OASIS RESULT:
1FDAW56P27EA91365
02/21/2008
22:23:55
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2007 F-SERIES BODY STYLE
F-550 CC CHASIS 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/03/2006 BUILD DATE
08/28/2006 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/29/2007
DEALER: Mills Ford
WARRANTY CLAIM NUMBER: 209636 ODOMETER: 049438M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 071601C 42 DOES NOT OPERATE PROPERLY
5C3Z 6K682CARM TURBO CHG-EXH DRIVE 001
1 ROAD TEST, VERIFIED CONCERN. EEC TEST RETREAVED CODE P0299. PERFORM TSB 07-16-1 AS OUTLINED. PERFORMED PINPOINT TEST, KAI-KA6-AK2-AK7. REPALCE UGT VALVE. ROAD TEST STILL NO POWER. CONTINUED WITH PINPOINT TEST KAI-KAII LEADS TO REPLACE TURBO. R+R TURBO INSPECT FOUND UNISON RING RUSTED AND HOTSIDE OF TURBO HEAVYLY CLOGED. REPLACED TURBO.
11/05/2007
DEALER: Mills Ford
WARRANTY CLAIM NUMBER: 207632 ODOMETER: 049395M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D 42 DOES NOT OPERATE PROPERLY
VC 7B 002 9456A
OSP 001 9456AZN
W302725 001 12650D
3C3Z 9J469AA SEAL EGR TUBE 001 12650DX1
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 6005F38
3C3Z 6A642AA COOLER CRANKCASE OI 001 MT6A642
3C3Z 6840AA GASKET-OIL FILLER AD 001
VERIFY CONCERN WHITE SMOKE OUT OF TAIL PIPE UNABLE TO ROAD TEST COOLING SYST EMM 16 PSI R-R TUBRO Y PIPE TO INSPECT EGR COOLER COOLANT COMING OUT OF CO OLER. CALLED HOT LINE ASKED OIL COOLER WILLBE DAMAGED TO DUE FAILURE, THEY A DVICED TO REPLACE EGR COOLER AND OIL COOLER. FLUSH SYSTEM R-R FAN AND ACCESS REPLACE EGR COOLER M-TIME REPLACE ENGINE OIL COOLER R PRES TEST COOLING SYS
10/18/2007
DEALER: Jorgensen Ford Mercury, Inc.
WARRANTY CLAIM NUMBER: 017896 ODOMETER: 046632M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 69 FROZEN/SEIZED/BINDING
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 6005F13
000 6005F1
000 6005F2
000 6005F20
000 6005F18
000 6005F6
000 6005F45
000 6005F1X1
000 9527AR
000 12650D30
GINE IS MAKING KNOCKING NOISE D50/// VERIFIED EXCESSIVE WHITE SMOKE FRM TAIL PIPE AND LACKS POWER-VISUALS OK OIL OK FUEL OK KOEO P1335 KOEC P0404 P0405 P1335 P2282 P0275 KOER P1335 PIN POINT TEST EGR KOEO VOLTAGE 1.8 1V REMOVED EGR FOUND TO BE EXCESSIVELY COKED-REPLACED EGR VLAVE. RETEST STILL BLOWS AL OT OF WHITE SMOKE. KOER P0725 POWER BALANCE CYL 5 CANOT BE SHUT DOWN-INJECTO
07/25/2007
DEALER: Colorado River Ford Lincoln Me
WARRANTY CLAIM NUMBER: 335108 ODOMETER: 036065M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9C407AA PUMP&ISOLATOR-FUEL E 001 9002A 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 9002A6
3C3Z 9N184CA WATER-FUEL SEP ELEM 001 9527AL
000 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F21
000 6005F22
000 6005F33
000 6005F38
000 6005F39
000 6005F45
000 6051A11
FUEL PUMP FAILURE DIESEL PERFORMANCE DIAGNOSIS 1-15. P0269, P0299. EGR TE ST- PASS. PINPOINT TEST. EGR TEST-PASS. BOOST TEST-PASS. FUEL PRESSURE DROPS TO 10 PSI UNDERLOAD. REMOVE FUEL FILTERS FOR INSPECTION-O.K. REPLACE FUEL P UMP, REPLACE FUEL FILTERS. RETEST-ENGINE STILL LOW ON POWER, MISS. COMPRESSI ON TEST #3- 410 PSI. INJECTOR INTERRUPT TEST - #2,4,6,8- NON CONTRIBUTIN
07/19/2007
WARRANTY CLAIM NUMBER: 334609 ODOMETER: 035908M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 9527AL 42 DOES NOT OPERATE PROPERLY
4C3Z 6564AA ARM-VALVE ROCKER 001 6584A5
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F
XO 15W40QSD 015 6005F1
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F21
000 6005F22
000 6005F23
000 6005F38
000 6005F39
000 6005F45
INJECTOR #2 FAILURE DIESEL NO START DIAGNOSIS-P0264-KOEO,KOEC. INJECTOR S ELF TEST-P0264. PINPOINT TEST P- OPEN PIN 122 INJECTOR. REMOVE VALVE COVER A ND OIL RAIL FOR INSPECTION-INJECTOR #2 COIL BOLT FAILURE, DAMAGE TO #2 EXHAU ST ROCKER ARM. REPLACE #2 INJECTOR. REPLACE #2 EXHAUST ROCKER ARM-DRAIN OIL, REPLACE FILTER. REASSEMBLE, CLEAN DTC AND ROAD TEST-VEHICLE HAS LACK
06/08/2007
DEALER: Mills Ford
WARRANTY CLAIM NUMBER: 201559 ODOMETER: 031873M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 001 6051AR D1 POROSITY
6C3Z 6051A GASKET CYL HEAD 001 6007D
3C3Z 6584BA GASKET VALVE ROCKER 001
VC 7B 003
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 9229AA GASKET CARB FUEL INL 004
6C3Z 6C288A KIT-ENG RKR ARM SHFT 001
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001
XO 15W40QSD 014
NECESARY TO REPLACE RIGHT SIDE CYLINDER HEAD REPLACE MOUNTIN PLATE,REASEMBLE ENGINE CHANGE OIL AND OIL FILTER ADD COOLANT RE TEST SYSTEM SEE LINE 2
06/08/2007
DEALER: Mills Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 9527AL 42 DOES NOT OPERATE PROPERLY
VERIFY CONCERN PERFOM CONTRIBUTION TEST FOUND NO2 AND NO6 CYLINDER DROPING P ERFOM IDS BASED RELATION COMPRESSION TEST OK REPLACE 2 INJECTORS RETEST OK
06/08/2007
DEALER: Mills Ford
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 002 10654C1T 42 DOES NOT OPERATE PROPERLY
REPLACE BATTERYS
05/22/2007
DEALER: Mills Ford
WARRANTY CLAIM NUMBER: 200967 ODOMETER: 029280M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642AA COOLER CRANKCASE OI 001 9527AT 42 DOES NOT OPERATE PROPERLY
3C3Z 6731AA ELEMENT ASY OIL FILT 001 9527A2T
VC 7B 002 6642A
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
OSP 001
W302725 001
B7A 8287BA CLAMP ASY-RAD HOSE 002
B7AZ 8287C CLAMP ASY-RAD HOSE 001
3C7Z 18495AB VALVE ASY HEATER WAT 001
OSP 001
6C3Z 6C640A CONNECTION A/C DUCT 001
OSP 001
6C3Z 6C640B CONNECTION A/C DUCT 001
XO 15W40QSD 014
REPLACE OIL COOLER AND EGR COOLER REASEMBLE ENGINE FLUSH COOLING SYSTEM 2 TI MES EST THERMOSTAT AND RAN OPERATION OK CHANGE OIL AND FILTER
05/22/2007
DEALER: Mills Ford
LABOR OP
CONDITION CODE
CONDITION DESC
XL3Z 13466AA SMALL BULBS 001 13465A 28 OPEN CIRCUIT
000 ADD
REPLACE BURNT OUT BULB
03/16/2007
WARRANTY CLAIM NUMBER: 015085 ODOMETER: 028576M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C407AB PUMP&ISOLATOR-FUEL E 001 6005E 63 WEAK/SOFT/SAGGED (INSUFFICIENT PRESSURE)
9C407 PUMP&ISOLATOR-FUEL E 000 6005E6
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 6005E7
3C3Z 9N184CA WATER-FUEL SEP ELEM 001 6005E8
000 6005E2
000 6005E3
000 9002A
000 9002A6
000 9527AR
000 9155AT
ART/// VERIFIED NO START-VISUALS OK,OIL LEVEL OK,FUEL LEVEL AND CONDITION O K-KOEO PASS KOEC P0269. KOEO INJ ELEC TEST PASS. FUEL PRESSURE TEST 0 PSI,IN LET RESTRICTION TEST 0. PIN POINT TO BAD FUEL PUMP.REPLACED FUEL PUMP.NOW HA S 53 PSI FUEL PRESSUREAND WILL NOT START.REPLACED INJ 3. NOW STARTS SPUTTERS AND DIES,CYL 1,5,7 ALLL MISSFIRE. REPLACED 1,5,7 INJECTORS. NOW STARTS AND
03/02/2007
DEALER: Barbee's Freeway Ford, Inc.
WARRANTY CLAIM NUMBER: 169924 ODOMETER: 026906M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 7005A CASE ASY-TRANSMISSIO 001 MT7000 42 DOES NOT OPERATE PROPERLY
3C3Z 7A089AB CLUTCH ASY-TRANS PLA 001
5C3Z 7D483E SNAP RING-RR CLCH P/ 001
3C3Z 7153AD GASKET TRANSMISSION 001
7C3Z 7A103A FRONT PUMP ASY-TRANS 001
3L3Z 7902AARM CONVERTER ASY 001
3C3Z 7A098AA SCREEN ASY - OIL PAN 001
XT 6QSP 018
CASE FALURE ELECT TRANS DIOG PRESSURE TEST R&I AND MOUNT TO BENCH O-H TRA NS FLUSH COOLER REPLACE TRANS CASE AND REVERSE SPRAG CLUTCH REROAD TEST
03/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F19
000 6005F8
000 6005F22
000 9527AL
ENGINE PERFORMANCE DIAG AND PCED TESTED STEPS 1-13 RECEIVED CODES P0268 AND P0280 AND FOLLOWED PINPOINT TESTS P1-P4 PERFORMED ENHANCED INJECTOR DIAG AND CONFIRMED #3 AND #7 INJECTORS ARE INOPER RECLAIM A-C, R&R EVAP HOUSING TO A CCESS AND R&R VALVE COVER AND REPLACED #3 AND #7 INJECTORS. PURGED OIL AND F UEL AND EVAC AND RECHARGED A-C AND RETESTED ENGINE OPERATION OK. ROAD TESTED
03/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 12B533AA MODULE-GLOW PLUG CTL 001 6005E 42 DOES NOT OPERATE PROPERLY
000 6005E2
000 6005E3
000 6005E4
000 6005E5
000 6005E6
000 6005E7
000 6005E8
000 6005E45
000 12342D2
HARD START NO START DIAG AND PCED TEST STEPS 1-10 AND TESTED GLOW PLUG SYSTE M RECEIVED CODE P0670 AND FOLLOWED PINPOINT AF8-AF13 AND FOUND GLOW PLUG CON TROL MODULE HAS INTERNAL OPEN CIRCUIT CONDITI REPLACED GPCM AND CLEARED CODE S AND RETESTED SYSTEM OPERATIN OK.
03/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AL 42 DOES NOT OPERATE PROPERLY
REDIAG ENGINE PERFORMANCE TESTS DTCS NUMBER 5 INJECTOR FAILS CYL BALANCE TES T NO KOEO INJECTOR DTCS REPLACE FUEL INJECTOR NUMBER 5 RETEST CLEAR DTC AN D RECHECK OKAY
02/20/2007
DEALER: Mills Ford
WARRANTY CLAIM NUMBER: 197359 ODOMETER: 026269M
LABOR OP
CONDITION CODE
CONDITION DESC
W302725 001 6005F
000 6005F1
000 6005F2
000 6005F45
VERIFY CAUSE FOLLOW STEP 1-6B IN PERFOANCE DIAG SHEET GO TO PC-ED PERFOM PIN POINT TEST P1-P2 NECESSARY TO REPLACE NO.6 FUEL INJECTOR AND ORING DUE TO O PEN ADJUST OIL LEVE. ROAD TEST VEHICLE OK EEC TEST PASSED
| On-line 1878
END OF OASIS REPORT FOR 1FDAW56P27EA91365
Discussion Starter · #3 ·
Wow, this truck has been in the shop quite a bit. Cannot believe all the inj. failures. At what point does Ford swap out this motor. It appears to be eating the injectors.
Discussion Starter · #4 ·
Based on this VIN# , can anyone on here determine what the rear end gear ratio is
Thanks
