Hello.
I am new to diesels but I found one I fell in love with.
If I could get an oasis report on it I sure would appreciate it.
It has a 6.4 in it and I have been reading not to favorable things
about them .
THANK YOU VERY MUCH.
Vin: 1FTSW21R48EA23490
[email protected]
OASIS RESULT: 1FTSW21R48EA23490 USA: EN 16-JANUARY-2013 / 05:43:46 EST/ APP2
Local Time: 16-JANUARY-2013 / 3:43:50 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.4L Diesel V8 Twin Turbo
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 8F716A0A
PAINT COLOR: Dark Blue Pearl W/B
PAINT CODE: DX
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 8 X 20" Prem Forged Pol Alum Wheel
FRONT TIRE: LT275/65R 20E A/T OWL Tire
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Comments 07S49 POWERTRAIN CONTROL MODULE RECALIBRATION RECALL.
Tech Comments REPROGRAM PCM PER RECALL.
Customer Comments CHECK COOLANT LEAK AT LEFT SIDE OF RADIATOR AREA.
Tech Comments VERIFY AND PRESSURE TEST FOR LEAKS. FOUND SEAM LEAKING BETWEEN THE TOP TANK AND RADIATOR CORE ON LEFT END OF TANK. REPLACE RADIATOR TO REPAIR. ADD NEW COOLANT. FILL AND ROAD TESTED. RECHECK FOR LEAKS. OK.
Customer Comments BATTERY LIGHT CAME ON AND LIGHTS SURGED. HIGH BEAMS QUIT.
Tech Comments VERIFY AND DIAGNOSE CONCERN. CHECK CHARGING SYSTEM. OK. REPLACE BOTH HEADLIGHT BULBS TO REPAIR. RECHECK OPERATION. OK.
Customer Comments CHECK LEFT REAR TURN SIGNAL INOP.
Tech Comments VERIFY AND DIAGNOSE CONCERN. REPLACE LEFT REAR TUN SIGNAL BULB TO REPAIR. RECHECK OPERATION. OK.
Customer Comments 08C01 FRONT DRIVERS SEAT BACK INSPECTION AND REPAIR RECALL.
Tech Comments INSPECT AND INSTALL CLAMP PER RECALL.
Customer Comments 08C04 STOPPER BRACKET INSTALLATION RECALL.
Tech Comments INSTALL FUEL TANK BRACKET PER RECALL.
Customer Comments 08B06 COOLING SYSTEM VENTURI TEE INSPECTION RECALL.
Tech Comments INSPECT AND FOUND VENTURI TEE ALREADY INSTALED PER RECALL.
Customer Comments CHECK FOR COOLANT LEAK.
Tech Comments VERIFY AND PRESSURE TEST FOR LEAKS. FOUND RADIATOR LEAKING. REPLACE RADIATOR ASSEMBLY TO REPAIR. ADD COOLANT. ROAD AND RETESTED FOR LEAKS. OK.
Customer Comments 07B07 REPROGRAM PCM AND IC RECALL.
Tech Comments REPROGRAM PCM, TCM AND IC PER RECALL.
Customer Comments RECALL 11B23 PCM RECALL
Tech Comments REPROGRAM MODULES PER RECALL
