03M02
FRONT COIL SPRINGS - COVERAGE TO 10 YEARS OF SERVICE OR 150,000 MILES FROM THE VEHICLES
03N01
FUEL DELIVERY MODULE - EXPIRES 10 YEARS FROM THE ORIGINAL WARRANTY START DATE REGARDLESS
Standard Claims List For Model Year 2001
1FAFP36321W167327 C/AK F C/FF * C/A AZ C/D2 C/EQ 23-OCT-2000 21-APR-2001 124489 USA 0 5K04 * * * * * * 10
AWS Claim Key: 901646 Trx Code: 00L12 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 04865 - * Name: DESOTO FORD-MERCURY, INC. Ph: 863-4944848 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2001 Doc #:08184149
Cust Comments: MANUAL SUPPLEMENT 00L12
Tech Comments: RECALL PERFORM RECALL
1FAFP36321W167327 C/AK F C/FF * C/A AZ C/D2 C/EQ 23-OCT-2000 21-APR-2001 124489 USA 26 5H04 * * * * * * 11183
AWS Claim Key: 14556536 Trx Code: 01B85 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2003 Doc #:64939902
Cust Comments: REAR WHEEL BEARINGS FSA 01B85
Tech Comments: RECALL 01B85 WHEEL BEARINGS AND SEAK KIT DONE
1FAFP36321W167327 C/AK F C/FF * C/A AZ C/D2 C/EQ 23-OCT-2000 21-APR-2001 124489 USA 26 * * * * * * * 11183
AWS Claim Key: 14556535 Trx Code: 02S42 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2003 Doc #:64939903
Cust Comments: PINCH BOLT TORQUE FSA 02S42
Tech Comments: RECALL 02S42 TORK BOLT TO 37FT LB , INSTALL BATTERY BOX KIT
1FAFP36321W167327 C/AK F C/FF * C/A AZ C/D2 C/EQ 23-OCT-2000 21-APR-2001 124489 USA 26 1H03 03XXXX 2F1Z 9J460 AA E29 42 11183
AWS Claim Key: 14556537 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2003 Doc #:64939901
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON CHECK AND ADV
Tech Comments: BASE DPFE MO 11186 NGS START UP , PO402 EGR FLOW TO HIGH RR DPFE RETEST OK CLEAR CODES
