OASIS RESULT:
1FTJW36F2VEC29841
08/29/2006
22:29:28
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1997 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF 5 SPD CLOSE RATIO AXLE CODE
39 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/10/1997 BUILD DATE
07/30/1997 SALE MILEAGE
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTJW36F2VEC29841
Standard Claims List For Model Year 1997
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 9 2E03 0300XX F5TZ 9C968 A D21 42 9611
AWS Claim Key: 9964788 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01403 - * Name: FAMILY FORD Ph: 717-2492215 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-1998 Doc #:02144801
Cust Comments: WILLNOT STAY RUNNING
Tech Comments: TEST SYSTEM AND TRAC CONBCERN BACK TO FUEL REG
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 14 5V01 060301 * 1102 * N27 14 17620
AWS Claim Key: 13256090 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 01403 - * Name: FAMILY FORD Ph: 717-2492215 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-1998 Doc #:12476901
Cust Comments: BRAKE PULSATION
Tech Comments: RESURFACE BOTH FRONT ROTORS
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 14 4B03 080203 F2TZ 7A543 D L72 30 17620
AWS Claim Key: 13256091 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 01403 - * Name: FAMILY FORD Ph: 717-2492215 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-1998 Doc #:12476902
Cust Comments: CLUTCH FLUID LEAKING
Tech Comments: REPLACE CLUTCH SLAVE CYL AND MASTER CYL AND SWITCH BLEED SYSTEM
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 14 * * * * * * * 17620
AWS Claim Key: 13223024 Trx Code: 97B16 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01403 - * Name: FAMILY FORD Ph: 717-2492215 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-1998 Doc #:12476903
Cust Comments: 97B16 RECALL
Tech Comments: REPLACE AIR CLEANER NUTS
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 22 1A01 030102 * 6049 * L65 D8 22878
AWS Claim Key: 17310823 Trx Code: E84 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 07506 - * Name: HUSTON FORD LINCOLN MERCURY Ph: 814-6433430 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-1999 Doc #:01170101
Cust Comments: CUSTOMER THINKS TURBO HAS LEAK
Tech Comments: INSTALL ENGINE DYE, CHECK WITH BLACKLIGHT, REPLACE OIL RAIL SUPPLY PLUG AS PER SSM
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 28 2B03 030703 * 12B533 * D03 42 33523
AWS Claim Key: 20259520 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07506 - * Name: HUSTON FORD LINCOLN MERCURY Ph: 814-6433430 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-1999 Doc #:01427101
Cust Comments: HARD TO START WHEN COLD
Tech Comments: CHECK GLOW PLUGS, CIRCUIT MODULE WEAK, REPLACE MODULE
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 28 7Q01 110602 F6TZ 9C899 AA A25 42 33523
AWS Claim Key: 20259521 Trx Code: E83 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07506 - * Name: HUSTON FORD LINCOLN MERCURY Ph: 814-6433430 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-1999 Doc #:01427102
Cust Comments: CRUISE CONTROL NOT WORKING
Tech Comments: CHECK CIRCUITS, BRUSH CONTACT INOPERATIVE. REPLACE SWITCH AND RETEST
1FTJW36F2VEC29841 T/F1 F T/BC T/CD T/E A1 T/RK T/DS 30-JUL-1997 10-SEP-1997 144453 USA 38 2B01 030701 F7TZ 12K073 A D21 42 54867
AWS Claim Key: 21374475 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01403 - * Name: FAMILY FORD Ph: 717-2492215 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2000 Doc #:14225901
Cust Comments: SHUTS OFF WHEN DRIVING
Tech Comments: EEC TEST SYSTEM RETRIEVE CODES AND REPLACE FAULTY CAM SENSOR
