Hello, this OASIS report request is for my 2005 Ford F-550
(VIN: 1FDAW57P15EC68127)
I bought the truck in December 2007 but didn't know about the OASIS report at the time. I love the truck so I figure having all the history will help me maintain it until the wheels fall off (and keep me from letting the wheels fall off).
Thanks!
JDH
I'm starting to discover "little issues" with the truck that I am certain will be more "obvious" based on the OASIS. For example, the truck was driven around the world...I'm pretty sure it was overseas that the catalytic converter was removed, the catalyst broken out (likely for its precious metal content) and the catalytic converter shell reinstalled. I discovered the lack of a catalyst when I upgraded to a 4 inch exhaust. The truck was serviced by Ford during the trip. I know it had a significant oil leak at one point too...maybe an HPOP leak! I think the OASIS for me is not a "luxury" but a "necessity" as I've got this EarthRoamer on the back of a fantastic truck. I just need to protect my investment. Thanks if you can get me an OASIS for:
1FDAW57P15EC68127
Jonathan
Standard Claims List For Model Year 2005
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 16 * * * * * * * 17580
AWS Claim Key: 5360488 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03297 - * Name: SILL-TERHAR MOTORS, INC. Ph: 303-4691801 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2006 Doc #:08064941
Cust Comments: 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALL DO RECALL 05B35 RECALIBRATE CONTROL MODULES
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 16 2H01 030008 5C3Z 6K682 CA D42 41 17580
AWS Claim Key: 5360489 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03297 - * Name: SILL-TERHAR MOTORS, INC. Ph: 303-4691801 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2006 Doc #:08064951
Cust Comments: TRUCK HAS NO TURBO POWER, CHECK AND ADVISE
Tech Comments: SELF TEST KOEO,RET&CLEAR,INJ TEST,AND KOER NO CODES CHECK TURBO PRESS LOW CHECK PIDS FOR MGP,AND VGT FOUND VGT PID AT 84.99 REPLACE TURBO AND RETEST TRUCK RUNS FINE
AWS Claim Key: 5360487 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03297 - * Name: SILL-TERHAR MOTORS, INC. Ph: 303-4691801 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2006 Doc #:08064940
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: RECALL DO RECALL 05B32 INSTALL LABEL
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 32 2E01 030008 4C3Z 9J332 AA D02 D8 29204
AWS Claim Key: 9220535 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: L0K07 - * Name: M-AUTO Ph: 007-327-511 St:* Ctry Cd: KAZ Reg Cd: WD Repr Date:19-OCT-2007 Doc #:0003521
Cust Comments: VEHICLE STUCK IN KAZAKHSTAN. ENGINE WOULDN'T START. NO CRANK
Tech Comments: DIAGNOSTIC WORKS.BRANCH TUBE REPLACEMENT.INCLUDES REMOVAL INSTALLATION OF GEARBOX, PROPELLER SHAFT, TURBINE REMOVAL INSTALLATION, OIL INJECTORS CLEAN ETC. REPAIR PROCESS TOOK ALMOST A MONTH (IN A STREET CONDITION). ACTUAL LABOR TIME TOOK THREE WEEKS.ONE ELECTRICIAN AND TWO MECHANICS WERE INVOLVED IN REPAIR PROCESS. BY OUR MINIMUM ESTIMATION WE ARE CLAIMING FOR THREE WEEKS (OVERTIME TOO / WEEKENDS)
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 38 7A01 140101 BXT 65 750 D36 53 29659
AWS Claim Key: 9853594 Trx Code: 911 Labor Hrs: 0.3
Dlr Cd-Sub Cd: A0F02 - * Name: WAGNER FORD Ph: *-* St:* Ctry Cd: MNG Reg Cd: WD Repr Date:30-APR-2008 Doc #:28901606
Cust Comments: MACHINE IS NOT STARTING.
Tech Comments: WHEN CHECKED, THE BATTERY WAS DEAD. BATTERY CHARGING AMPERE IS GOOD, BATTERY VOLTAGE IS TOO LOW.
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 38 1D01 03XXXX 3C3Z 6701 A G29 X2 29659
AWS Claim Key: 9853595 Trx Code: 911 Labor Hrs: 4.4
Dlr Cd-Sub Cd: A0F02 - * Name: WAGNER FORD Ph: *-* St:* Ctry Cd: MNG Reg Cd: WD Repr Date:30-APR-2008 Doc #:28901607
Cust Comments: OIL IS LEAKING.
Tech Comments: OIL LEAKING BETWEEN ENGINE AND TRANSMISSION, LEAKAGE WAS FROM ENGINE REAR SEAL. REMOVED THE TRANSMISSION AND REPLACED WITH NEW.SERVICE MADE IN FIELD AND AIR TICKET CLAIMED BY MISC.
1FDAW57P15EC68127 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 15-MAR-2005 31-MAR-2005 156008 USA 38 1H03 030804 4C3Z 9J460 A D36 63 29659
AWS Claim Key: 9853593 Trx Code: 911 Labor Hrs: 3
Dlr Cd-Sub Cd: A0F02 - * Name: WAGNER FORD Ph: *-* St:* Ctry Cd: MNG Reg Cd: WD Repr Date:30-APR-2008 Doc #:28901605
Cust Comments: LOW POWER, BAD PERFORMANCE
Tech Comments: CHECKED THE VEHICLE PERFORMANCE, AND FOUND THE FOLLOWING PROBLEMS: PCM FAILURE, TURBOCHARGER FAILURE, DEFECTIVE EGR PRESSURE AND VALVE MODULATOR. DAMAGED TURBOCHARGER SEAL OF THE SHAFT, OIL IS LEAKING FROM TURBOCHARGER, REPLACED BY NEW. MADE ROAD TEST. ENGINE PERFORMANCE IS GOOD WHEN START UP, BUTAFTER WARMS UP, OPERATION BECOMES ROUGH. AFTER TEST OF EGR PRESSURE,IT WAS 3.4MPA AFTER REPLACEM
Reactions: howell_jd
