Breaks stuff
1FTNW21P84EA26706
Thanks in advance!:thumbsup
OASIS RESULT:
1FTNW21P84EA26706
USA
EN
04/20/2009
00:12:13
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/13/2003 BUILD DATE
08/04/2003 SALE MILEAGE
00020
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0736 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: MICHAEL BEST
OPTIONS:
EXPIRATION DATE: 09/27/2008
DISTANCE: 96,175
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 06450
ESP CONTRACT START DATE: 09/27/2006
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
11/20/2008
DEALER: Excel Ford Lincoln Mercury, LP
WARRANTY CLAIM NUMBER: 067064 ODOMETER: 129267M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 42 DOES NOT OPERATE PROPERLY
REPLACE ICP SENSOR
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 2 7S02 180102 * 14401 * D21 95 4446
AWS Claim Key: 23058 Trx Code: 1 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2003 Doc #:58689701
Cust Comments: VEH STARTED UP PUT IN REVERSE ENGINE STALLED WOULD NOT RESTART
Tech Comments: 1 CK FOR NO START FOUND BLOWN FUSE NUM F2.22 TRACE WIRES TO FIND SHRT TO GND CIR 361 SHORTED TO GND UNDER GLOW PLUG
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 11 2G05 031405 * RECAL * D13 42 21156
AWS Claim Key: 1215504 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:06945101
Cust Comments: C S IDLES ROUGH AND INTERMINTENTLY SURGES CC D13 CUSTOMER WAIT
Tech Comments: 42 INOP 12A650 PCM REPROGAMMED PCM, FICM, AND TCM. CK REPAIR OK.
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 27 1H03 030008 4C3Z 9F452 A D42 42 51342
AWS Claim Key: 7548670 Trx Code: E72 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2005 Doc #:09139102
Cust Comments: C S ENGINE LACKING POWER ON ACCELERATION, BLOWS BLACK SMOKE ON ACCELERATION. CHECK AND REPORT.
Tech Comments: 42 INOP EGR VALVE 9F452 ENGINE PERF.DIAG. TESTS #1 #14. FUEL PSI. AT 50LBS. CODES P0299. REPLACE EGR VALVE . RETEST P1000 ROADTEST 51356
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 30 2E06 030008 3C3Z 9E527 AE D50 42 59032
AWS Claim Key: 8541102 Trx Code: E72 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 05841 - * Name: WHITSON-MORGAN MOTOR COMPANY, INC. Ph: 479-7543020 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2006 Doc #:02219001
Cust Comments: VEHICLE STARTED SMOKING WHILE DRIVING ON HWY CHECK AND ADVISE
Tech Comments: PERFORMED DIAG TEST EGR VALVE IS LEAKING OIL HAS LOTS OF FUEL NUMBER 6 INJECTOR IS LEAKING REPLACED EGR VALVE AND PERFORMED DIAG PER WOKSHEET PERFORMED RELATIVE COMPRESSION CYLINDER BALANCE E3U7A 12A650FTF, REPLACED NUMBER 6 INJECTOR ECTRA TIME 03 TO EXTRACT ONE BOLT THAT THE HEAD WAS ROUNDED OFF ROAD TEST AND REPEAT SELF TSET NO CODES RETURNED
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 31 2E06 030008 * 9E527 * D50 42 60026
AWS Claim Key: 8894250 Trx Code: E72 Labor Hrs: 20.4
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2006 Doc #:268459A
Cust Comments: VEHICLE DIED WHILE DRIVING, ENGINE QUIT, CUSTOMER JUST HAD WARRANTY REPAIR WORK IN ARKANSAS
Tech Comments: RAN DIESEL ENGINE PERFORMANCE DIAGNOSTICS, FOUND MISSFIRE AND ENGINE RUNS ROUGH, RETRIEVED CODES P0263,P0281,P0677,P0671. REMOVED NUMBER 1 AND 7 GLOW PLUGS AND CHECKED COMPRESSION. NUMBER 7 HAD 0 COMPRESSION AND NUMBER 1 HAD ONLY 100 PSI. REMOVED ENGINE AND REMOVED CYLINDER HEADS FOR INSPECTION. FOUND PISTONS IN CYLINDERS 1 AND 7 MELTED AND CYLINDERS SCORED.CAUSE INJECTOR F AILURE WHICH CAUSED
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 31 5R02 110601 * 3600 * A99 82 60026
AWS Claim Key: 8906907 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2006 Doc #:268459C
Cust Comments: RENTAL COVERAGE FOR VEHICLE
Tech Comments: RENTAL RENTAL COVERAGE FOR OUT OF TOWN WAITER APPROVED BYCUSTOMER ASSISTANCE CENTER ON A P98 CODE
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 31 2B01 030707 3C3Z 12K073 AA D50 01 60030
AWS Claim Key: 8866334 Trx Code: E88 Labor Hrs: 31.2
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:268915A
Cust Comments: CORRECT FOR ENGINE DIED WHILE DRIVING
Tech Comments: 60030 PERFORMED DIESEL PERFORMANCE DIAGNOSTICS, RETRI EVED CODES P2614, PERFORMED PINPOINT TESTS, FOU ND CAM SENSOR FAULT, REPLACED THE SENSOR, STILL NOT OPERATING CORRECTLY. CHECKED WIRING AND AL L SYSTEMS, CALLED HOTLINE. DISASSEMBLED ENGINE FOUND THE KEYWAY WAS NOT INSTALLED AND CAUSED D DAMAGE TO THE CAMSHAFT RING AND ALL THE VALVES ARE BENT. INSTALLED A NEW ENGINE BLOCK, TRANSFE
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 31 5R02 110601 * 3600 * A99 82 60030
AWS Claim Key: 8964534 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 05009 - * Name: MIDWAY FORD TRUCK CENTER, INC. Ph: 816-4553000 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:268915C
Cust Comments: RENTAL ASSISTANCE CODE P98
Tech Comments: RENTAL ASSISTANCE
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 33 * * * * * * * 63869
AWS Claim Key: 9082390 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2006 Doc #:09857402
Cust Comments: PERFORM RECALL 59B01 CUST ASSURANCE TEST DRIVE
Tech Comments: TEST DROVE TRUCK
AWS Claim Key: 9082391 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2006 Doc #:09857401
Cust Comments: PERFORM RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: REPROGRAMMED PCM FICM TCM
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 37 2E06 030008 3C3Z 6C751 AA L65 D8 72042
AWS Claim Key: 10165821 Trx Code: E72 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2006 Doc #:76038501
Cust Comments: C S ENGINE OIL LEAK
Tech Comments: FAILED SEAL CC D8 RUN OIL LEAK DIAG.FOUND LEAKING FROM OIL PRESS RELEAVE VALVE.REPLACE RELEAVE VALVE ASY AND CAP WITH O RING
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 43 1D01 030201 3C3Z 6700 BA L65 D8 86675
AWS Claim Key: 11256073 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2007 Doc #:78173301
Cust Comments: CK FOR OIL LEAK DIESEL
Tech Comments: FIALED O RING CC D8 RUN OIL LEAK DIAG. FOUND TO BE LEAKING FROM OIL PUMP FRONT COVER.REPLACE O RING ON FRONT COVER AND FRONT CRANK SEAL CLEAN AND RECHECK. OK
1FTNW21P84EA26706 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-AUG-2003 13-AUG-2003 123036 USA 65 2E06 030008 3C3Z 9F838 EA D50 42 129267
AWS Claim Key: 13015573 Trx Code: OTC Labor Hrs: 0
Dlr Cd-Sub Cd: 02871 - * Name: EXCEL FORD LINCOLN MERCURY, LP Ph: 903-6933821 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2008 Doc #:06706402
Cust Comments: CHECK ICP SENSOR FAULTY
Tech Comments: REPLACE ICP SENSOR
Reactions: machine
Breaks stuff
A great deal of appreciation to you, 4play. Thank you very much.
