Good Morning,
OASIS RESULT:
1FTSW31P54EC01969
12/13/2006
08:16:50
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/20/2004 BUILD DATE
01/06/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
10/25/2006
DEALER: Mack Grubbs Ford-Mercury, Inc.
WARRANTY CLAIM NUMBER: 021579 ODOMETER: 059277M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001
VC 7B 002
XO 15W40QSD 004
REPLACED EGR COOLER
09/18/2006
WARRANTY CLAIM NUMBER: 021011 ODOMETER: 057328M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6C751AA KIT-VLV OIL PRESS RE 001 6005F 42 DOES NOT OPERATE PROPERLY
OSP 002 6600A
REPLACED RELIEF VALVE ASSY
07/13/2006
DEALER: Pine Belt Ford
WARRANTY CLAIM NUMBER: 011462 ODOMETER: 052827M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D30 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1
000 6005F1X1
000 6005F12
000 6005F18
RUN DIASG TEST FUEL PRESS TEST BOOST FOUND EGR STICKING AT TIMES REPLACE EGR E
04/17/2006
WARRANTY CLAIM NUMBER: 018501 ODOMETER: 047668M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AC COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
000 8005D
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 3 2A01 031202 4C3Z 6C646 AA N12 42 4180
AWS Claim Key: 871490 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:007472A
Cust Comments: CHECK FOR ROARING NOISE UNDER HOOD TURBO HOSE HERE
Tech Comments: REPLACE TUBE
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 3 7T09 191001 * 14B205 * A85 42 4180
AWS Claim Key: 999859 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:007472B
Cust Comments: CUSTOMER STATES 4X4 LITE STAYING ON
Tech Comments: REPAIR CONNECOTR
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 4 2E06 030008 4C3Z 9E527 AA D21 42 6168
AWS Claim Key: 1081606 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2004 Doc #:007991A
Cust Comments: RUNNING BAD, VIBRATES WHEN TAKING OFF
Tech Comments: REPLACE INJECTOR
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 13 1H03 030008 3C3Z 9F452 AC D21 42 22123
AWS Claim Key: 4060500 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2005 Doc #:012090A
Cust Comments: CK FOR LACK OF POWER AT TIMES
Tech Comments: REPLACE EGR AND ACTUATOR
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 19 2H01 * * * * * * 30349
AWS Claim Key: 6487415 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07568 - * Name: PINE BELT FORD Ph: 601-7948543 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:00871401
Cust Comments: RECALL 05B29 CHARGE AIR COOLER DUCT
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 19 * * * * * * * 30349
AWS Claim Key: 6487416 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07568 - * Name: PINE BELT FORD Ph: 601-7948543 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:00871402
Cust Comments: RECALL 05S34 INJ CONTROL MODULE
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 21 * * * * * * * 35694
AWS Claim Key: 7579546 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07568 - * Name: PINE BELT FORD Ph: 601-7948543 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:00919501
Cust Comments: RECAL 05E15
AWS Claim Key: 7579547 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07568 - * Name: PINE BELT FORD Ph: 601-7948543 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:00919502
Cust Comments: RECAL 59B01A
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 27 1H03 030008 4C3Z 9P456 AC F99 42 47668
AWS Claim Key: 9208228 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2006 Doc #:018501A
Cust Comments: CHECK FOR LEAKING COOLANT
Tech Comments: REPLACE EGR COOLER
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 30 1H03 030008 4C3Z 9F452 A D42 42 52827
AWS Claim Key: 9821994 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 07568 - * Name: PINE BELT FORD Ph: 601-7948543 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2006 Doc #:01146201
Cust Comments: C/S TRUCK SHUTTERS WHEN DRIVING
Tech Comments: RUN DIASG TEST FUEL PRESS TEST BOOST FOUND EGR STICKING AT TIMES REPLACE EGRE
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 32 2E06 030008 3C3Z 6C751 AA L65 42 57328
AWS Claim Key: 10353325 Trx Code: E72 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2006 Doc #:021011A
Cust Comments: CHECK FOR OIL LEAK
Tech Comments: REPLACED RELIEF VALVE ASSY
1FTSW31P54EC01969 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-JAN-2004 20-FEB-2004 123358 USA 33 1H03 030804 4C3Z 9P456 AF D50 42 59277
AWS Claim Key: 10658222 Trx Code: E72 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2006 Doc #:021579A
Cust Comments: CUSTOMER STATES ENGINE LOCKED UP AND WILL NOT TURN OVER
Tech Comments: REPLACED EGR COOLER
Thanks,
Vivian
Thank you for the report. I appreciate it.
Now, do any of you think there's anything in this report that I should be concerned about? The truck does have a small oil leak at the rear of the engine. It also takes longer to crank than my '97 7.3L Powerstroke (about 2 seconds vs 1 second on the older Powerstroke).
Thanks again,
James
