Diesel Pro
you guys are probably wearing out Doug LOL
OASIS RESULT:
1FTNW21P93ED04298
See bottom of the OASIS result for contact ID
02/07/2006
21:23:30
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/29/2003 BUILD DATE
04/15/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTNW21P93ED04298
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 1 2H02 030008 3C3Z 6F089 AA D50 42 1223
AWS Claim Key: 1564703 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2003 Doc #:09576451
Cust Comments: CUST STATES WHILE TOWING UP AHILL TURBO STATED TO WHISTLE THEN CUST PULLED OVER SHUT OFF ENGINE THEN VEHICLEWOULD NOT GO OVER 40 NO MATTER HOW
Tech Comments: VGT SOLENOID REPLACED SOLENOID
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 3 2G05 031405 * RECAL * D50 42 3558
AWS Claim Key: 2001873 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2003 Doc #:09976751
Cust Comments: CUST STATES ONLY GETTING 7 MPG PULLING TRAILOR AND A VERY LOUD TURBO WHISSWHISTLE UNDER A LOAD VERY LOUD AND NO POWER TILL 1800 2000 RPMS
Tech Comments: REPROGRAM PCM EEC (QUICK TEST) DIAGNOSIS
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 10 * * * * * * * 11922
AWS Claim Key: 4751079 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2004 Doc #:02809452
Cust Comments: 03E03
Tech Comments: PCM CALIBRATION PCM REPROGRAM
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 11 2E06 030008 3C3Z 9F838 EA L65 42 17442
AWS Claim Key: 5561669 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:03186251
Cust Comments: OIL LEAK FROM FRONT OF VEHICLE ( PRIME ITEM )
Tech Comments: ICP SENSOR CAC PIPE ENGINE OIL LEAKS DIAGNOSIS
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 11 1D01 030008 3C3Z 6701 AA L65 42 17580
AWS Claim Key: 5652180 Trx Code: E84 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2004 Doc #:03227351
Cust Comments: CUST STATES HAS OIL LEAK FROM ENGINE
Tech Comments: REAR MAIN SEAL LEAKING OIL AUTOMATIC TRANSMISSION SEAL CRANKSHAFT REAR MAIN (FULL CIR
1FTNW21P93ED04298 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 29-MAY-2003 171167 USA 19 2H01 031202 3C3Z 6C640 FA D50 42 31627
AWS Claim Key: 8695478 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2004 Doc #:05318551
Cust Comments: CAC TUBE GOING INTO TURBO BLEW OFF CK AND ADV
Tech Comments: REPL HOSE AND CLAMP DUCT ENGINE CHARGE AIR COOLER REPLACE
Squatch said:
OASIS RESULT:
1FTNW21P93ED04298
02/07/2006
21:23:30
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
WARRANTY START DATE
ARN MESSAGES
WARNING MESSAGES
EXTENDED COVERAGES
REPAIR HISTORY
I guess they didn't put the New Motor Replacement on since I had to pay for everything!Oh well I still got the 03 motor sitten in the Garage wondering what to do?:evil:
Thank you very much!:thanks:
Luckily, someone else has the time to donate to pulling the OASIS. You guys know I would if someone didn't beat me to it. I appreciate Squatch's help on these. Its nice to have a newer member help out.
THANK YOU BOTH FOR ALL YOUR HARD WORK:Thumbup: :thanks: !
