check you vin, i bet it's this number 1FTSW21P05EB11396, i will post an oasis for this vin, if thats not correct let me know.
OASIS RESULT:
1FTSW21P05EB11396
02/08/2009
23:16:10
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-11-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/05/2004 BUILD DATE
10/22/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P05EB11396
AWS Claim Key: 205547 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2004 Doc #:010767A
Cust Comments: CHECK FOR POPPING IN FRONT END WHEN TURNING LEFT & RIGHT
Tech Comments: REPLACE FRONT HUB
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 6 2H02 030008 3C3Z 6F089 AA D21 42 4906
AWS Claim Key: 818930 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2005 Doc #:012793A
Cust Comments: CUSTOMER STATES TURBO QUITS WHEN DRIVING HAS TO SWITCH OFF & RESTART TO MAKE WORK AGAIN
Tech Comments: REPLACE VGT
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 6 2H01 030008 4C3Z 6K682 AARM D41 42 5025
AWS Claim Key: 864128 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2005 Doc #:045081A
Cust Comments: GOING DOWN RD TRUCK STARTS SPITTING AND SPUDDING WHEN HITTING PASSING GEAR INTERMITTLY
Tech Comments: CK AND TEST REPLACE TURBO
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 7 7K88 000615 * NPF * H19 42 5627
AWS Claim Key: 947755 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 00815 - * Name: RONNIE WATKINS FORD Ph: 256-5439400 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2005 Doc #:117805A
Cust Comments: C S ABS LIGHT ON
Tech Comments: 5627 VERIFIED CONCERN CONNECT WDS RETRIEVE CODE C1175 C1236 CALLED HOT LINE CHECK PID MONOITOR FOR DROP OUT CUSTOMER DECLINED ANY FURTHER DIAG RELEASE VEHICLE WITH CONCERN
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 7 7K88 000615 * NPF * H19 42 6113
AWS Claim Key: 932320 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:045323A
Cust Comments: ABS LIGHT ON
Tech Comments: CK AND TEST NPF
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 7 7J05 050201 4L3Z 9E731 AA H19 42 6117
AWS Claim Key: 951529 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:045338A
Cust Comments: CK ABS LIGHT IT IS ON
Tech Comments: CK AND TEST REPLACE SENSOR
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 10 6N04 010802 5C3Z 16720 VA B66 42 8154
AWS Claim Key: 1671908 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:046201A
Cust Comments: F250 EMBLEMS ON BOTH DRIVER AND PASSENGER SIDE PAINT COMING OFF OF EMBLEMS
Tech Comments: R R EMBLEM ROMOVE OLD GLUE AND REINSTALL NEW EMBLEMS
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 15 * * * * * * * 9800
AWS Claim Key: 3230291 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:047960D
Cust Comments: RECALL 59B01
Tech Comments: COMPLETE RECALL
AWS Claim Key: 3230290 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:047960C
Cust Comments: RECALL 05E15
AWS Claim Key: 3230292 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:047960E
Cust Comments: RECALL 05B32
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 17 2H01 030008 5C3Z 6K682 CA D50 42 10808
AWS Claim Key: 4229377 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2006 Doc #:048694A
Cust Comments: WHEN GOING DOWN RD AND GIVE GAS AND LET OFF YOU CAN HEAR A POPING NOISE
Tech Comments: CK AND TEST RUN DIAG REPLACE TURBO
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 29 7J05 0502XX 6L3Z 9E731 A H19 42 17462
AWS Claim Key: 7350468 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00239 - * Name: MACK GRUBBS FORD-MERCURY, INC. Ph: 601-7311953 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2007 Doc #:023493A
Cust Comments: CUSTOMER STATES ABS LIGHT COMES ON AND BRAKES LOCK UP
Tech Comments: REPAIRED AS PER TSB 06 7 6
1FTSW21P05EB11396 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-OCT-2004 05-NOV-2004 123358 USA 29 6N04 010802 5C3Z 16720 VA B66 81 17573
AWS Claim Key: 7404377 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05832 - * Name: GRUBBS FORD, LINCOLN-MERCURY, INC. Ph: 985-7353673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2007 Doc #:053163A
Cust Comments: EMBLEMS PEELING F250 LARIAT SUPER DUTY XS 2 F250 SUPERDUTY
Tech Comments: CK AND REPLACE EMBLEMS
