I am new here. Do you just post your vin and you get a report.
Here is the vin# 1FMSU45P54ED33888
Good Morning,
OASIS RESULT:
1FMSU45P54ED33888
07/15/2006
08:27:58
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/27/2004 BUILD DATE
04/29/2004 SALE MILEAGE
00051
ARN MESSAGES
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/08/2006
DEALER: Young Ford, Inc.
WARRANTY CLAIM NUMBER: 363066 ODOMETER: 052360M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 060605A 69 FROZEN/SEIZED/BINDING
000 6005F
000 6005F1
000 6005F1X1
000 6005F6
000 8146A
000 8616A
PERFORM ENGINE DIAGNOSIS RETEST PINPOINT TEST RR FAN DRIVE HUB AND FAN SHROU D REPROGRAM PROCESSOR PER TSB 06 06 05 INSPECT THROTTLE BODY PINPOINT TEST
02/10/2006
WARRANTY CLAIM NUMBER: 361280 ODOMETER: 052168M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6701A
3C3Z 6D083AA GASKET-RR COVER 001 6700A
000 MT6D083
VERIFY OIL LEAK AT ENGINE ADD DYE ROAD TEST BACK LITE ENGINE FT SEAL AND REA M MAIN SEAL LEAKING R R AND REPL CRANK FT SEAR AND R R TRANS R R 4X4 R R FLY WHEEL REPLACE REAR MAIN WITH BLACK LITE FOUND REAR PLATE LEAKING R R REAR ENG PLATE REPLACE GASKETS
01/04/2006
DEALER: O. C. Welch Ford Lincoln-Mercu
WARRANTY CLAIM NUMBER: 009176 ODOMETER: 051072M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 12650D 42 DOES NOT OPERATE PROPERLY
6C3Z 9B249A HEADER-FUEL FILTER 001 12650D84
000 12650D45
000 9249A
000 12650D80
EEC (QUICK TEST) PIN POINT TEST PCM REPROGRAMMING TEST. REPLACE FUEL FILTER - HEADER. DCL DISPLAY/PID MONITOR TEST
01/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
W300012 001 9438A D8 FAILED GASKET/SEAL
9G438 TURBOCHARGER ASSY 000
OSP 003
TURBOCHARGE ASSY - REMOVE AND REPLACE O-RING AT DRAIN TUBE
01/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
EP SENSOR, CONNECTOR AND RECALIBRATION
01/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RD TEST VEHICLE FOR ASSURANCE AND VERIFY REPAIRS
08/08/2005
WARRANTY CLAIM NUMBER: 348136 ODOMETER: 034973M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AC COOLER - EGR 001 9456A 28 OPEN CIRCUIT
3C3Z 9P455AB SE E/G/R VLV 001 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F20
000 12650D30
000 12650D84
PERFORM EEC TEST FUEL PRESSURE TEST EGR TEST ROAD TEST PID MONITOR EGR BAD R EPALCE EGR COOLER AND GASKET AND O RINGS REPROGRAM TCM PCM AND FICM
08/08/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 14A099A SHIELD WIRING 001 05S34E
5C3Z 12224A 3 WAY VACUUM CONNECT 001
08/08/2005
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
08/08/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7D006D PLANET ASSY TRANS RE 001 04B24G
XT 6QSP 019
06/30/2005
WARRANTY CLAIM NUMBER: 002931 ODOMETER: 031142M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9N184CA WATER-FUEL SEP ELEM 001 9249A 42 DOES NOT OPERATE PROPERLY
3C3Z 9B249AB HEADER-FUEL FILTER 001
HEADER - FUEL FILTER - REPLACE
06/30/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D30 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F8
000 6005F22
000 6005F12
EGR VALVE OR GASKET REPLACE, ENGINE PERFORMANCE DIAGNOSTICS, KEY ON ENGINE O FF, INTAKE, EGR POSTITION, EXHAUST SYS, FUEL PUMP BOOST TEST
Thanks,
Vivian
