i own a 2005 f350 built 8/04 the engine says it is 2005 on the valve cover. my vin is 1ftww31p35ea58488 .also how can tell what series/revision of head bolts/gaskets are on my truck. my truck has 46000 miles on it after reading some postings on line i am little scared of my 6.0 coming apart . if there any signs to watch for please let me know. my truck is all stock except for airraid intake.
OASIS RESULT:
1FTWW31P35EA58488
11/01/2006
16:39:00
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/02/2004 BUILD DATE
08/23/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0778 - USA 2004 NEW 60/75,000 BASECARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: JOHN SIMON
OPTIONS: $100,DED.
EXPIRATION DATE: 09/02/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 03010
ESP CONTRACT START DATE: 09/02/2004
REPAIR HISTORY
05/31/2006
DEALER: Signature Ford Lincoln-Mercury
WARRANTY CLAIM NUMBER: 113077 ODOMETER: 040460M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z26611B69AAC S/BELT R/SEAT RETRAC 001 61168A 42 DOES NOT OPERATE PROPERLY
40470 BN 6611B69 CC 42 CHECK CONCERN R&R REPLACED LEFT REAR SEAT BELT RETRAC TER ASSM, VERIFY REPAIR TECH 173
05/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
40470 PERFORMED RECALL 05E15 REPLACED EBP & REPROGRAM MODULES TECH 173
05/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
40470 PERFORMED RECALL 59B01 ROAD TEST TECH 173
05/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
40470 PERFORMED RECALL 05B32 INSTALL LABLE & ADJUST COOLANT TECH 173
01/23/2006
WARRANTY CLAIM NUMBER: 110874 ODOMETER: 031620M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 10849GD CLUSTER ASY-INST PNL 001 12650D 42 DOES NOT OPERATE PROPERLY
5C3Z 11654FAA SWITCH ASY LT CNTRL 001 10838A
000 12650D45
000 12650DX1
31620 42 BN 11654 W INSPT . WDS TEST PID MONITOR 4X4 INPUT TO HEC REMOVE CL USTER AND PIN TEST. RENEW CLUSTER RENEW HEAD LAMP SWITCH. BEZEL CRACKED RE TEST ROAD TEST
01/16/2006
WARRANTY CLAIM NUMBER: 110740 ODOMETER: 031560M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 10849GD CLUSTER ASY-INST PNL 001 12650D 41 STICKS/BINDS/GRABS
000 12650D81
000 12650DX1
000 10838A
31560 41 BN 10849 INSPT WDS TEST PID MONITOR ROAD TEST RECORD RENEW SPEEDO C LUSTER. RETEST. ROAD TEST
01/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 001 69000A 12 IMPROPER ASSEMBLY
3820124 DOOR ASY-FRONT 000 20124A
31580 12 BN20124 INSPT. ROAD TEST WITH SONIC EARS. NO AIR LEAK INTO CABIN . BUT HAS WIND NOISE FROM O-S MIRROW AREA. REMOVE RIGHT O-S MIRROW, WINDOW C HANAL RUN. REPAIR DOOR FRAM SO MIRROW FITS CLOSE TO DOOR AND SEALS TO DOOR. REASSEMBLE AND SILICONE RUN CHANAL AND MIRROW SEALING SURFACE RETEST.
01/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
RECALEM ECC PROCESSOR RECAL 000 6005F 04 SOFTWARE REVISION/FLASH MODULE
000 6005F1
000 6005F2
000 6005F33
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 12650D84
000 6005F1X1
31580 O4 BN 12A650 INSPT ROAD TEST. PERFORM 6.0L DIESEL DIAD AND PERFORMANC E TESTS. ENGINE AND CHASSIS INSPT,OK INSPT FUELCONDITION, OK, ENGINE OIL F ULL,KOEO, KOEO INJECTOR AND CONTINOUS PASS CODE, INTAKE RESTRICTION .3,EGR .7 CLOSED4.26 OPEN, TRAVAL OK ,EXHAUST RESTRITION 15, ELECT FUEL PUMP PRES SURE 52, INLET RESTRICTION 2.6 FUEL AEROTION PASS. KOER PASS, ICP 783, IPR 1
01/06/2006
WARRANTY CLAIM NUMBER: 110582 ODOMETER: 031554M
LABOR OP
CONDITION CODE
CONDITION DESC
17682 MIRROR ASSY RR O/S 000 69000A 12 IMPROPER ASSEMBLY
000 23943A
31567 CC 12 BN 17682 INSPT. ROAD TEST AND DIAG FOR WINDNOISE SONIC EAR TEST . REMOVE RIGHT FRONT DOOR PAD REMOVE O-S MIRROW. . REINSTALL MIRROR LEVEL WITH DOOR PILLAR AND BACK SEAL MOUNT. RETEST
01/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 10849GD CLUSTER ASY-INST PNL 001 12650D 01 BROKEN/CRACKED
000 12650D81
000 10838A
000 12650D45
000 12650DX1
31567 O1 BN 10849 INSPT WDS TEST HEC . PID MONITOR. REMOVE HEAD LAMP SWITCH ,RADIO,HEATER CONTROL, LOWER STEERING COLOUM FOR ACCESS REMOVE CLUSTER. PI N TEST. RENEW CLUSTER RETEST
01/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3020DA BUMPER FRT SUSP 002 MT3A131 30 CHAFED,EXCESSIVE WEAR,FRAYED
N802455S426 002
5C3Z 3A089BA BRKT FRT AX BMPR TO 002
6C3Z 3A131D KIT SPINDLE CON ROD 001
6C3Z 3304B ROD ASY-STR ARM TO I 001
31567 CC 30 BN 3304 INSPT ROAD TEST. HAS BANG WHILE DRIVING AND CLUNK TURNI NG. PERFORM DIAG RENEW FRONT JOUNCE STOPS WITH NEW DESIGN. RENEW DRAG LINK AND RIGHT TIE ROD END. PERFORM FRONT ALIGNMENT AND RETEST
END OF OASIS REPORT FOR 1FTWW31P35EA58488
