OASIS RESULT:
1FMSU45P64ED18137
05/23/2007
21:31:21
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
4L11ON0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/28/2005 BUILD DATE
04/08/2004 SALE MILEAGE
00236
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/04/2007
DEALER: Visteon Aftermarket - U.S.
WARRANTY CLAIM NUMBER: 046603 ODOMETER: 031885M
LABOR OP
CONDITION CODE
CONDITION DESC
6C7T 18C815AA RECEIVER-ELECT CMPCT 000 42 DOES NOT OPERATE PROPERLY
VI11 001
REQUESTING DEALER'S P/A CODE 04886
04/02/2007
DEALER: Garber Ford-Mercury, Inc.
WARRANTY CLAIM NUMBER: 137629 ODOMETER: 031885M
LABOR OP
CONDITION CODE
CONDITION DESC
XO 15W40BSD 001 6007D 42 DOES NOT OPERATE PROPERLY
OSP 001 6584AR
6007 ENGINE ASSY 000
31885 OIL DIAG OIL LEAK, FOUND LEAKING FROOM RIGHT HAND VALVE COVER GASKET, R&R VALVE COVER INSPECT GASKET, CLEAN GASKET AND VALVE COVER NO DEFECTS IN GASKET FOUND REASSEMBLE AND SECURE COVER, RETEST FOR LEAKS OK
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
1C3Z 17603AA JET/BRKT W/S WASHER 001 999A 42 DOES NOT OPERATE PROPERLY
31885 WASHER JET REPLACE DRIVER SIDE WINDSHIELD WASHER JET NO WORKING PROPE RLY RE TESTED OK
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 1125DA DISC - FRONT WHEEL B 002 2001BF 13 OUT OF ROUND
000 2001B5FT
31885 ROTORS PERFORM ROAD TEST TO VERIFY CUSTOMER CONCERN FOUND BAD ROTORS S PECS ARE 36.0 MINIMUM THICKNEES ROTORS ARE NOW IS 3.9 MM REPLACE FRONT ROT ORS RE TESTED OK
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F13
000 6005F18
000 6005F20
000 6005F45
000 070504A
31885 REVS AND LUNGES AT IDLE DIESEL PERFORMANCE DIAG, KOEO PASS, KOER PASS , INJECTOR SELF TEST PASS, TEST ICP OK, TEST FUEL FOR CONTAMINATION OK, TE ST FUEL PRESSURE 55LBS, TEST EGR SYSTEM OK, PERFORM DCL DISPLAY WITH RECORDE R MONITOR, UNABLE TO DUPLICATE CONCERN, REPROGRAM MODULES WITH LATEST LEVEL CALIBRATION
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
7866801 CVR REAR SEAT BACK 000 OSL 42 DOES NOT OPERATE PROPERLY
SUBLET REAPIR
04/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
18806 CHASSIS RADIO 000 MT062107 42 DOES NOT OPERATE PROPERLY
000 18805B
000 18805C
31885 #2 BUTTON STICKS GET RAZDIO INFO AND FILL OUT FORMS TO ORDER RADIO. S OP RADIO
02/12/2007
WARRANTY CLAIM NUMBER: 136441 ODOMETER: 029269M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P455AB SE E/G/R VLV 001 062302B 42 DOES NOT OPERATE PROPERLY
PM 3 001 061906A
PM 6 001
PM 2 MOTORCRAFT BATTERY 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
9F452 TRANSDCR-EGR BACK PR 000
29269 CHECK ENGINE LIGHT ON DIESEL PERFORMANCE DIAG, P0401 P0404 P0299 PERF ORM TSBS, 06-19-06 AND TSB 06-23-02 AND RETEST OK
10/20/2006
WARRANTY CLAIM NUMBER: 133673 ODOMETER: 023458M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2A451A PUMP ASY-BRAKE VACUU 001 6005F1 69 FROZEN/SEIZED/BINDING
4C3Z 9F838A SENSR ASY F/I TIMING 001 6005F
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 9424A
000 9838A
000 12650D30
23458 LOSSES POWER RUNS ROUGH INTER DIESEL PERFORMANCE DIAG, KOEO PASS, KOE R PASS INJECTOR SELF TEST PASS, TEST ICP OK, TEST BOOS T PRESSURE 23LBS, TE ST INLETA ND EXHAUST FOR RE STRICTIONS OK, TEST FUEL PRESSURE OK, TEST FUEL FOR CONTAMINATION OK, TEST EGR PSOITION OK, TES T IPR OK, ROAD TEST WHILE MONITORING PIDS, AFTE R MULTIPLE ROAD TEST VEHICLE RUNNNING ROUGH AT IDLE
10/20/2006
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 18A318AA MOTOR ASY-VACUUM CTR 001 19700A 69 FROZEN/SEIZED/BINDING
F81Z 18A318BA MOTOR ASY-VACUUM CTR 001 19700D1
000 04320B
000 19616A
000 19616B
000 2451A
23458 AC BLOWS OUT DEFROST ON PANEL SETTINGS AC DIAG, REPLACE VACUUM MOTORS TO FLOOR AND VEN T DOORS RETEST OK
10/20/2006
LABOR OP
CONDITION CODE
CONDITION DESC
78613B85 BELT ASY RR ST COMP 000 OSL 42 DOES NOT OPERATE PROPERLY
SUBLET TO HAVE REPEAIR ON VELCRO FASTENER
10/20/2006
LABOR OP
CONDITION CODE
CONDITION DESC
7823942 PNL ASY-FT DR TRIM 000 OSL 42 DOES NOT OPERATE PROPERLY
NEC TO SUBLET TO HAVE POST COVER ON PASSENGER SIDE REPAIRED
10/20/2006
LABOR OP
CONDITION CODE
CONDITION DESC
1102 HUB & ROTOR ASY FRON 000 2001B2PT 14 SURFACE ROUGH/UNEVEN
23458 PULSATION ROAD TEST TO VERIFY CUSTOMER CONCERN R-R FRONT ROTORS BEFOR E 37.8 MM RE SURFACE FRONT ROTORS AFTER 37.2 MM RE TESTED OK
10/09/2006
WARRANTY CLAIM NUMBER: 133337 ODOMETER: 022832M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 6005F1X1
000 9527AT
22832 ENGINE REVS AND LUNGES DIESEL PERFORMANCE DIAG, KOEO PASS, KOER PASS, INJECTOR SELF TEST PASS, TEST ICP OK, TEST FUEL FOR CONTAMINATION OK, TES T FUELPRESSURE 50LBS, TEST EGR POSITION OK, TEST BOOST PRESSURE 22LBS TEST INLET AND EXHAUST FOR RESTRICTION NONE FOU ND, TEST OIL AND FUEL FOR AERATI ON NONE FOUND, TEST IPR OK, ROAD TEST WHILE MONITORING PIDS AN D POWER BALA
06/14/2006
WARRANTY CLAIM NUMBER: 130326 ODOMETER: 018703M
LABOR OP
CONDITION CODE
CONDITION DESC
3C7Z 7831012AAA TRIM ASY-QTR 001 31012AR 34 DISTORTED/WRINKLED/WAVY
18703 RIGHT REAR PANEL CLIPS BAD AND PANEL WARPED REPLACED PANEL REMOVED REA R SEAT AND CENTER AND REAR PILLAR TRIM IN ORDER TO REMOVE BOTTOM PANEL ALS O REMOVED 2 RIGHT SIDE CENTER AND REAR SEATBELTS ALSO REMOVED REAR HATCH WE ATHER STRIP REMOVED BAD PANEL AND REPLACED AND REPLACED ALL OF ABOVE
06/12/2006
WARRANTY CLAIM NUMBER: 130234 ODOMETER: 018617M
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 13201AA LAMP ASY PARKING 001 999A 46 BURNED OUT
18617 LAMP REPLACE DRIVER SIDE DIRECTIONAL PARKING LIGHT LENS NOT FLUSH RE TESTED OK
06/12/2006
LABOR OP
CONDITION CODE
CONDITION DESC
2C026 ROTOR-RR WHL DISC BK 000 2001B3PT 14 SURFACE ROUGH/UNEVEN
18617 VIBRATION RE SURFACE REAR ROTORS LEFT REAR BEFORE 30.00MM AFTER 29.6 MM RIGHT REAR BEFORE 30.MM AFTER 29.5MM RE TESTED OK
END OF OASIS REPORT FOR 1FMSU45P64ED18137
