Standard Claims List For Model Year 2003
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 0 2E01 * * * * * * 450
AWS Claim Key: 1727514 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2003 Doc #:23938101
Cust Comments: A99 03B05 INJECTION CONTROL PRESSURE(ICP) SENSOR REPLACEMENT
Tech Comments: INSTALLED ICP SENSOR PER RECALL
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 0 2G05 * * * * * * 450
AWS Claim Key: 1727513 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2003 Doc #:23938102
Cust Comments: A99 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: 1 REPROGRAMMED PCM TCM FICM PER RECALL
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 3 6X04 010904 3C3Z 17D743 CAA M10 33 4485
AWS Claim Key: 3309007 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:25510201
Cust Comments: CUSTOMER STATES MIRROR CAP IS LOOSE
Tech Comments: 1 SECURITY TAB IS LOOSE AND CRACKED, REPLACED CAP AND RETEST OK,
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 15 2H01 031202 3C3Z 6K769 DA D50 33 29566
AWS Claim Key: 8180557 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:31752102
Cust Comments: CUSTOMER STATES TURBO HOSE KEEPS COMING OFF RETIGHTENED 3 TIMES
Tech Comments: FOUND HOT SIDE TURBO PIPE BLOWING OFF.REPLACED PIPE AND TEST DROVE OK.CC 42 QUALITY CHECKED BY 9047
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 15 2H01 031202 YC3Z 6C640 KA D13 42 29566
AWS Claim Key: 8180556 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:31752103
Cust Comments: CUSTOMER STATES IDLE FLUCTUATES BETWEEN 800 1200 BACK AND FORTH
Tech Comments: PERFORMED DIESEL DIAGNOSIS,NO CODES.REPROGRAMMED PCM TEST DROVE OK.CC 42 QUALITY CHECKED BY 9047
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 15 * * * * * * * 29566
AWS Claim Key: 8252410 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:31752105
Cust Comments: RECALL 04S12 NEGATIVE BATTERY CABLE
Tech Comments: PERFORMED RECALL 04S12,INSTALLED BOLT QUALITY CHECKED BY TECH 9047
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 28 2E06 030008 3C3Z 9E527 AE D41 42 69495
AWS Claim Key: 12623230 Trx Code: E72 Labor Hrs: 8.5
Dlr Cd-Sub Cd: 07282 - * Name: CHASTANG'S BAYOU CITY FORD Ph: 713-6785000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-NOV-2005 Doc #:103156A
Cust Comments: CUST STATES ENGINE SURGING AT IDLE AND CHECK ENGINE LIGHT IS ON. ALSO MISSES BAD WHEN COLD.
Tech Comments: 69495 RUN TEST 1 16 PERFORMANCE.VERIFIE60.PERFORM PIN POINT TEST.CODES FOR WATER IN FUEL,ICP,#7 CYLINDER BALANCE.CHECK FOR WATER IN FUEL,OK. REPLACE FUEL MODULE,SENSOR BAD.REPLACE ICP SENSOR ON BACK OF MOTOR.REPROGRAM MODULES TO LATEST CALIBRACTION AVALABLE.SSM17032.PERFORM DATALOGGER TEST.PULL RIGHT VALVE COVER TO REPLA CE #7 INJECTOR.CLEAR CODES,RETESTED.P1000. STEAM CLEAN
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 34 2E06 030008 3C3Z 9E527 AE D42 42 88170
AWS Claim Key: 13886468 Trx Code: E72 Labor Hrs: 7.7
Dlr Cd-Sub Cd: 07282 - * Name: CHASTANG'S BAYOU CITY FORD Ph: 713-6785000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:106103B
Cust Comments: CHECK FOR LOW POWER AND ROUGH RUNNING IN THE A.M.
Tech Comments: 88170 RUN TEST ON ENGINE WHEN COLD IN AM.VERIFIE60. ENGINE HAS A LITTLE MISS,ENGINE HAS LOW POWER. RUN TEST 1 16 PERFORMANCE.ENGINE HAS 15 PSI BOOST,#4 CYLINDER BALANCE,TURBO BOOST CODES. P0299,P2263,P0272.PERFORM DATALOGGER TEST, RELATIVE COMPRESION,INJECTOR INHANCED TEST. VGT VALVE AT 85%.PERFORM PINPOINT TEST KA. VEINS MOVE,VGT VALVE WILL ONLY MOVE TO 65% ON DATALOGGER
1FTNW21P13EC06575 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-FEB-2003 16-AUG-2003 152032 USA 34 * * * * * * * 88170
AWS Claim Key: 13886469 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07282 - * Name: CHASTANG'S BAYOU CITY FORD Ph: 713-6785000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:106103D
Cust Comments: RECALL 59B01 ASSURANCE TEST DRIVE
Tech Comments: PERFORM ROAD TEST
AWS Claim Key: 13886470 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07282 - * Name: CHASTANG'S BAYOU CITY FORD Ph: 713-6785000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:106103E
Cust Comments: RECALL 06E17 MODULE RECALIBRATION
Tech Comments: 88170 REPROGRAM MODULES AS PER RECALL.
