OASIS RESULT:
1FTNX21P23EC56317
See bottom of the OASIS result for contact ID
02/07/2006
17:38:38
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/24/2003 BUILD DATE
03/03/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
03L12
ENGINE EMISSION CONTROL INFORMATION (EECI) LABEL REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTNX21P23EC56317
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 9 2G04 031401 * 12A650 * D50 42 3817
AWS Claim Key: 3617849 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2003 Doc #:05065651
Cust Comments: CHECK FOR BLACK SMOKE ROUGH RUNNING IN THE MORNING
Tech Comments: BLACK SMOKE AND ROUGH RUNNING EEC (QUICK TEST) DIAGNOSIS ,NO PROBLEM FOUND,UN ABLE TO DUPLICATE CONCERN
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 16 7S06 030008 3C3Z 12B637 BA D50 42 14141
AWS Claim Key: 6938457 Trx Code: S07 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2004 Doc #:05797851
Cust Comments: TRANSMISSION SLIPS OR JUMPS OUT OF GEAR WARNING LIGHT ON
Tech Comments: ROAD TESTED, SHIFTS OK, POSSSIBLE ENGINE MISS FILLED OUT DIESEL DIAGNOSIS SHEET FOUND MISS ON #6, #7, AND #8 CYLINDERS WITH NO CODES CHECKED FOR CHAFED WIRES REPLACED ENGINE AND INJECTOR WIRE HARNESSES RECHECKED AND ROAD TEST OK RUBBED AT OIL PRESSURE RAIL REIED TO REPAIR INEFFECTIVE HAD TO REPLACE
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 17 * * * * * * * 15149
AWS Claim Key: 7264423 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2004 Doc #:05885555
Cust Comments: RECALL
Tech Comments: RECALL 04S15 RECALL 04S15
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 18 2E06 100101 3C3Z 9275 CA A85 42 15995
AWS Claim Key: 7876556 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:06005251
Cust Comments: AFTER FUEL FILL GAUGE STAYS ON EMPTY WITH LOW WARNING LITE WILL CORRECT ITSELF AFTER SEVERAL DRIVE CYCLES
Tech Comments: FUEL GAUGE INOP ON FUILL UP FUEL GAUGE TANK UNIT REPLACE
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 18 6X04 0109XX 4C3Z 17D743 BAA M05 42 15995
AWS Claim Key: 7876557 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:06005252
Cust Comments: RUNNING LITES ON OR BLOWER FAN PICKS UP STATIC IN AM ON BALTIMORE STATIONS
Tech Comments: RADIO STATIC MIRROR REAR VIEW OUTSIDE SAIL MOUNT MANUAL REPLACE
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 18 5C01 050101 3C3Z 4602 CA N22 42 15995
AWS Claim Key: 7876558 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:06005253
Cust Comments: AT A STOP GO TO ACCEL DROPS OUT OF GEAR FOR A SPLIT SECOND THEN GOES REVIEW HISTORY
Tech Comments: CHECK VIRBRRATION DRIVE SHAFT ASSEMBLY REAR REMOVE AND INSTALL OR REPLACE
1FTNX21P23EC56317 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 03-MAR-2003 24-MAR-2003 127558 USA 18 6R01 011001 3C3Z 28611B09 BAA S25 42 15995
AWS Claim Key: 7876559 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:06005254
Cust Comments: DRIVER SEATBELT GRABS
Tech Comments: SEATBELT JAMS SEATBELT ASSEMBLY FRONT REPLACE
AWS Claim Key: 7876560 Trx Code: E90 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03809 - * Name: NORRIS FORD OF EASTON, LLC Ph: 410-8222900 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #:06005255
Cust Comments: MIRROR COVER WON T STAY ON
Tech Comments: COVER WON T STAY ON MIRROR REAR VIEW OUTSIDE SAIL MOUNT ELECTRIC REPLACE
