VIN# 1FDWW37P55EB71801
Thank You:Thumbup:
OASIS RESULT:
1FDWW37P55EB71801
11/09/2006
21:10:46
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CHASSIS CC 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
5F710D0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/31/2004 BUILD DATE
12/13/2004 SALE MILEAGE
00012
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
07/25/2006
DEALER: Gillie Hyde Ford-Lincoln-Mercu
WARRANTY CLAIM NUMBER: 151985 ODOMETER: 052182M
LABOR OP
CONDITION CODE
CONDITION DESC
F4TZ 9030C CAP ASY FUEL TANK 001 6005E 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 6005E2
XO 15W405QSD 003 6005E3
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005E6
VC 7B 003 6005F
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 9527AT
000 6051A11
000 MT6051
000 12650D30
000 12650D47
RECALIBRATION PERFORM DIESEL NO START DIAGNOSIS; FOUND MULTIPLE CYLINDERS MISSING; PINPOINT TEST FOUND INJECTOR FAILURE; RELATIVE COMPRESSION TEST AN D COMPRESSION TEST FOUND CYLIDERS 7,3,AND 4 AT FAULT; REPLACE INJECTORS AND RETEST- OK AT THIS TIME.
07/25/2006
LABOR OP
CONDITION CODE
CONDITION DESC
VC 7B 002 8005D 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AC COOLER - EGR 001 9456A
VC 7B 002
XO 15W405QSD 003
PERFORM COOLING SYSTEM DIAGNOSIS; FOUND EGR COOLER LEAKING COOLANT; REPLACE COOLER AND RETEST- OK AT THIS TIME.
03/15/2006
WARRANTY CLAIM NUMBER: 147294 ODOMETER: 042135M
LABOR OP
CONDITION CODE
CONDITION DESC
MISC FOR REPAIRS NOT COVE 000 82 FREIGHT/POSTAGE/MAINTENANCE
CUSTOMER HAD PREVIOUS CONCERNS WITH THIS VEH ASKING FOR WAIVER OF DED
02/28/2006
WARRANTY CLAIM NUMBER: 146665 ODOMETER: 042135M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005E 42 DOES NOT OPERATE PROPERLY
5C3Z 9C854A BLK-FUL DSTR 001 6005E2
W301727 OIL PUMP FITTING 001 6005E3
3C3Z 9N693DA RING-SEALING 001 6005E4
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001 6005F
3C3Z 9E933BA GSKT-EGR TO-TH-BDY 001 6005F1X1
3C3Z 9J469AA SEAL EGR TUBE 001 6005F2
W302053 001 6005F6
5C3Z 9C968CA FUEL PRESSURE REG 001 9527AT
XO 15W40QSD 004 MT9C854
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 MT9N693
XO 15W40QSD 001 9968B
VC 7B 002
PERFORM NO START DIAGNOSIS; CODES FOR NO ICP; FOUND LEAK FROM MIDDLE OF ENGI NE; DISASSEMBLE FOUND O-RING BLOWN AT QUICK CONNECT ADAPTOR; REPLACE ADAPTOR AND BLOCK ASSEMBLY; RETEST- FOUND MISSING ON CYLINDERS 1,3,5,7,4,6; RELATIV E COMPRESSION TEST FOUND INTERNAL INJECTOR FAULTS. REPLACE AND REASSEMBLE; R ETEST- OK AT THIS TIME.
01/16/2006
WARRANTY CLAIM NUMBER: 145075 ODOMETER: 037265M
LABOR OP
CONDITION CODE
CONDITION DESC
F6DZ 8100A CAP ASY RADIATOR 001 9456A 01 BROKEN/CRACKED
VC 7A 002 6642A
6C3Z 8005DA RADIATOR ASY 001 12650D
VC 7A 002 12650D45
3C3Z 6731AA ELEMENT ASY OIL FILT 001 12650D30
XO 15W405QSD 003 8005A
3C3Z 6766BA CAP ASY OIL FILLER 001 8100A
VC 7B 001
XO 15W40QSD 001
3C3Z 6A642AA COOLER CRANKCASE OI 001
3C3Z 8287CB CLAMP ASY-RAD HOSE 001
PERFORM COOLING SYSTEM DIAGNOSIS; LOW LEVEL; FOUND LEAK AT LOWER RADIATOR TA NK AND COOLANT RUNNING OUT EXHAUST; CHECK AND FOUND EGR COOLER LEAKING; CONT ACT HOTLINE; ADVISED REPLACEDMENT OF OIL COOLER ALSO; REPLACE ALL; CHANGE EN GINE OIL AND FILTER AND REFILL WITH COOLANT; REASSEMBLE AND RETEST- OK AT TH IS TIME.
01/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
PERFORM RECALL PER INSTRUCTIONS; REPLACE EBP SENSOR AND REFLASH
01/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
TEST DRIVE- OK AT THIS TIME.
01/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
PERFORM RECALL PER INSTRUCTIONS; INSTALL LABEL
END OF OASIS REPORT FOR 1FDWW37P55EB71801
:Thumbup: Thank you
