Standard Claims List For Model Year 2004
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 0 6P07 010301 * 3820125 * B15 07 144
AWS Claim Key: 2126304 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 06204 - * Name: COURTESY AUTO & TRUCK CENTER, INC. Ph: 715-6695517 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2004 Doc #:10435401
Cust Comments: DRIVERS DOOR SHUTS HARD
Tech Comments: ADJUSTED DOOR AND LATCH AND TESTED FOR WIND NOISE
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 3 5B03 050301 F81Z 3222 FA P82 42 4182
AWS Claim Key: 3326198 Trx Code: 2 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2005 Doc #:059989A
Cust Comments: CHECK FOR A GRINDING NOISE WHEN GOING INTO 4X4 ON THE FLY
Tech Comments: TEST DROVE GEAR NOISE IN 4 4. 4 4 GRIDES WHEN GO IN TO4 4. DIASSEMBLE OF FRONT END. SET PINON UP WITH NEW GEARS. REPLACED RING GEAR. SET BACK LASH. RIGHT SIDE AXLE SNAP RING CUTTING IN TO HUB. REPLACED HUB AND WASHER AND SNAP RING. TEST DROVE OK.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 5 5V01 050301 3C3Z 1104 BA K03 69 10774
AWS Claim Key: 4336700 Trx Code: 2 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2005 Doc #:060857C
Cust Comments: CUSTOMER STATES THAT HEAR A GRINDING NOISE WHEN THEY PUT THE TRUCK IN 4X4
Tech Comments: LEFT SIDE HUB MAKING NOISE. REPLACED LEFT SIDE HUB.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 5 3A03 * * * * * * 10774
AWS Claim Key: 4336699 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2005 Doc #:060857B
Cust Comments: PERFORM OPEN RECALL FOR REVERSE PLANET
Tech Comments: REMOVED TRANS AND INSPECT. INSTALL NUMBER ONE KIT. REASSEMBLE TRANS AND FILL. TEST DROVE .
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 5 5A12 050201 TCAA 1244 A K03 07 10774
AWS Claim Key: 4336701 Trx Code: 2 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2005 Doc #:060857D
Cust Comments: CUSTOMER STATES THAT THE HAVE A HOWLING NOISE IN THE FRONT END
Tech Comments: TEST DROVE 4 4 FRONT END HOWLS. SET PINON UP. CHCEK BACK LASH. TEST DROVE.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 15 1H03 030008 4C3Z 9F452 A D42 42 23828
AWS Claim Key: 8025382 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-DEC-2005 Doc #:065870A
Cust Comments: CUSTOMER STATES NO POWER AND BLOWS LOTS OF SMOKE
Tech Comments: EEC TEST P0299 P0404. TEST FOR VGT WORKING PASS. TEST EGR FOR MOVEMENT FAIL. REPLACED EGR. TEST DROVE TO RECHECK PASS.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 18 * * * * * * * 28273
AWS Claim Key: 9065950 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:067326E
Cust Comments: PERFORM RECALL 05S34
Tech Comments: INSTALL FICM WIRING SHEILD KIT.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 18 2H01 * * * * * * 28273
AWS Claim Key: 9053016 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:067326D
Cust Comments: PERFORM RECALL 05B29
Tech Comments: REPLACED AIR INTAKE TUBE.
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 18 7X01 011001 2C3Z 2561710 AA S15 42 28273
AWS Claim Key: 9053015 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:067326A
Cust Comments: CUSTOMER STATES PASS SIDE SEAT WONT GO ALL THE WAY BACK
Tech Comments: CHECK SEAT TRACK FOR OPSTRUCTION NONE. REPLACED SEAT TRACK. RETEST OK.
AWS Claim Key: 9065951 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:067326F
Cust Comments: PERFORM RECALL 05E15
Tech Comments: REPLACED EBP SENSER AND HARNESS. REPROGRAM PCM TCM FICM.
AWS Claim Key: 9065952 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:067326G
Cust Comments: PERFORM RECALL 59B01
Tech Comments: TEST DROVE AFTER PERFORMING RECALLS
1FTSW31P04EC75509 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-MAR-2004 19-OCT-2004 158624 USA 19 1H03 030804 4C3Z 9J460 A E29 42 28813
AWS Claim Key: 9250534 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02638 - * Name: RIVERFRONT FORD MERCURY Ph: 651-3852666 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2006 Doc #:067823A
Cust Comments: CUSTOMER STATES WHILE DRIVING HEARD A POP NOISE AND NOW CHECK ENGINE LIGHT IS ON
Tech Comments: EEC TEST P0473 P2262. PIN POINT TEST FOR CODE P0473. TEST X15 INDUCE OPPOSITE CODE NO. TEST X16 CHECK EB SENSOR SIGNAL FOR SHORT TO VOLTAGE PASS. TEST X17 CHECK EB SENSOR SIG RTN CIRCUIT FOR OPEN. PASS. TEST X18 CHECK THE EB SENSOR BIAS. FAIL. REPLACED EB SENSOR. INSTALL INNER COOLER TUBE. PIN POINT TEST FOR P2262. TEST DROVE MGP 24. PASS.
