I don't know if it's kosher to ask for two. I am going to look at these two Excursions as possible purchase prospects on Friday.
1FMSU43F41EB75002
1FMSU43F62EB07835
I really appreciate having this resource available as I go looking for a rig. Thanks in advance for the information and assistance.
OASIS RESULT:
1FMSU43F41EB75002
02/28/2008
21:35:34
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1L119Y0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/17/2001 BUILD DATE
01/05/2001 SALE MILEAGE
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FMSU43F41EB75002
Standard Claims List For Model Year 2001
1FMSU43F41EB75002 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 05-JAN-2001 17-MAR-2001 156579 USA 22 2E06 100106 F81Z 9C407 AA N50 42 45260
AWS Claim Key: 12255900 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 08358 - * Name: COURTESY FORD LINCOLN MERCURY, INC. Ph: 208-2381600 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:24-DEC-2002 Doc #:07017101
Cust Comments: WILL NOT START COLD
Tech Comments: TOWED TO SHOP DIAGNOSED ENGINE PERFORMANCE & REPLACED LIFT PUMP ASSY.
1FMSU43F41EB75002 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 05-JAN-2001 17-MAR-2001 156579 USA 34 * * * * * * * 62682
AWS Claim Key: 16858388 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08358 - * Name: COURTESY FORD LINCOLN MERCURY, INC. Ph: 208-2381600 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2003 Doc #:08078901
OASIS RESULT:
1FMSU43F62EB07835
02/28/2008
21:36:39
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 EXCURSION BODY STYLE
7.3L TURBO - DI
TRANSMISSION
ENGINE CALIBRATION
ARN MESSAGES
WARRANTY START DATE
01/28/2002 BUILD DATE
11/10/2001 SALE MILEAGE
00012
07S57
EXTENDED COVERAGES
| On-line 1878
END OF OASIS REPORT FOR 1FMSU43F62EB07835
Standard Claims List For Model Year 2002
1FMSU43F62EB07835 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 10-NOV-2001 28-JAN-2002 171171 USA 17 * * * * * * * 14606
AWS Claim Key: 5949152 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2003 Doc #:09245652
Cust Comments: PROGRAM 03B03 ADJUSTABLE ACCELLERATOR PEDAL SENSOR
Tech Comments: PERFORMED RECALL 03B03 INSTALLED NEW PEDAL ASSY
1FMSU43F62EB07835 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 10-NOV-2001 28-JAN-2002 171171 USA 17 7E03 011603 * 17A605 * W03 01 14684
AWS Claim Key: 6059657 Trx Code: E83 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2003 Doc #:09325251
Cust Comments: CUST STATES THE WINDSHIELD WASHERS ARE INOP
Tech Comments: RF FENDER WELL ACCESS TO REPAIR AND REROUTE BOTH WASHER HOSES DUE TO PINCHED AND OUT OF PLACE
1FMSU43F62EB07835 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 10-NOV-2001 28-JAN-2002 171171 USA 21 1D01 030008 3C3Z 6734 AA L85 30 19763
AWS Claim Key: 7640389 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2003 Doc #:00657651
Cust Comments: CUST STATES ENGINE OIL LEAK
Tech Comments: REPLACED WORN GASKET ON DRAIN PLUG
1FMSU43F62EB07835 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 10-NOV-2001 28-JAN-2002 171171 USA 22 1B02 030202 * 6731 * L65 D8 21287
AWS Claim Key: 8020580 Trx Code: E90 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2003 Doc #:00985451
Tech Comments: CLEAN ENGINE ADD OIL DYE CHECK FOR LEAKS REMOVE AND REPLACE ENGINE OIL FILTER DUE TO LEAK AT GASKET TOP OFF OIL ROADTEST OK AT THIS TIME ALSO DEBURR SHARP EDGES ON FILTER HOUSING WHICH MAY HAVE CAUSED LEAKING FILTER
1FMSU43F62EB07835 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 10-NOV-2001 28-JAN-2002 171171 USA 52 2E06 03XXXX 2C3Z 9G804 AB L65 D8 49064
AWS Claim Key: 15346939 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01718 - * Name: RIVERSIDE FORD Ph: 253-8383464 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2006 Doc #:09322201
Cust Comments: CUSTOMER REPORTS OIL LEAK.WAS TOLD COMING FROM BEHIND TURBO
Tech Comments: SOME OIL VISIBLE IN VALLEY, DRAINING DOWN BACK OF ENG. NO DRIPPING OBSERVED WITH ENG RUNNING. CLEANED VALLEY, ADDED DYE TO ENG OIL, ADVISE CUST TO RETURN AFTER 100 200 MILES FOR INSPECTION AND R REPLACED PUMP O RINGS PER TSB 4 4 4. CLEANED VALLEY, TEST DROVE OK. NO FURTHER LEAKS OBSERVED AT THIS TIME. TOPPED OIL OFF. (3 QTS)
Discussion Starter · #6 ·
Thanks a lot. Unfortunately, one sold before I got to it and the dealer is in love with the other one-price is too high and they won't come down. The search continues........
