OASIS RESULT:
1FTWX31P47EA33261
03/03/2009
23:49:40
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2007 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710H0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-11-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/24/2007 BUILD DATE
06/06/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
1FTWX31P47EA33261 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-JUN-2006 24-JAN-2007 111409 USA 3 5T03 070603 4C3Z 7210 BA P82 42 7014
AWS Claim Key: 402619 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08910 - * Name: COLUMBIA FORD LINCOLN-MERCURY Ph: 860-2282886 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:07035153
Cust Comments: CUSTOMER STATES POPS OUT OF LOW RANGE USSALY WHILE BACKING UP
Tech Comments: SHIFT MOTOR GEAR SELECTOR LEVER REPLACE
1FTWX31P47EA33261 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-JUN-2006 24-JAN-2007 111409 USA 3 7C01 170501 5C3Z 11654 FAA L29 42 7014
AWS Claim Key: 402617 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08910 - * Name: COLUMBIA FORD LINCOLN-MERCURY Ph: 860-2282886 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:07035151
Cust Comments: CUSTOMER STATES PANLE AROUND HEADLAMP SWITCH POPS OUT
Tech Comments: SWITCH FALIURE SWITCH HEADLAMP CONTROL REPLACE
1FTWX31P47EA33261 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-JUN-2006 24-JAN-2007 111409 USA 3 5K01 040401 * 1007 * N25 D9 7014
AWS Claim Key: 402618 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 08910 - * Name: COLUMBIA FORD LINCOLN-MERCURY Ph: 860-2282886 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:07035152
Cust Comments: CUSTOMER STATES VIBRATION OVER 60 MPH
Tech Comments: FRONT WHEELS OUT OF BALANCE TIRES AND WHEELS CHECK RUN OUT
1FTWX31P47EA33261 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-JUN-2006 24-JAN-2007 111409 USA 3 7K11 130101 6C3Z 10849 JC G32 42 7014
AWS Claim Key: 402620 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08910 - * Name: COLUMBIA FORD LINCOLN-MERCURY Ph: 860-2282886 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:07035154
Cust Comments: CUSTOMER STATES CLUSTER READS ERATIC SEE CUSTOMER NOTE
Tech Comments: CLUSTER CONCERN INSTRUMENT CLUSTER REMOVE AND INSTALL OR REPLACE
1FTWX31P47EA33261 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-JUN-2006 24-JAN-2007 111409 USA 4 5U01 000502 5C3Z 5D008 A N25 42 12495
AWS Claim Key: 716222 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08910 - * Name: COLUMBIA FORD LINCOLN-MERCURY Ph: 860-2282886 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2007 Doc #:07253151
Cust Comments: CUSTOMER STATES VIBRATION SHIMMY 56 MPH AND ABOVE
Tech Comments: VIBRATION DAMPER ROAD TEST VECH CHECK TIRES AND INSTALL REAR VIBRATION DAMPER PER T
