Standard Claims List For Model Year 2001
1FTSW31F41EA02446 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 03-AUG-2000 12-OCT-2000 152012 USA 38 7S12 NANANA F81Z 9D930 AB E29 42 47756
AWS Claim Key: 16453980 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 02459 - * Name: SAM PACK'S FIVE STAR FORD Ph: 972-2426415 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2003 Doc #:369518A
Cust Comments: CHECK ENGINE LIGHT TROUBLES ENGINE IS RUNNING ROUGH
Tech Comments: 47756 28 9D930 6005F .2, F1 .1, F1X1 .1, F2 .1, F6 .1, F10 .1, F12 .3, F13 .1, F14 .1, 6584AR 1.0 TOTAL 2.2 NGS CONT. P1316, KOEO P1275, KOER P0275. R&R RIGHT VLVE COVER FOUND INJ. HARNESS LOOSE AT GASKET. REPLACED HARNESS. CLEARED CODES AND DROVE
1FTSW31F41EA02446 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 03-AUG-2000 12-OCT-2000 152012 USA 38 * * * * * * * 47756
AWS Claim Key: 16440533 Trx Code: 01S24 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02459 - * Name: SAM PACK'S FIVE STAR FORD Ph: 972-2426415 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2003 Doc #:369518C
Cust Comments: RECALL 01S24 WIPER MOTOR GEAR COVER
Tech Comments: 47756 RECALL 01S24M .6 .6 INSPECT ONLY
1FTSW31F41EA02446 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 03-AUG-2000 12-OCT-2000 152012 USA 46 3A02 070104 * 7A089 * P59 01 65560
AWS Claim Key: 18766664 Trx Code: P05 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 02441 - * Name: BANKSTON FORD OF FRISCO, LTD, CO. Ph: 972-3355000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2004 Doc #:425191A
Cust Comments: CUST STATES TRANS SHUDDERING ON SHIFT AND HAS TO GO TO 3K RPM AND LET OFF OD ACCELERATOR TO SHIFT OUT OF 1ST GEAR
Tech Comments: 65560 ELECTRONIC TRANS DIAG, PINPOINT TEST, P0782, R&R TRANS, MOUNT ON BENCH FIXTURE, TEARDOWN TO INSPECT, FOUND INTERMEDIATE ONE WAY CLUTCH BROKEN, PERFORM COST CAP ANALYSIS, REPAIR COST OVER CAP, CALL HOTLINE FOR PRIOR APPROVAL # PAAZN, REPORT #4GWEP021, REPLACE TRANS ASSY, FLUSH COOLER AND LINES, INSTALL INLINE FILTER, ROAD TEST AFTER REPAIRS.
1FTSW31F41EA02446 T/F7 F T/BC T/CD T/E A1 T/DQ T/DS 03-AUG-2000 12-OCT-2000 152012 USA 51 2B01 0300XX F7TZ 12K073 A D50 42 76971
AWS Claim Key: 19297437 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02478 - * Name: MIDDLEKAUFF FORD Ph: 972-9853600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2004 Doc #:616369A
Cust Comments: D21 CUST STATES THE VEH DIES WHEN SLOWING OF TAKING FOOT OFF ACCEL SOMETIMES HAPPENS OVER THE LAST THREE WEEKS NO WARNING LIGHTS REPORT
Tech Comments: 76971 DIES 6005F,F1,2,6,7,8,9,12650D60 1.3 WDS DIAG DIESEL PERFORMANCE CHART RETRIEV CODES REPLACE CAMSHAFT SENSOR P0340
