1FTNW21F53EA50838
I would be greatly appreciative! Thank you in advance!
OASIS RESULT:
1FTNW21F53EA50838
10/12/2006
19:54:39
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
C1 ENGINE CALIBRATION
2F719N0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/03/2002 BUILD DATE
08/15/2002 SALE MILEAGE
00101
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
04/04/2006
DEALER: El Centro Motors
WARRANTY CLAIM NUMBER: 055093 ODOMETER: 033890M
LABOR OP
CONDITION CODE
CONDITION DESC
1L2Z 14529BA SWITCH ASY-WINDOW RE 001 14529A 42 DOES NOT OPERATE PROPERLY
PERFORMED PINPOINT TEST FOR POWER WINDOW SYSTEM, DETERMINED CAUSE OF WINDOW INOP IS RHF MASTER WINDOW SWITCH. REPLACED SWITCH AND RETEST OPERATION, A LL WORKING NORMAL AFTER REPLACEMENT OF SWITCH. LABOR- 12651D2: .3 14529A: .3
04/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 2560136BAA KIT BK ASY FRT ST 001 MT2560136 42 DOES NOT OPERATE PROPERLY
INSPECTION OF CENTER CONSOLE-ARMREST SHOWED FABRIC COMING OFF ASSYMBLY. REMO VED TRIM FROM CONSOLE AND REPLACED ARMREST-CONSOLE ASSYMBLY. LABOR- MT256 0136: .5
04/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7210AAA LEVER GEAR SHIFT 001 7210A 42 DOES NOT OPERATE PROPERLY
000 12651D2
000 12651DX1
000 12651D
DIAG BURNOUT FUSE F2.45 PIN POIN TEST ELECTRICAL CIRCUIT SHORT TO GROUND SHI FTER LEVER AREA CONECTOR REPLACE PART DAMAGE AND REINSTALL FUSE RETEST SYSTE M WORK FAC ESPEC CAUSE SHORT TO GROUND CABLE SHIFTER INSOLATOR DAMAGE 12651D 0.2 12651DX1 0.1 12651D2 0.3 7210A 0.3
03/13/2006
WARRANTY CLAIM NUMBER: 053607 ODOMETER: 033254M
LABOR OP
CONDITION CODE
CONDITION DESC
F4TZ 8255A GASKET WATER OUTLET 001 8575B 42 DOES NOT OPERATE PROPERLY
VC 7B 001 8575B1
PRESSURE TEST COOLING SYSTEM LEKING THERMOSTAT HOUSING O RING RECOVERY COOLA NT REPLACE O RING RETEST PASS TEST 8575B 0.4 8575B1 0.4
03/13/2006
LABOR OP
CONDITION CODE
CONDITION DESC
XF2Z 14018AA SWITCH ASY DOOR WARN 001 23943AT 42 DOES NOT OPERATE PROPERLY
XF2Z 14018AD SWITCH ASY DOOR WARN 001 23943A6
DIAG DOOR AJAR LIGHT ON ALL TIME ISTALL WDS TEST CODES PASS TEST INTERMITENT PROBLEM CHECK PID FRONT AND REAR DOOR AJAR SWITCH CLOSED CIRCUIT SOME TIME REMOVE FRONT AND REAR DOOR PANEL REPLACE DOOR AJAR SWITCH RETEST SYSTEM WORK FAC ESPEC 23943AT 0.4 23943A6 0.4
10/05/2005
WARRANTY CLAIM NUMBER: 043319 ODOMETER: 029223M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3049DA JOINT ASY-FRT SUSP L 002 3504A 42 DOES NOT OPERATE PROPERLY
4C3Z 3050BA KIT-FRT SUSP LWR SPD 002 3674A
4C3Z 3304BA ROD ASY-STR ARM TO I 001 MT3674
4C3Z 3A131AD KIT SPINDLE CON ROD 001
4C3Z 3304BB ROD ASY-STR ARM TO I 001
F4DZ 3D643A PLATE & BUSHING-P/S 001
E9DZ 3D607A ROTOR-PWR STRG PUMP 001
F1DZ 3D590B PLATE-P/S-PUMP PRESS 001
E9DZ 3B559A SHAFT-P/S PUMP ROTOR 001
E1AZ 3B584A KIT P/S PUMP SEAL 001
XT 2QDX 001
INSPECT VEHICLE FOR P-S LEAKS GEAR BOX LEAKING AND PUMP IS NOISEY REMOVE INSTALL AND OVERHAULED P-S GEAR BOX AND PUMP 3504A-14 3404A1-10 3674A-11 MT-07 MT FOR PUMP OVERHAUL NO LABOR OP TIME LOGED WIHT LI NE 52
10/05/2005
LABOR OP
CONDITION CODE
CONDITION DESC
F6TZ 3E501AA SEAL HSG PISTON 001 3049AT 42 DOES NOT OPERATE PROPERLY
F4UZ 3E502A SEAL HSG PISTON 001 3130AC
388898S 002 3001A
000 3001A6
000 2134ABT
000 4462AT
PERFORM TEST DRIVE CK CONDITION VEHICLE HAS EXCESIVE PLAY AT STEERING INSPEC T BALL JOINTS AND STEERING LINKAGE EXCESIVE PLAY AND REPLACE ALL BALL JOINTS ,DRAG LINK AND 2 TIE ROD ENDS 3049AT-26 3130AC-10 3001A-04 3001A6-0 4
10/05/2005
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 10654C1 42 DOES NOT OPERATE PROPERLY
000 10654C
DIAG ENG HARD TO START TEST BATTERY LOAD TEST NO GOOD. REPLACED BATTERY AND CHECK CHARGIN SYSTE, SYSTEM OK. BATTERY DTC 0AJSWJ3J0306 ACES: XE0BU. LABOR- 10654CB: .4 10654C1: .2
10/05/2005
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 12651D4 42 DOES NOT OPERATE PROPERLY
000 12650DX1
000 12651D2
000 12651D
12651D 0.2 12651D 2 0.3 12651D4 0.1 12651DX1 0.1
END OF OASIS REPORT FOR 1FTNW21F53EA50838
