Could I get an OASIS report on VIN 1FTWW31P85EC40204?
It should have grown a few pages since last time....
OASIS RESULT:
1FTWW31P85EC40204
05/20/2007
23:09:56
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/21/2005 BUILD DATE
02/20/2005 SALE MILEAGE
00027
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
05/03/2007
DEALER: Jim Fugate Ford, Inc.
WARRANTY CLAIM NUMBER: 137103 ODOMETER: 021001M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 MT062102 42 DOES NOT OPERATE PROPERLY
VC 7B 002
6051 GASKET CYL HEAD 000
21001 CONFIRMED CONCERN OF COOLANT BOTTLE OVERFLOW UNDER HARD ACCEL. PREFOR MED TSB 06-21-02 FOR THIS CONCERN. WHEN CHECKING EGR COOLER FOUND COOLER LE AKIG INTERNALLY. REMOVED INTAKE AND INSTALLED NEW EGR COOLER. ALSO CLEANED INTAKE AND IAT 2 SENSOR. REINSTALLED PARTS AND FOUND NO CONCERN PRESENT ON RETEST AT THIS TIME. MAY SMELL OIL SMELL FROM CLEAQNER AND PENATRANTE USED O
05/03/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K682A TURBO CHG-EXH DRIVE 001 1007D 07 IMPROPERLY ADJUSTED/FITS POORLY
21001 CONFIRMED NOISE CONCERN. PREFORMED NVH DIAG AND FOUND TURBO TURBINE HI TTING TURBO HOUSING. REMOVED AND INSPECTED TURBO FOUND SIGNS OF CONTACT. I NSTALLED NEW TURBO AND RETESTED. FOUND NO CONCERN PRESENT WHEN RETEST. INST ALLED NEW TURBO WHEN ENGINE WAS APART FOR LINE C DID NVH DIAG AND INSTAL L ON THIS LINE
02/27/2007
DEALER: Parr Ford, Inc.
WARRANTY CLAIM NUMBER: 178161 ODOMETER: 018825M
LABOR OP
CONDITION CODE
CONDITION DESC
6F089 ACTUATOR ASSY 000 062302B 42 DOES NOT OPERATE PROPERLY
OSP 001
3C3Z 9A564A TUBE ASSY-FUEL RET 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
W302676 001
W302677 001
PM 2 MOTORCRAFT BATTERY 001
W302725 001
CODE TEST TO FIND P0299 P0401 AND P0404 FOLLOW TSB 06-23-02 AND CLEAN TUR BO TO REPAIR CODE P0299 FOLLOW TSB 06-19-06 AND CLEAN EGR VALVE TO REPAIR CO DE P00401 AND FOLLOW TSB 07-05-04 FOR COLD MISS R-TEST ALL OK CUST SAYS TRUC K STILLBUCKS WHEN COLD R-TESTED 3-5-07 WAS UNABLE TO VERIFY BUCK WHEN COLD O N FREEWAY UNDER LIGHT THROTTLE WOULD REQ CUST R-TEST TO VERIFY
02/27/2007
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2521452AA F/DR WDO W/S 001 21452A 12 IMPROPER ASSEMBLY
000 17682C
INSPECT OUTER DOOR TRIM ATT BOTTOM OF GLASS DOESNT FIT PROPERLY REMOVE OUTSI DE MIRROR AND INSTALL WEATHERSTRIP ALL OK
02/27/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 3B396AA LOCKING HUB ASSEMBLY 001 1007D 42 DOES NOT OPERATE PROPERLY
7C3Z 1104B HUB ASSY-FRONT 002 2134ADT
5C3Z 3254AA OIL SEAL-FRONT AXLE 002 MT3B396
USE M-TIME TO R-TEST TRUCK AND TO ISOLATE NOISE TO FRONT OF TRUCK COMPARED T O LIKE TRUCK FROM USED CAR LOT CUST TRUCK HAS NOISE IN FRONT END RUN OASIS N O HELP RUN ON HOIST UNABLE TO HEAR NOISE USED D STETHOSCOPE TO NARROW DOWN T O WHEEL BRGS AND KNUCKLES SEALS ALSO ONE 4X4 HUB WILL NOT DISENGAGE PROPERLY REMOVE BOTH WHEEL BRGS AND FRONT DRIVE AXLES AND INSTALL NEW SEALS AND WHEE
02/27/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9F452 TRANSDCR-EGR BACK PR 000 061906A 55 PLUGGED/RESTRICTED
3C3Z 9P455AB SE E/G/R VLV 001
PM 3 001
PERFORMED TSB 06-19-06
02/27/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
PERFORMED TSB 07-05-04
END OF OASIS REPORT FOR 1FTWW31P85EC40204
