OASIS RESULT:
1FMSU45P64EC47814
02/27/2008
19:53:46
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/23/2004 BUILD DATE
02/09/2004 SALE MILEAGE
00008
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0968 - USA 2007 USED 3/4,000 ROYAL SHIELD POWERTRAIN WARRANTY
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: KENDRA DOLAN
OPTIONS:
EXPIRATION DATE: 05/26/2008
DISTANCE: 78,762
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01980
ESP CONTRACT START DATE: 02/26/2008
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
04/09/2007
DEALER: Les Wenning Motors Inc
WARRANTY CLAIM NUMBER: 006322 ODOMETER: 066800M
LABOR OP
CONDITION CODE
CONDITION DESC
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D D8 FAILED GASKET/SEAL
3C3Z 9P458AA KIT - VLV EGR 001 MT8592
PERFORMED A COOLING SYSTEM PRESSURE TEST - FOUND ACOOLANT LEAK -MT TIME TO R EPLACE THE SHORT COOLAN T HOSE THAT CONNECTS TO THE EGR COOLER -REFILLED SYS TEM WITH COOLANT AND RETESTED -OK
04/09/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
5C3Z 12224A 3 WAY VACUUM CONNECT 001
REPLACED EBP SENSOR REPLACED EBP SENSOR CONNECTOR REPROGRAMMED PCM FICM AND TCM PER RECALL
04/09/2007
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
PERFORMED A TEST DRIVE PER FORD PROGRAM
| On-line 1878
END OF OASIS REPORT FOR 1FMSU45P64EC47814
Standard Claims List For Model Year 2004
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 7 1H03 030008 3C3Z 9J460 AA D13 42 12377
AWS Claim Key: 1908833 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:00771901
Cust Comments: RUNS ROUGH AT IDLE AND ON ACCELERATION ALMOST STALLS
Tech Comments: PERFORMED DIAGNOSIS PERFORMED PINPOINT TESTS AND PID DATA TESTS REPLACED EGR VALVE REPROGRAMED PCM STILL HAS SOME PROBLEM CALLED TECH HOTLIN MONITORED EBP AND VGT AND FUEL PRESSURE MT TIME FOR EXTRA TIME TO TEST DRIVE AND DIAGNOSE CONCERN MT TIME TO REPLACE VGT SOLENOID CLEARED CODE AND RETESTED OK ALSO REPLACED EBP SENSOR
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 13 2G05 031405 * RECAL * N12 04 24747
AWS Claim Key: 4641474 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2005 Doc #:00065601
Cust Comments: SOUNDS LIKE SOMETHING WINDING DOWN ON
Tech Comments: DECEL AT TIMES AND IDLE FLUCTUATES AT TIMES PERFORMED DIAGNOSIS NO EEC CODES IN SYSTEM PERFORMED PID DATA TESTING TEST DROVE REPROGRAMMED PCM TO LATEST LEVELS
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 13 3Y88 000615 * NPF * P82 82 24747
AWS Claim Key: 4660276 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2005 Doc #:00065602
Cust Comments: AT TIMES THINKS 4X4 DOESN'T WORK
Tech Comments: PERFORMED DIAGNOSIS TRIED TO GET TO HAPPEN DID NOT CHECKED FRONT HUBS ETC NO PROBLEM FOUND TODAY OASIS # 202 552 478
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 18 * * * * * * * 32830
AWS Claim Key: 6458512 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2005 Doc #:00190101
Cust Comments: FORD SAFETY RECALL 05S34
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 18 2H01 * * * * * * 32830
AWS Claim Key: 6412909 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2005 Doc #:00190102
Cust Comments: CUSTOMER SATISFACTION PROGRAM 05B29
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 39 1G01 03XXXX 4C4Z 8592 AA L87 D8 66800
AWS Claim Key: 11432610 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2007 Doc #:00632201
Cust Comments: COOLANT LEAK FROM ENGINE
Tech Comments: PERFORMED A COOLING SYSTEM PRESSURE TEST FOUND ACOOLANT LEAK MT TIME TO REPLACE THE SHORT COOLAN T HOSE THAT CONNECTS TO THE EGR COOLER REFILLED SYSTEM WITH COOLANT AND RETESTED OK
1FMSU45P64EC47814 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-FEB-2004 23-FEB-2004 147596 USA 39 * * * * * * * 66800
AWS Claim Key: 11432611 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2007 Doc #:00632203
Cust Comments: FORD RECALL # 05E15
Tech Comments: REPLACED EBP SENSOR REPLACED EBP SENSOR CONNECTOR REPROGRAMMED PCM FICM AND TCM PER RECALL
AWS Claim Key: 11432612 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02793 - * Name: LES WENNING MOTORS INC Ph: 419-3754135 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2007 Doc #:00632204
Cust Comments: FORD PROGRAM # 59B01
Tech Comments: PERFORMED A TEST DRIVE PER FORD PROGRAM
