Good morning,
I am looking at an 05 Ford F-350 Lariat 4X4 Dually w/ 6.0 ltr. The truck has 46K miles.
The VIN: 1FTWX33P35EC05242
Thank you in advance,
Mark
Tow Mater
OASIS RESULT: 1FTWX33P35EC05242
USA: EN-US
03-FEBRUARY-2012 / 12:45:35 / FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 F-SERIES BODY STYLE: F-350 S/CAB PICKUP 4X4 ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT AXLE CODE: 37 ENGINE CALIBRATION: 5F710D0A
PAINT COLOR: MEDIUM WEDGEWOOD BLUE PAINT CODE: LD RADIO: ELETR PREM AM/FM STRO/DISC
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 17 X 6.5 ALUM - MCHND FINISH FRONT TIRE: LT245/75/R17E A/T OWL
GROSS VEHICLE WEIGHT: 13,000 LB. GVW
WARNING MESSAGES
Click here for CUDL
CUDL - DIGITAL IMAGING/RTDA DENIED A WARRANTY REPAIR. SEE CUDL FOR DETAILS
ACCURATE REPAIR NOTIFICATIONS
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 01-FEBRUARY-2005 BUILD DATE: 23-JANUARY-2005 SALE MILEAGE: 00012
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
Competitive make ESP part verification
0968 - USA 2010 USED 36/36,000 PREMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD OWNER NAME: ROY GENDREAU OPTIONS:
EXPIRATION DATE: 05-MARCH-2013 DISTANCE: 75989 RENTAL: 30 UP TO 10 DAYS
TOWING: 0 USD CONTRACT SOLD BY: USA 09137 ESP CONTRACT START DATE: 05-MARCH-2010
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
0701 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD OWNER NAME: CHARLES DIEMER JR OPTIONS:
EXPIRATION DATE: 01-FEBRUARY-2010 DISTANCE: 75000 RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD CONTRACT SOLD BY: USA 48996 ESP CONTRACT START DATE: 01-FEBRUARY-2005
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTWX33P35EC05242
Tow Mater
VIN 1FTWX33P35EC05242
Vehicle Line T/F7 Market Derived Code F
Body Cab T/BD Ver. Series T/CD
Drive Type T/E
PLT CD A1 TRS CD T/BE ENG CD T/YB
Production Date 23-JAN-05 Warranty Start Date 01-FEB-05
Selling Dealer 111060 Selling Country USA
AWS Claim Key Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 1095314 5 1.1 SARAT FORD LINCOLN 2861 06-JUN-05 * 3820124 * 22278901
Customer Comments ALIGN ALL FOUR DOORS
Tech Comments 1 ALIGN ALL FOUR DOORS AT HINGES AND STRIKERS
Details 1332151 5 2.4 SARAT FORD LINCOLN 2861 06-JUN-05 3C3Z 6700 BA 22280302
Customer Comments OIL LEAK FROM ENGINE AREA
Tech Comments PERFORMER ENGINE OIL DYE TEST AND FOUND LEAK AT FRONT COVER SEAL BEHIND DAMPER REPLACED FRONT COVER SEAL AND RETESTED DRY AFTER HIGHWAY DRIVE
Details 1105042 5 1 SARAT FORD LINCOLN 2861 06-JUN-05 * FRONT * 22280303
Customer Comments STEERING WHEEL OFF CENTER
Tech Comments CENTERED STEERING WHEEL
Details 1105043 5 3.6 SARAT FORD LINCOLN 2861 06-JUN-05 3C3Z 4R602 CW 22280301
Customer Comments VIBRATION FELT AT ANY SPEED BUT MAINLY HIGHWAY CUSTOMER THINKS TIRES ARE OUT OF BALANCE
Tech Comments PERFORMED NVH DIAG WITH VETRONICS TESTER ROAD TESTED FOUND 32 36 HZ VIBRATION CHECKED DRIVESHAFT RUNOUT FOUND .020 AT REAR OF SHAFT TRIED TO INDEX AND BALANCE SHAFT NO HELP ORDERED NEW DRIVE SHAFT REPACED DRIVE SHAFT AND REINDEXED NEW DRIVESHAFT PERFORMED FINAL ROAD TEST VIBRATION GONE
Details 2015545 8 .3 SARAT FORD LINCOLN 6871 26-SEP-05 5C3Z 3E651 CA 22999301
Customer Comments FRONT SHOCK LEAKING. SOP PARTS ORDERED UNDER CUST #54476
Tech Comments REPLACED STEERING DAMPNER
Details 2194843 8 1.1 SARAT FORD LINCOLN 6871 27-SEP-05 * 3820124 * 23005801
Customer Comments ADJUST ALL FOUR DOORS
Tech Comments 1 ADJUST ALL DOORS
Details 3731716 13 .2 SARAT FORD LINCOLN 9114 22-FEB-06 * * * 23864603
Customer Comments PERFORM RECALL 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments 1 LOWERED LEVEL IN D GAS BOTTLE APPLIED STICKER.
Details 3731717 13 .7 SARAT FORD LINCOLN 9114 22-FEB-06 * * * 23864602
Customer Comments RECALL 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments RECALIBRATED PCM,FICM AND TCM.
Details 3731715 13 .4 SARAT FORD LINCOLN 9114 22-FEB-06 6C3Z 6C646 AA 23864601
Customer Comments LEAK FROM PASSENGER SIDE FRONT OF ENGINE BEHIND RADIATOR CAP LEAKING LOOKS LIKE TRANY FLUID
Tech Comments INSPECTED FOUND OIL LEAKING FROM PASSENGER SIDE CAC TUBE. REPLACED PASSENGER SIDE CAC TUBE.
Details 4613208 16 0 SARAT FORD LINCOLN 9830 10-MAY-06 5C3Z 2825532 AAN 24326401
Customer Comments CUSTOMER STATES: MOULDINGS CRACKING
Tech Comments SPW(OTC) R& R MOULDINGS
Details 5013668 17 1.1 SARAT FORD LINCOLN 11121 14-JUN-06 5C3Z 2553 B 24507501
Customer Comments DRIVERS SIDE REAR BRAKES, GET VERY HOT
Tech Comments REPLACED DRIVERS REAR CALIPER AND PADS BLED BRAKES ALL OK NOW
Details 5550143 19 2.9 DEALMAKER FORD, INC. 13005 09-AUG-06 5C3Z 6F089 A 18925101
Customer Comments CUST STATES CK ENG LITE IS ON VEH RUNS GOOD
Tech Comments ROADTEST AND VERFIY CONCERN PERFORM D DIOG GUID SHEET PERFORM KOER KOEO RETRIEVE DTC FOR UNDERBOOST PO299 MONITIRO PIDS PERFROM BOSST PRESSURE TEST PERFORMED 3 ACTIVE COMMANDS FOR VGT SOILINOID FOUND VGT NOT RESPONDING LIKE NORMAL,ACCES CAM PLUG ON TOP OF TURBO ACTIAVTE VGT CAM MOVES NORMAL NOT STICKING AT THIS TIME
Details 5726324 20 2.6 SARAT FORD LINCOLN 14200 29-AUG-06 5C3Z 6K682 DA 24935702
Customer Comments CHECK ENGINE LIGHT ON, DIAGNOSE AND ADVISE.
Tech Comments ENGINE LIGHT IS ON PDS TESTED GOT CODE P0299 TURBO UNDERBOOST FOUND TURBO VANES STICKING R R TURBO CLEARED CODE ALL OK NOW
Details 5935580 20 .2 SARAT FORD LINCOLN 14200 29-AUG-06 5C3Z 16720 NA 24936401
Customer Comments CUST STATES PASS EMBLEM IS PEELING
Tech Comments INSTALLED NEW EMBLEM
Details 8176811 30 2.4 SARAT FORD LINCOLN 22775 16-JUL-07 5C3Z 3050 AB 26614202
Customer Comments RIGHT FRONT BALL JOINT LOOSE
Tech Comments CHECK FRT. END LEFT SIDE BALL JOINTS LOOSE REPLACE UPPER AND LOWER BALL JOINTS 4X4, DUALLY
Details 8434649 32 .3 SARAT FORD LINCOLN 23907 20-AUG-07 6C3Z 6C640 A 26806402
Customer Comments BLUE TURBO HOSE DOES NOT SEEM SECURE
Tech Comments REPLACED HOT SIDE CAC TUBE AND CLAMPS ALL OK NOW
Details 9054148 35 .4 SARAT FORD LINCOLN 25881 27-NOV-07 2C3Z 1700 CA 27390103
Customer Comments DRIVERS SIDE FRONT TIRE SLOW LEAK
Tech Comments REMOVED AND REPLACED LEFT FRONT VALVE STEM
Details 9054149 35 .5 SARAT FORD LINCOLN 25881 27-NOV-07 8C3Z 12K073 A 27390102
Customer Comments OIL LEAK REAR MAIN SEEPING ? IF THIS IS DONE AND OIL IS CHANGED THEN MAKE SURE A NEW OIL FILTER IS PUT ON
Tech Comments INSPECTED FOUND OIL LEAKING FROM LEFT SIDE OF ENGINE AND FOUND CAM SENSOR LEAKING. REMOVED AND REPLACED CAM SENSOR CLEANED OFF ENGINE AND ROAD TESTED AND RECHECKED OK.
Details 10263817 43 1.5 SARAT FORD LINCOLN 30319 06-AUG-08 8C3Z 2B120 C 28896101
Customer Comments CUSTOMER STATES FRONT WHEELS BINDING.CUST THINKS BRAKES HANGING UP. ADVISE
Tech Comments REMOVED FRONT CALIPERS ATTEMPTED TO COMPRESS PISTONS, COULD NOT FROZEN, REPLACED FRONT CALIPERS, TURNED ROTORS AND REPLACED PADS, BLEED BRAKE SYSTEM, RE ROADTESTED ALL OKAY
Details 10728578 49 1.2 SARAT FORD LINCOLN 32739 19-JAN-09 5C3Z 3254 AA 29850503
Customer Comments 4X4 AUTO HUBS ARE NOT LOCKING IN WHEN IN AUTO MODE CAN HEAR A WHISTLING NOISE AT TIMES
Tech Comments VAC TESTED BOTH FRONT WHEELS FOUND LF NOT HOLDING VAC REMOVED LF HUB AND BEARING ASSY REPLACED BLUE VAC HUB SEAL, DUST SEAL, AND O RING VAC TESTED AGAIN PULLED VAC AND 4X4 AUTO WORKING CORRECTLY ALL OK NOW
Details 11113681 55 2.4 SARAT FORD LINCOLN 37596 04-AUG-09 5C3Z 2552 B 31091701
Customer Comments GETTING A VIBRATION WHEN BRAKING FROM REAR DRIVERS SIDE BRAKE. PLEASE CHECK ALL
Tech Comments FOUND BOTH REAR CALIPERS FROZEN, ALSO ROTORS ARE UNDER 36MM SPEC, REMOVED REAR ROTORS AND FOUND BOTH BACKING PLATES HAD COME APART, REPLACED BOTH BACKING PLATES, ROTORS, AXLE SEALS, AND CALIPERS, BLED BRAKES, DROVE VEHICLE CAN FEEL VIBRATION FROM FRONT BRAKES, ROTORS UNDER 36MM SPEC FOUND BOTH FRONT CALIPER PINS FROZEN, REMOVED BOTH FRONT
Details 11556667 67 2.3 BILL SELIG FORD, INC. 42121 20-JUL-10 4C3Z 9B246 E 01558804
Customer Comments FUEL/DRIVEABILITY HARD START WHEN ENGINE IS HOT
Tech Comments VERIFIED CUSTOMER CONCERN. PERFORMED EEC TEST AND FOUND ICP 210 PSI HOT. PERFORMED TSB 08 18 6. PERFORMED AIR PRESSURE TEST ON HIGH PRESSURE OIL SYSTEM. FOUND LEAK IN REAR OF ENGINE. FOUND STC FITTING LEAKING. REMOVED AND REPLACED STC FITTING AND RETESTED GOOD.
Details 11556666 67 7.4 BILL SELIG FORD, INC. 42121 20-JUL-10 3C3Z 6A642 CA 01558802
Customer Comments CHECK ENGINE LIGHT IS ON FORD DEALER IN UPSTATE NY SAYS IT NEEDS OIL COOLER
Tech Comments PERFORMED EEC TEST AND FOUND CODE P012F. ROAD TESTED AND MONITORED PIDS. FOUND BAD OIL COOLER. REMOVED AND REPLACED OIL COOLER. RETESTED AND ROAD TESTED GOOD.
Reactions: RETTROOPER
Many Thanks Buckshot!
Thank You Buckshot! I was about to seriously consider pulling the trigger on this truck. Now that I've seen the Oasis on it, I am RUNNING away from it.
Thanks so much!
PS Would you mind running another one for me? If you can, I'd certainly appreciate it. I'll post the VIN here as well as on the Oasis Request page.
VIN: 1FTWW33P76EB01289
Oasis Request
Hello, I am looking possibly purchasing a:
2006 Ford F-350 Crew Cab 4X4 Dually w/6.0 Liter.
The VIN is:
1FTWW33P76EB01289
I am requesting an Oasis Report.
Thanks in advance!
Mark
Many thanks Stuntman!
I appreciate your quick response to this request. Confirms my initial suspicions that there are some really good people on this site. Again, Stuntman I really appreciate what you did. Going to go look at the truck tomorrow at the dealership. Keep your fingers crossed!
Mark :rock
Good Luck!
