Discussion Starter · #2 ·
Anyone willing to run this Oasis for me? I know I've asked for others recently, maybe I've asked too much? I'm not being impatient, just wondering if I violated etiquette?
OASIS RESULT:
1FMSU43F52EC69424
03/04/2008
20:39:31
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/28/2002 BUILD DATE
03/28/2002 SALE MILEAGE
00073
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/19/2008
DEALER: Courtesy Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 124497 ODOMETER: 118680M
LABOR OP
CONDITION CODE
CONDITION DESC
F7TZ 12K073B TRNSDC ASY-C/SHT PSN 001 07S57B
1 REPLACED CAM SENSOR
| On-line 1878
END OF OASIS REPORT FOR 1FMSU43F52EC69424
Standard Claims List For Model Year 2002
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 1 6F88 000615 * NPF * R22 82 3568
AWS Claim Key: 2723928 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 05518 - * Name: BOB BAKER FORD-MISSION VALLEY Ph: 619-2975001 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2002 Doc #:427566B
Cust Comments: R22 CUSTOMER STATES 70MPH WIND NOISE IN DRIVERS DOOR POST
Tech Comments: 3568 NPF 82 NO PROBLEM FOUND. MT NPF 1.0 ROAD TESTED VEHICLE, HEARD A SMALL AMOUNT OF WIND NOISE FROM MIRROR. THIS IS NORMAL FOR THIS VEHICLE. USED SONIC LEAK TESTER TO CHECK LEFT SIDE OF VEHICLE FOR LEAKS. NO LEAKS AT THIS TIME. CHECKED OASIS FOR COMMON CONCERNS. NONE FOUND. NO PROBLEM FOUND AT THIS TIME.
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 5 2H01 030008 F81Z 6K682 BARM N11 D8 12297
AWS Claim Key: 4011550 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 05518 - * Name: BOB BAKER FORD-MISSION VALLEY Ph: 619-2975001 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:31-DEC-2002 Doc #:440782A
Cust Comments: D13 CUSTOMER STATES AT 2000 RPMS THERE IS A HUMMING SOUND FROM THE ENGINE WHICH TURNS INTO A SPUTTERING SOUND FEEL ALSO NOTED EXCCESIVE SMOKE FROM THE TAIL PIPE CHECK AND ADVISE.
Tech Comments: 12309 9438 D8 TURBO NOT WORKING 9438A 1.7, 6005F 0.2, 600F1 0.1, F1X1 0.1, F2 0.1, F6 0.1, F7 0.2, F8 0.1, F9 0.3, F10 0.1 F11 0.2, F12 0.3 CORRECTION: RAN DIESEL ENGINE PREFORMANCE TEST. RAN KOEO TEST KOER TEST. FOUND CODE FOR LOW BOOST PRESSURE. BUZZ TESTED IJECTORS. TEST ICP PRESSURE, RAN CYLINDER CONTRIBUTION TEST. ALL OK. TEST BOOST PRESSURE AND FOUND TO BE LOW. DURING
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 8 7B02 140201 F81Z 10346 EARM D02 42 18665
AWS Claim Key: 5364428 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2003 Doc #:02674251
Cust Comments: CK CLICK NO START JUMP STARTED THEN DIED AGAIN
Tech Comments: TEST CHARGING SYSTEM REPLACED FAULTY ALTERNATOR TEST OK
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 10 * * * * * * * 21395
AWS Claim Key: 5985022 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2003 Doc #:02843951
Cust Comments: RECALL 03B03 ADJUSTABLE ACCELERATOR PEDAL SENSOR
Tech Comments: PERFORMED RECALL 03B03
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 19 5K06 * * * * * * 44471
AWS Claim Key: 9291698 Trx Code: 04B14 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2004 Doc #:03889451
Cust Comments: RECALL 04B14 FIRESTONE TIRE
Tech Comments: PERFORMED RECALL 04B14
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 19 5K06 * * * * * * 44694
AWS Claim Key: 9473141 Trx Code: 04B14 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2004 Doc #:03913051
Cust Comments: RECALL 04B14 FIRESTONE TIRES
Tech Comments: REPLACED ALL 5 TIRES DOT CODE VNW81X01102
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 53 2B01 0300XX F7TZ 12K073 A D03 42 98336
AWS Claim Key: 15858031 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2006 Doc #:07586151
Cust Comments: CK STALLS AT TIMES WHILE DRIVING
Tech Comments: ROAD TEST TO VERIFY CONCERN RAN SCAN TOOL TESTS 0340 PERFORMED PINPOINT TESTS AND MONITORED PIDS AS NEEDED FOUND FAULTY CAM SENSOR REPLACED CAM SENSOR ROAD TEST RETEST OK
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 53 7A01 140101 * 10654 * D03 42 98336
AWS Claim Key: 15860687 Trx Code: SPW Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2006 Doc #:07586251
Cust Comments: FAILED PART WARRANTY BATTERIES GO DEAD AT TIMES
Tech Comments: TEST BATTERY AND CHARGING SYSTEM CHARGING SYSTEM OK CHARGED AND RETESTED BATTERIES BOTH BATTERIES FAILED REPLACED BOTH BATTERIES AND RETEST OK
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 54 7A01 140101 BXT 65 850 C25 42 100000
AWS Claim Key: 15943483 Trx Code: SPW Labor Hrs: 1
Dlr Cd-Sub Cd: 08369 - * Name: GALLAGHER FORD LINCOLN MERCURY, INC. Ph: 775-7383147 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2007 Doc #:07681251
Cust Comments: FAILED PART WARRANTY TO REPAIR DEAD BATTERY
Tech Comments: RAN SCAN TOOL TEST FOUND LEFT SIDE BATTERY FAILED REPLACED BATTERY RETESTED OK
1FMSU43F52EC69424 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 28-MAR-2002 28-AUG-2002 171086 USA 67 * * * * * * * 118680
AWS Claim Key: 16662746 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08358 - * Name: COURTESY FORD LINCOLN MERCURY, INC. Ph: 208-2381600 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2008 Doc #:12449701
Cust Comments: RECALL 07S57
Tech Comments: 1 REPLACED CAM SENSOR
Discussion Starter · #5 ·
My sincere thanks to you. I'll be trying to make a deal on this one-hopefully I won't have to check any more VIN's
