OASIS RESULT:
1FTSW31P64EB19264
USA
EN
05/03/2009
23:16:27
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/26/2003 BUILD DATE
10/21/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0711 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: THOMAS RYAN
OPTIONS: $100,DED.
EXPIRATION DATE: 11/26/2008
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04473
ESP CONTRACT START DATE: 11/26/2003
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 0 6Y05 000001 * TDRIVE * A96 82 5
AWS Claim Key: 110662 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2003 Doc #:14269601
Cust Comments: CUST STATES PERFORM POWERTRAIN INSPECTION AND ROAD TEST
Tech Comments: PERFORMED PI AND ROADTEST DONE
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 1 6Y05 000001 * TDRIVE * A96 82 11
AWS Claim Key: 172836 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04473 - * Name: CHAMPION FORD GULF FREEWAY Ph: 713-3714000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2003 Doc #:160594A
Cust Comments: 6.0 PDI TEST DRIVE
Tech Comments: 11 PERFORMED ROAD TEST
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 17 6L01 011201 * 3804320 * T50 42 30826
AWS Claim Key: 4591736 Trx Code: E84 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 10167 - * Name: CHAMPION-LINCOLN MERCURY Ph: 281-8904000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2005 Doc #:197562B
Cust Comments: CUSTOMER STATES THE CUP HOLDER ON THE DASH WILL NOT GO IN
Tech Comments: 30826 42 04320B 2.5 INST PANEL ACCESS TO REMOVE CUP HOLDER AND REPOSTION WIRING BEHIND HOLDER AND RE ASEMBLE ASSY
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 18 2G04 031401 * 12A650 * D13 04 32206
AWS Claim Key: 4957054 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 10167 - * Name: CHAMPION-LINCOLN MERCURY Ph: 281-8904000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2005 Doc #:198669D
Cust Comments: CUSTOMER STATES VEHICLE IS RUNNING ROUGH AT TIMES WHEN CRANKED UP
Tech Comments: 32206 12A650 04 12650D 0.2+ 12650DX1 0.1+ 12650D45 0.3+ 12650D80 0.1+ 12650D84 0.5 CK EEC SYSTEM. CONT CODE P2069 WATER IN FUEL. SEE LINE A FOR REPAIR. PINPOINT TEST Z INTERMITTENT FAULT DIAG. RUNS ROUGH INTERMITTENTLY ON COLD START. CK DCL DATA. ALL ENGINE DATA NORMAL. POWER BALANCE ALL CYL FIRING EVENLY. FELT ONCE BUT UNABLE TO DUPLICATE SINCE. REPROGRAM PCM AND FICM FOR COLD
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 21 * * * * * * * 38476
AWS Claim Key: 6383983 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 10167 - * Name: CHAMPION-LINCOLN MERCURY Ph: 281-8904000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2005 Doc #:202687A
Cust Comments: PERFORM RECALL 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: 38476 RECALL 05S34D 1.0 INSPECT INJECTOR HARNESS AND INSTALL REPAIR KIT PER TSB
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 24 * * * * * * * 43069
AWS Claim Key: 7581999 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 10167 - * Name: CHAMPION-LINCOLN MERCURY Ph: 281-8904000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2005 Doc #:206002B
Cust Comments: CUSTOMER ASSURANCE
Tech Comments: CUSTOMER ASSURANCE TEST DROVE
AWS Claim Key: 7581998 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 10167 - * Name: CHAMPION-LINCOLN MERCURY Ph: 281-8904000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2005 Doc #:206002A
Cust Comments: A99 RECALL 05E15 EXHAUST PRESSURE SENSOR
Tech Comments: 43069 RECALL 05E15F 1.0+ 59B01A 0.3 REPLACE EP SENSOR AND RECALIBRATE CONTROL MODULES PER RECALL. ROAD TEST AFTER REPAIR PER BULLITEN.
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 28 1H03 030008 4C3Z 9F452 A E29 42 49186
AWS Claim Key: 8918153 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 03262 - * Name: LAWRENCE MARSHALL FORD-MERCURY Ph: 979-8268026 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:92469903
Cust Comments: CLIENT STATES THE SERVICE ENGINE SOON LIGHT IS ON AND RUNS ROUGH ADVISE
Tech Comments: 9F452 CCN 42 DIAG DIESEL ENGINE PREFORMANCE TEST 1 15 CHECK AIR AND OIL AERATION TESTS CHECK FUEL PRESSURE AND FOUND CODE P0404 P0401 PIN POINT TEST AND CHECK EGR VALVE PID.FOUND VALVE STICKING ,REPLACE VALVE AND RETEST SYSTEM ,MONITOR PIDS FOUND BARO SENSOR OUT OF RANGE AT 155 MZ.REPLACE SENSOR AND RETEST SYSTEM ,REPROGRAM MODULES AND ROAD TEST OK
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 28 3A15 0701XX 4C3Z 7G383 AA P59 42 49186
AWS Claim Key: 8948447 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 03262 - * Name: LAWRENCE MARSHALL FORD-MERCURY Ph: 979-8268026 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:92469901
Cust Comments: CLIENT STATES THE TRANS SHIFTS HARD AND WILL NOT SHIFT PAST 3RD GEAR ADVISE
Tech Comments: 7G383 CCN 42 DIAG TRANS AND INSTALL TESTER,FOUND CODE P0730 PIN POINT TES AND MONITOR PIDS.FOUND ERATIC PRESSURE.R R PAN AND CHECK INTERNAL HARNESS LOOSE CONNECTORS AND PRESSURE SOLENIOD OUT OF SPECS.REPLACE INTERNAL HARNESS AND SOLENOID ASSY CLEAN AND INSPECT VALVE BODY .REFILL AND ROAD TEST OK
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 35 2E05 100106 6C3Z 9B249 A G29 42 58388
AWS Claim Key: 10343948 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2006 Doc #:38030402
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT KEEPS COMING ON IN MESSAGE CENTER EVEN AFTER DRAINED COMES ON AND OFF
Tech Comments: 9B249 42 VERIFIED CONCNER DRAINED FUEL SEPERATOR. LIGHT STILL ON BCE DIAG DTC P2269. PINPOINT TEST FOUND OPEN IN FUEL HEADER. REPLACED FUEL HEADER AND CLEARED CODES. RETEST NO CONCENRS.
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 41 1H03 030008 3C3Z 9P458 AA L87 D8 75505
AWS Claim Key: 11315540 Trx Code: E72 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2007 Doc #:39953703
Cust Comments: CUSTOMER STATES IS HAVING TO ADD COOLANT AT LEAST ONCE A WEEK
Tech Comments: 9P456 42 VERIFIED CONCERN PRESSURE TEST . FOUND COOLANT LEAKING FROM OIL COOLER TO EGR COOLER CONNECTION. REMOVED INTAKE AND FOUN CRAKCED HOUNSING ON OIL COOLER COOLANT PASSAGE. REPLACED HOU SING AMD ORINGS. RESTORED VEHICLE AND ROADTEST. NO LEAKS AFT ER REPAIRS.
1FTSW31P64EB19264 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-OCT-2003 26-NOV-2003 152024 USA 41 1B03 030204 3C3Z 6A642 AA L87 42 75865
AWS Claim Key: 11368971 Trx Code: E72 Labor Hrs: 16.5
Dlr Cd-Sub Cd: 02091 - * Name: PLANET FORD Ph: 281-7193700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2007 Doc #:40059803
Cust Comments: CUSTOMER STATES VEHICLE IS LEAKING COOLANT AGAIN AND GOT HOT ON TEMP GAUGE WHILE DRIVING
Tech Comments: 6A642 55 9P456 D8 VERIFIED CONCERN PRESSURE TEST COOLING SYSTEM. NO LEAKS FOU D ROADTEST MONITORED PIDS FOUND ECT AT 188 AND EOT AT 221. VERIFIED RESTRICTED OIL COOLER . R&R INTAKE AND TURBO TO REP LACE OIL COOLER. REPLACED OIL COOLER AND RESTORED VEHICLE. ROADTEST VEHICLE RUNS POORLY AND SMOKES. RETEST PERFORMANCE DIAG. FOUND EGR VALVE WET AND FULL OF CARBON. FOUND COOLANT
