I am buying the following truck and would very much like an OASIS report before finalizing the deal.
VIN:1FTHF36F2VEC16196
Thank you.
:thanks:
Hi,
OASIS RESULT:
1FTHF36F2VEC16196
09/25/2006
07:20:42
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1997 F-SERIES BODY STYLE
F-350 RC PICKUP 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF 5 SPD CLOSE RATIO AXLE CODE
C5 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/30/1997 BUILD DATE
06/23/1997 SALE MILEAGE
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
1FTHF36F2VEC16196 T/F1 F T/BB T/CD T/E A1 T/RK T/DS 23-JUN-1997 30-JUN-1997 144509 USA 9 1E04 031101 F5TZ 6316 AA L65 D8 16184
AWS Claim Key: 6925452 Trx Code: E84 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 07644 - * Name: FOX FORD-MERCURY INC Ph: 724-6273151 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-1998 Doc #:01163351
Cust Comments: ENGINE OIL LEAK
Tech Comments: GASKET FAILED RADIATOR ASSY. - REMOVE AND INSTALL OR REPLACE
1FTHF36F2VEC16196 T/F1 F T/BB T/CD T/E A1 T/RK T/DS 23-JUN-1997 30-JUN-1997 144509 USA 12 4B01 080201 E7TZ 7515 A P23 30 23221
AWS Claim Key: 10689704 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07644 - * Name: FOX FORD-MERCURY INC Ph: 724-6273151 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-1998 Doc #:01325451
Cust Comments: CK. FOR HAVING TO PUSH CLUTCH HARD TO FLOOR TO GET INTO GEAR
Tech Comments: CLUTCH WORN FORK CLUTCH RELEASE BEARING REMOVE AND INSTALL OR REPLACE
1FTHF36F2VEC16196 T/F1 F T/BB T/CD T/E A1 T/RK T/DS 23-JUN-1997 30-JUN-1997 144509 USA 58 1A03 030101 * 6026 * L65 D8 99654
AWS Claim Key: 24086156 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 07644 - * Name: FOX FORD-MERCURY INC Ph: 724-6273151 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2002 Doc #:03668851
Cust Comments: CHECK FOR ENGINE OIL LEAK
Tech Comments: R&R POWER STEERING AND BRACKET TO ACCESS FRONT PLUG, TROUBLE ON REAR PLUG GETTING IT LOOSE, INSTALLED NEW PLUGS IN HEAD, RECHECK FOR LEAKS, NONE FOUND, OKK
Thanks,
Vivian
