OASIS RESULT:
1FTNW21F83EB13799
02/27/2008
19:50:55
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
31 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/19/2003 BUILD DATE
11/02/2002 SALE MILEAGE
00020
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/16/2008
DEALER: Faulkner-Ciocca Ford
WARRANTY CLAIM NUMBER: 156730 ODOMETER: 064006M
LABOR OP
CONDITION CODE
CONDITION DESC
F6TZ 9F838A SENSR ASY F/I TIMING 001 6007D 42 DOES NOT OPERATE PROPERLY
OSP 002 9838A
VERIFIED ENGINE OIL LEAK, PERFORMED ENGINE DYE TEST TRACED TO ICP SENSOR, RE MOVED AND REPLACED ICP SENSOR RETEST FOUND OK AFTER REPAIRS
01/16/2008
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9VE527BRM INJECTOR ASSY-DIESEL 001 6005E2 42 DOES NOT OPERATE PROPERLY
000 6005E3
000 6005E4
000 6005E6
000 6005E7
000 MT6005E45
000 6005F
000 6005F1X1
000 6005F6
000 6005F7
000 6005F10
000 6005F11
000 9527AR
VERIFIED RUNS ROUGH, PERFORMED SELF TEST-PASS INJECTOR ELEC TEST-PASS CYLIN DER CONTRIBUTION TEST-FAIL 284 #1 CYLINDER PINPOINT TEST REMOVE AND REPL ACE #1 INJECTOR REUSABLE GASKET RETEST FOUND OK AFTER REPAIRS
01/16/2008
LABOR OP
CONDITION CODE
CONDITION DESC
F7TZ 12K073B TRNSDC ASY-C/SHT PSN 001 07S57B
PERFORMED RECALL 07S57 INSPECTED CAM SENSOR GOLD,REMOVED AND REPLACED CAM S ENSOR PER RECALL 07S57
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21F83EB13799
Standard Claims List For Model Year 2003
1FTNW21F83EB13799 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 02-NOV-2002 19-FEB-2003 116443 USA 35 5C02 050100 F81Z 4800 FA N18 42 24967
AWS Claim Key: 12744575 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 10994 - * Name: HOLMAN LINCOLN MERCURY - ENGLISH CREEK Ph: 609-4849400 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:122680A
Cust Comments: CUST STATES NOISE UNDER VEH
Tech Comments: 24967 REMOVED DRIVE SHAFT REPLACED HANGER BEARING 4602AA 4602A4F .9 .5
1FTNW21F83EB13799 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 02-NOV-2002 19-FEB-2003 116443 USA 60 2E06 030008 F6TZ 9F838 A L65 42 64006
AWS Claim Key: 15781735 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02955 - * Name: FAULKNER-CIOCCA FORD Ph: 215-7219100 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2008 Doc #:156730A
Cust Comments: CUSTOMER STATES VEHICLE HAS AN OIL LEAK
Tech Comments: VERIFIED ENGINE OIL LEAK, PERFORMED ENGINE DYE TEST TRACED TO ICP SENSOR, REMOVED AND REPLACED ICP SENSOR RETEST FOUND OK AFTER REPAIRS
1FTNW21F83EB13799 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 02-NOV-2002 19-FEB-2003 116443 USA 60 2E03 030402 5C3Z 9VE527 BRM D13 42 64006
AWS Claim Key: 15787508 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 02955 - * Name: FAULKNER-CIOCCA FORD Ph: 215-7219100 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2008 Doc #:156730B
Cust Comments: CUSTOMER STATES VEHICLE RUNS ROUGH NO ACCELERATION
Tech Comments: VERIFIED RUNS ROUGH, PERFORMED SELF TEST PASS INJECTOR ELEC TEST PASS CYLINDER CONTRIBUTION TEST FAIL 284 #1 CYLINDER PINPOINT TEST REMOVE AND REPLACE #1 INJECTOR REUSABLE GASKET RETEST FOUND OK AFTER REPAIRS
1FTNW21F83EB13799 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 02-NOV-2002 19-FEB-2003 116443 USA 60 * * * * * * * 64006
AWS Claim Key: 15781734 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02955 - * Name: FAULKNER-CIOCCA FORD Ph: 215-7219100 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2008 Doc #:156730C
Cust Comments: CUSTOMER STATES RECALL 07S57 CAMSHAFT POSITION SENSOR INSPECTION REPLACEMENT
Tech Comments: PERFORMED RECALL 07S57 INSPECTED CAM SENSOR GOLD,REMOVED AND REPLACED CAM SENSOR PER RECALL 07S57
