1FTSW21P75EB66735
:thanks:
OASIS RESULT:
1FTSW21P75EB66735
08/07/2006
22:08:46
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/06/2005 BUILD DATE
12/10/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
04/07/2006
DEALER: Ford, Lincoln-Mercury of Slide
WARRANTY CLAIM NUMBER: 154146 ODOMETER: 027082M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
DONE PERFORMED RECALL
04/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
DONE PERFORMED TEST DRIVE PER RECALL
04/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
PERFORMED RECALL
02/14/2006
DEALER: Sullivan Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 095927 ODOMETER: 026027M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640B CONNECTION A/C DUCT 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6646AH
HECK AND INSTALLED CAC HOSE ON RIGHT SIDE.
11/14/2005
DEALER: Country Ford
WARRANTY CLAIM NUMBER: 021449 ODOMETER: 024819M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 12650D 42 DOES NOT OPERATE PROPERLY
000 12650DX1
000 9527AR
DIAG--INJECTOR #3 AND #7 OUT #7 REGAINED CHARGE--R&R INJECTOR #3 AND RECH ECKED--PERFORM ING TO SPECS--TESTED OK
11/02/2005
WARRANTY CLAIM NUMBER: 021327 ODOMETER: 024816M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 12650D 42 DOES NOT OPERATE PROPERLY
3C3Z 9C891AA HARNESS ASY FUEL INJ 001 12650D45
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 12650DX1
000 12650D67
000 9527AR
000 MT9891
000 12650D84
VERIFY CONCERN PERFOMRED PINPOINT TEST EEC TEST FOLLOWED TSB T REPLACE FICM MODULE AND HARNESS ALSO FOUND #3 AND #7 INJECTOR FAILED RAND R REPALCE INJEC TORS RE CK ALL OK
10/24/2005
WARRANTY CLAIM NUMBER: 021211 ODOMETER: 024571M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6C646DA DUCT ASY-ENG CHG AIR 001 6646AC 42 DOES NOT OPERATE PROPERLY
000 MT6640
TECH FOUND EXHAUST HOSES WARPED AND CLAMPS NOT STAYING TIGHT R&R HOSES AND CLAMPS AND RETESTED--NO LEAKS
10/24/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3E651CA ABSORBER-STEERING SH 001 MT3E651 42 DOES NOT OPERATE PROPERLY
FRONT DAMPER LEAKING--R&R DAMPER
09/30/2005
WARRANTY CLAIM NUMBER: 020998 ODOMETER: 023000M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7R081BA OIL PIPE ASY 001 7000A43 42 DOES NOT OPERATE PROPERLY
5C3Z 7B155AA FLTR&HD ASY TRNS OIL 001 MT7R081
TRANSMISSION LINE FITTINGS OFF CENTER RESULTING IN STRIPPED THREADS CAUSING LEAK--R&R FILTER ASSEMBLY AND LINES
END OF OASIS REPORT FOR 1FTSW21P75EB66735
