C50 42 21155
AWS Claim Key: 7770590 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 10386 - * Name: STU EVANS LINCOLN-MERCURY, LAKESIDE, INC. Ph: 586-8402000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2003 Doc #:50347102
Cust Comments: CUST STATES POWER STEERING PUMP MAKES CONSTANT GROANING NOIS WHEN TURNING SEEMS EXCESSIVE
Tech Comments: CC 42 BASIC 3A674 START ENGINE, LISTEN FOR ANY ABNORMAL P.S. NOISE. CHEKC FLUID LEVEL, OK. CHECK FOR ANY LEAKS, NONE FOUND.
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 2H01 030008 F81Z 6C640 CA L65 D8 25863
AWS Claim Key: 9169285 Trx Code: E84 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:21968001
Cust Comments: ENGINE LEAKS OIL COMMING FROM REAR OF MOTOR PER CUST
Tech Comments: 6C640 L65 D8 MT NO OPS FOR 6C640 AND 9E436 RPLCMNT VRFY OIL LK, CLN DYE TST FND INTRCLR TUBES ON DRVRS SIDE BLOW OFF ORNG INTK BOOTS LKNG AND HI PRESS PMP FTTNG LKNG RMV AND RPLC LFTCLR TUBE PERF TSB 03 21 50 FOR PMP LK INSTL NEW ORING AND LCK TGHT CLEAN AND RD TEST AND REDYE TEST NO LEAKS
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 5I01 110204 F1TZ 3A674 DBRM H22 30 25863
AWS Claim Key: 9169284 Trx Code: E90 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:21968002
Cust Comments: CAR NEEDS EXTRA EFFORT IN STEERING. HARD TO TRUN INTERMITENTLY
Tech Comments: 3A674 H22 30 ROAD TESTED,CONFIRMED,PRESSURE CK POWER STEERING SYSTEM, FOUND,50 PSI AT IDLE NO RESTRICTIONS,PRESSURE RISES WHEN RUNING AT HI RPM ONLY REPLACED POWER STEERING PUMP AND RECK OK
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 5R01 110401 * 3D677 * N59 42 25863
AWS Claim Key: 9169283 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:21968008
Cust Comments: SQUEAK WHEN TURNING THE WHEEL SIDE TO SIDE SEE BRETT FOR DETAILS
Tech Comments: 42 3D677 N59 INSPECT VEC FOR SQUEAK IN COULNM. PULL BACK BUSHING AT STEE RING COULNM SHAFT JUBE BUSHING AT FIREWALL REINSTALL RETEST
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 1B03 030204 1C3Z 6A642 AA L65 D8 27273
AWS Claim Key: 9634140 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2004 Doc #:22078601
Tech Comments: 6A642 L65 D8 DYE TEST VERIFY OIL LEAKING FROM THE OIL COOLER ASSEMBLY BOTH ENDS INSTALL NEW OIL COOLER ASSEMBLY AND RETEST NO LEAKS RE DYE TEST OK
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 1B02 030202 F4TZ 6881 B L65 42 27273
AWS Claim Key: 9696952 Trx Code: E90 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2004 Doc #:22078603
Cust Comments: TECH FND OIL COOLER LEAKING OIL WHEN PERFORMING INSTALL CASTING
Tech Comments: 6881 L65 42 DYE TEST VERIFY OIL LEAKING FROM THE FRT OF THE OIL CLR REMOVE OIL COOLER AND FND POOR CASTING ON THE FRT END OF THE OIL COOLER SERVICE PART THE FRT END AND RETEST NO LEAKS OK
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 31 2E06 030402 F81Z 9A543 CRM D13 42 27273
AWS Claim Key: 9648215 Trx Code: E84 Labor Hrs: 9.5
Dlr Cd-Sub Cd: 03025 - * Name: JEROME-DUNCAN, INC. Ph: 586-2687500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2004 Doc #:22078604
Cust Comments: ENGINE IDLES TOO ROUGH FOUND DURING INSPECTION
Tech Comments: 9A543 D13 42 RDTST,VRFY NO PWR UNABL TO PULL INTO TRFFC,PERF DSL DIAG SHT 1 14 PASS.CODE P1298 RPLC THE IDM,RSE VEH,REM INNR FNDR WELL AND RPLCRETST PASS RUNS BAD.ATTMPT TO RPGRM PCM WLDNT PRGRM TO LVL,REM AND RPLC PCM NO CHNG,PERF CMPRSN TST WTHIN 10PSI OF 470,CLLHTLN 4CSFB004,SAID TO RPLC HI PRESS OIL PMP,RETEST INSTLD RDTEST RETEST NO FLTS RUNS PERFECT
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 41 2E06 030008 F81Z 9E527 CRM D50 63 35104
AWS Claim Key: 12746796 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 02746 - * Name: ROMEO FORD INC Ph: 574-7525500 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2004 Doc #:04791602
Cust Comments: EXCESSIVE BLUE SMOKE ON COLD START
Tech Comments: REPLACED #2, #4 & #5 FUEL INJECTORS
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 43 1A03 030101 F81Z 6009 AARM N11 01 35770
AWS Claim Key: 13311138 Trx Code: E72 Labor Hrs: 21.7
Dlr Cd-Sub Cd: 07533 - * Name: JEROME-DUNCAN, INC. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2005 Doc #:27428801
Cust Comments: CUST STATES WHEN DRIVING AT HIGHWAY SPEEDS ENG MAKES NOISE WHEN STO
Tech Comments: INSP DIESEL NO START NEC TO PERFORM CYLINDER LEAKAGE TEST 1 AND 2 DAMAGED AND LEAKING THREW CRANKCASE REMOVED ENG DETERMINED CONDITION CALLED HOTLINE ADVISED IF COULD REPL SHORT BLOCK RPT 5CDA5013 REPL SHORT BLOCK DISSEMBLE HEADS CKED VALVES OK REASSEMBLE REINSTALLED RETEST OK
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 45 2B01 0300XX F7TZ 12K073 A D21 42 36214
AWS Claim Key: 13382975 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 07533 - * Name: JEROME-DUNCAN, INC. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2005 Doc #:28289001
Cust Comments: ENGINE STALLS WHEN COMING TO A STOP CHECK AND ADVISE
Tech Comments: INSP DIESEL PERFORM 1 10 KOEO P1000 KOEC P0344 KOER P1000 NEC TO PINPOINT TESTKC 1 PERFORMED CAM SENSOR TEST FOUND INOP NEC TO REPL CAM SENSOR ROADTESTMOINTORED PIDS W NGS PASS
1FTSW31F22EA42414 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 22-AUG-2001 30-AUG-2001 148418 USA 50 2G01 031401 2C3Z 12A650 DF D02 42 37119
AWS Claim Key: 14346233 Trx Code: S07 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07533 - * Name: JEROME-DUNCAN, INC. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2005 Doc #:298314A
Cust Comments: ENGINE NO START
Tech Comments: 37119 INSPECTED NO START.VEHICLE CRANKS.EEC TEST NO COMMUNCATION.FOUND NEC TO CHECK POWER AND GROUNDS.PERFORMED NO COMUNCATION PINPOINT TEST FOUND NEC TO REPLACE PCM RETEST OK ROADTEST PASS
