Well, my first choice of truck sold before I could get to it so another request for a report please. VIN: 1FTWW32F91ED40182
Standard Claims List For Model Year 2001
1FTWW32F91ED40182 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 25-MAY-2001 26-JUN-2001 121524 USA 0 6C04 010505 * 1623942 * L29 33 19
AWS Claim Key: 2121607 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00469 - * Name: BONDY'S FORD, INC. Ph: 334-7925171 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2001 Doc #:09358851
Cust Comments: CK RIGHT DOOR LIGHT IS INOP
Tech Comments: INOP TRIM PANEL FRONT DOOR REMOVE AND INSTALL
1FTWW32F91ED40182 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 25-MAY-2001 26-JUN-2001 121524 USA 3 * * * * * * * 6292
AWS Claim Key: 3983624 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00469 - * Name: BONDY'S FORD, INC. Ph: 334-7925171 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2001 Doc #:09923440
Cust Comments: 01S21 SEAT BELT BUCKLE
Tech Comments: RECALL 01S21A .1
1FTWW32F91ED40182 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 25-MAY-2001 26-JUN-2001 121524 USA 12 2B01 030701 F7TZ 12K073 A D02 28 19234
AWS Claim Key: 9251576 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-JUN-2002 Doc #:16053501
Cust Comments: CUSTOMER STATES STALLED TWICE,NOW TURNS OVER BUT WILL NOT START,TOWED IN
Tech Comments: OPEN CIRCUIT NO START DIAG, PINPOINT TEST, REPLACE CMP SENSOR, RETEST, TEST DRIVE
1FTWW32F91ED40182 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 25-MAY-2001 26-JUN-2001 121524 USA 54 2E06 030402 * 9A543 * L65 D8 51781
AWS Claim Key: 20624514 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04887 - * Name: HENRY ARNOLD FORD CO INC Ph: 850-2633271 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2005 Doc #:00278601
Cust Comments: ENGINE LEAKING OIL
Tech Comments: CHECK OIL LEAK,RUN OASIS,FOUND TSB #04 04 04, PERFORM TSB,REPLACE KITS FOR HIGH PRESSURE PUMP SEAL KIT,FUEL TUBE,RETURN LINE,HIGH PRESSURE PUMP GASKET, CLEAN ENGINE,RECHECK,TEST DRIVE,CHECK FOR OIL LEAK, RELEASE
