Vin# 1FDWX37PO5EC44456 Thank You!
OASIS RESULT:
1FDWX37P05EC44456
USA
EN
06/18/2009
14:12:42
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 S/CAB CHASSIS CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
ZF M6HD-W 6-SPEED AXLE CODE
4N ENGINE CALIBRATION
5F720F0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/29/2005 BUILD DATE
03/05/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - EXPIRED
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: CALVIN C & W CONSTRUCTION
OPTIONS:
EXPIRATION DATE: 06/29/2008
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01185
ESP CONTRACT START DATE: 06/29/2005
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 4 3M05 070301 4C3Z 7124 AA P01 42 16195
AWS Claim Key: 2201386 Trx Code: E84 Labor Hrs: 13.3
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:099792A
Cust Comments: GRINDING GOING INTO SECOND GEAR
Tech Comments: VERIFY CONCERN GRINDS IN FIRST AND SECOND GEARS R AND R TRANS AND TRANSFER CASE. REMOVE PTO ASY MOUNT TRANS TO BENCH FIXTURE AND TEAR DOWN. FO UND 1ST AND 2ND GEAR SYNCRONIZER AND GEARS WORN REPLACE 1ST AND 2ND GEARS AND SYCRONIZER. REASSEMBLE SET FEND PLAY AND GEAR LASH PUT PTO BACK ON AND INSTALL TRANS FILL AND FLUSH COOLER LINES ROAD TEST PROBLEM SOLVED. CASUE OF FAILUE
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 6 4A01 080103 4C3Z 7550 BARM P24 42 20523
AWS Claim Key: 2870249 Trx Code: E84 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2005 Doc #:100698A
Cust Comments: CLUTCH PEDAL GOING TO THE FLOOR
Tech Comments: VERIFY CONCERN. CHECK CLUTCH ASY FOUND HYDROLIC CLUTCH SLAVE CYL BUSTED DUE TO CLUTCH DISC SHEDDED AND COLLAPSED. PRESSURE PLATE. REPLACED HYDROLIC CLUTCH SYSTEM. R R TRANS AND PTO. REPLACE CLUTCH DISC PRESSURE PLATE T O BEARING AND PIVOT BUSHINGS REASSEMBLE. ROAD TEST. OK.
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 8 * * * * * * * 27479
AWS Claim Key: 3540354 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:101540C
Cust Comments: RECALL ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: PERFORM RECALL AS PER INSTRUCTED
AWS Claim Key: 3429467 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:101540D
Cust Comments: RECALL 05B32 DE GAS BOTTLE FILL LEVEL
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 11 5I01 110204 5C3Z 3A674 B N58 42 38730
AWS Claim Key: 4630401 Trx Code: 0701D Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:102954D
Cust Comments: POWER STEERING IS NOISY
Tech Comments: VERIFY FOUND PS PUMP WORN OUT. REPLACED PS PUMP AND PURGE AIR FROM SYSTEM. ROAD TEST. OK.
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 11 1A01 030008 3C3Z 6049 AA L87 42 38730
AWS Claim Key: 4660362 Trx Code: E72 Labor Hrs: 22.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:102954E
Cust Comments: TRUCK IS LOSING COOLANT
Tech Comments: VERIFY. PERFORM PRESS TEST AND INSTALL T GAGE. ROAD TEST. FOUND PRESS ROSE ABOVE 22LBS. CONTAC T HOT LINE NO. 6EHD4009 TEAR DOWN CYLD HEADS AND REPLACE EGR COOLER OIL COOLER CHECK BLOCK FLATNESS LESS THAN .002 HEADS ARE CRACKED AND W ARPED .004. REPLACE BOTH HEADS AND GSKTS. REASS EMBLE ENGINE AND TORQ CLEAN EVAT INTAKE AN REPL ACED EGR VALVE DUE TO COOLANT IN INTAKE. FILL A
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 14 5I01 110204 3C3Z 3A674 AARM N58 42 44684
AWS Claim Key: 5633167 Trx Code: SPW Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2006 Doc #:104450B
Cust Comments: GRINDING NOISE WHEN TURNING
Tech Comments: VERIFY CONCERN FOUND POWER STEERING PUMP NOISEY REPLACE POWER STEERING PUMP AND PUGE SYSTEM RO AD TEST REPAIR COMPLETE
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 14 2B01 030706 3C3Z 6C315 AA E29 42 44684
AWS Claim Key: 5633168 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2006 Doc #:104450C
Cust Comments: SERVICE ENGINE SOON LIGHT IS ON
Tech Comments: VERIFY CONCERN PERFORM DIESEL ENGINE DIAG 1 THR U 5 RETRIECED CODE P2617 CRANK SENSOR FAULT CHE CK TSB AND SSM NONE APPLY FOUND CRANK SHAFT SEN SOR OPEN CIRCUIT REPLACE SENSOR AND RETEST PASS ES ROAD TEST REPAIR COMPLETE
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 16 2E03 030402 4C3Z 9E527 AA D13 42 48156
AWS Claim Key: 6154148 Trx Code: S07 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2006 Doc #:105451A
Cust Comments: ENGINE IS RUNNING ROUGH IN THE A.M.
Tech Comments: VERIFY CONCERN PERFORM DIESEL DIAG 1 TH 6B 9 10 A 10B 10C 11 AND 14 CODES P0263 CYLD NUM 1 FAIL ED PERFORM PPT P1 YES GO TO P15 YES FUEL PRESS 52 PSI P16 POWER BAL FAILS NUM 1 AND 8 CYLD PPT P17 CRANKCASE 0 INCH COMPRESSION NUM 1 410 NUM 8 410 PSI PPT P18 NO REMOVE AND REPLACED NUM 1 AND 8 INJECTORS DUE TO NOT WORKING PROPERLY RE ASSEMBLE RETEST PASSES ROAD TEST PROB SOLVED
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 18 7H06 120303 1W1Z 19E889 DC C02 42 53224
AWS Claim Key: 6608794 Trx Code: 0701D Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2006 Doc #:105992C
Cust Comments: A C BLOWS WARM
Tech Comments: VERIFY CONCERN HOOK UP GUAGES FOUDN SYSTEM LOW LEAK TEST AC SYSTEM FOUND O RINGS LEAKING ON AC CUMULATER SYCTION HOSE ON CONDENSOR TO DISCHARG E P NUT FITTINGS RECHAIN FREON AND REPLACE ORIN GS 2 EVACUATE AND RECHARGE 2LBS 10 OZ OF R134 R OADTEST PROBLEM SOLVED
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 18 2E03 030402 4C3Z 9E527 AA D13 42 53224
AWS Claim Key: 6860875 Trx Code: S07 Labor Hrs: 6
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2006 Doc #:105992A
Cust Comments: ENGINE IS RUNNING ROUGH IN THE A.M. WHEN FIRST STARTED
Tech Comments: VERIFY CONCERN CHECK TSB 06223 REPROGRAM FCM TE ST DRIVE STILLL MISSES PERFORM DEISEL DIAG 1 TH RU 6 B 10A 10B 10C 11 AND 14 FOUND CYLDS 2 4 6 MISSING AT 40 PERCENT ON POWER BALANCE TEST PER FORM PPT P15 TES FUEL PRESSURE 52 PSI PD AND P 16 NO FAILED 2 4 6 PPT P17 NO CRANKCASE PRESSUR E 0 COMPRESSION 2 420 4 420 6 420LBS PPT P18 NO REMOVE REPLACE 2 4 6 INJECTORS TO INJ HOLD D OWN
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 19 5I01 110204 5C3Z 3A674 B C50 42 55533
AWS Claim Key: 6782610 Trx Code: 0701D Labor Hrs: 0
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2006 Doc #:106318A
Cust Comments: VEHICLE IS HARD TO TURN AND MAKES A WHINING NOISE
Tech Comments: VERIFY CONCERN PERFORMED POWER STEERING FLOW TE ST FLOW TEST FAILED AT 4 OZ IN 30 SECONDS AND PERFORMED POWERSTEERING PRESSURE TEST PRESSURE TEST FAILED AT 30 PSI R R POWERSTEERING PUMP AND REPLACED REFILL TO SPEC RETEST PASSED RO AD TEST PROB SOLVED
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 19 5V07 060704 6C3Z 2005 AA H50 42 56778
AWS Claim Key: 7301230 Trx Code: 0701D Labor Hrs: 3.6
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:106592B
Cust Comments: POWER STEERING MAKING A GRINDING NOISE WHEN TURNING
Tech Comments: VERIFY CONCERN PERFORMED POWER STEERING PUMP FL OW TEST TEST FAILED AT 4 PSI FOUND RESTRICTION AT HYDROBOOST FOUND POWER STEERING PUMP DAMAGED R AND R POWER STEERING PUMP AND R AND R HYDROBO OST REASSEMBLE AND REFILL TO SPEC PURGE AIR FRO M POWER STEERING TO HYDROBOOST SYSTEM ROAD TEST PASSED PROBLEM SOLVED
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 21 5C04 050100 5C3Z 4A376 E P31 01 59157
AWS Claim Key: 7391099 Trx Code: 0701D Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2007 Doc #:107149A
Cust Comments: CUSTOMER STATES 4X4 INOP
Tech Comments: VERIFY CONCERN PERFORM 4X4 DIAG UPON INSPECTION FOUND TRANSFER CASE BUSTED IN TWO AND FRONT DRI VE SHAFT CV JOINT BROKEN CAUSING TRANSFER CASE TO BUST UP REPLACE TRANSFER CASE AND FRONT DRIV E SHAFT ROAD TEST PROBLEM SOLVED APPROVAL E57N N
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 23 7Q01 031904 3L3Z 9F924 AB G29 28 61959
AWS Claim Key: 7793153 Trx Code: 0701D Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2007 Doc #:108105C
Cust Comments: TBC FAULT LIGHT IS ON
Tech Comments: VERIFY CONCERN HOOK UP IDS RAN KOEO TBC CODE C2 803 BRAKE PRESS SWITCH CIRCUIT FAULT CHECK AND TEST SWITCH SWITCH FAILED OPEN REPLACED SWITCH RETEST PASSES ROAD TEST PROBLEM SOLVED
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 23 5I01 110204 3C3Z 3A674 AARM H22 30 61959
AWS Claim Key: 7784052 Trx Code: SPW Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2007 Doc #:108105I
Cust Comments: POWER STEERING HARD TO TURN
Tech Comments: POWER STEERING PUMP WORN OUT
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 23 5O01 110201 7C3Z 3504 A H22 30 61959
AWS Claim Key: 7793152 Trx Code: 0701D Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2007 Doc #:108105A
Cust Comments: POWER STEERING IS HARD TO TURN
Tech Comments: VERIFY CONCERN CHECK AND FOUND PS PUMP WORN OUT GEAR BOX WORN REPLACED PS PUMP AND GEAR BOX PU RGE AIR FROM SYSTEM ROAD TEST OK PROBLEM SOLVED SEE LINE I FOR POWER STEERING PUMP
1FDWX37P05EC44456 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 05-MAR-2005 29-JUN-2005 152666 USA 23 5I01 110204 3C3Z 3A674 AARM H50 42 61960
AWS Claim Key: 7872935 Trx Code: SPW Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01185 - * Name: MCKAY FORD, LINCOLN-MERCURY, INC. Ph: 580-2566465 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2007 Doc #:108125A
Tech Comments: VERIFY CONCERN PS PUMP WAS JUST PUT ON AND OUIT WORKING BEFORE I GOT OUT OF PARKING LOT REPLAC ED PS PUMP FLUSH SYSTEM ALL PASS PURGE AIR ROAD TEST OK
