I hate having one post, asking for something, sorry.
I need a report for 1FTNW21P13ED61157
Thanks!
Standard Claims List For Model Year 2003
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 6 1D01 030008 3C3Z 6701 AA L65 D8 8987
AWS Claim Key: 4925578 Trx Code: 2 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 01622 - * Name: RIO VISTA FORD, INC. Ph: 707-3746411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2004 Doc #:0092961
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 6 * * * * * * * 8987
AWS Claim Key: 4925579 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01622 - * Name: RIO VISTA FORD, INC. Ph: 707-3746411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2004 Doc #:0092962
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 17 1D01 03XXXX 3C3Z 6701 AA L65 D8 22541
AWS Claim Key: 9502735 Trx Code: E84 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 01622 - * Name: RIO VISTA FORD, INC. Ph: 707-3746411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2005 Doc #:032411A
Cust Comments: CUSTOMER STATES CAR HAS OIL LEAKS
Tech Comments: REPLACE REAR MAIN SEAL
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 21 2H01 030008 3C3Z 6K682 AARM D42 42 27511
AWS Claim Key: 10884366 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 01622 - * Name: RIO VISTA FORD, INC. Ph: 707-3746411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2005 Doc #:033684A
Cust Comments: CUSTOMER STATES AROUND 55 65MPH, ENGINE FEELS LIKE IT IS SURGING
Tech Comments: VERIFIED CONCERN ON LINE A C, ALL CONCERNS ARE RELATED. PERFORM WDS QUICK TEST. HAS DTCS P023 8 AND P2263. PERFOR DIESEL DIAG SHEET, FOUND BA ISED EBP SENSOR KOEO 15.4 PSI. REPLACE EBP SENS OR. INSTALL NEW EBP SENSOR. CHECKED EGR VALVE F OR OPERATION, FOUND STICKING. NOT OPENING FULLY AND GASKET IS LEAKING. RECOMMEND NEW EGR VALVE AND GASKET. INSTALL NEW EGR VALVE. CHECKED TUR
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 21 1G01 030008 3C3Z 8592 AB L87 D8 27511
AWS Claim Key: 10884367 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01622 - * Name: RIO VISTA FORD, INC. Ph: 707-3746411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2005 Doc #:033684D
Cust Comments: CUSTOMER STATES RADIATOR CAP IS LEAKING, CHECK AND ADVISE
Tech Comments: VERIFY CONCERN ON LINE D. PERFORM COOLING SYSTE M PRESSURE TEST ANDCAP FAILED LEAK TEST. DEGAS BOTTLE IS LEAKING. ALSO FOUND BY PASS TUBE O RI NG LEAKING. REPLACE ALL PARTS PER LIST. FULL AN D BLEED COOLANT TO MIN. LEVEL TO PREVENT OVERFL OW. ROAD TESTED VEHICLE, OK AT THIS TIME.
1FTNW21P13ED61157 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-JUN-2003 22-SEP-2003 172504 USA 44 * * * * * * * 57295
AWS Claim Key: 15099605 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07818 - * Name: JAMES FORD INC Ph: 650-7264496 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2007 Doc #:073242A
Cust Comments: RECALL 06E17 RE CALIBRATE PCM
Tech Comments: PERFORMED RECALL 06E17 RECALIBRATE PCM, TCM AND FICM.
AWS Claim Key: 15099606 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07818 - * Name: JAMES FORD INC Ph: 650-7264496 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2007 Doc #:073242B
Cust Comments: RECALL 59B01 ROAD TEST
Tech Comments: PERFORMED RECALL 59B01 ROAD TEST OK.
