Hi,
OASIS RESULT:
1FMSU43P83EC08188
08/28/2006
10:29:40
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
3L11ON0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/03/2003 BUILD DATE
02/04/2003 SALE MILEAGE
WARNING MESSAGES
NOT ELIGIBLE FOR DEALER APPROVED AWA; TWO PAID REPAIR VISITS
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
07/19/2006
DEALER: McCoy & Mills Ford
WARRANTY CLAIM NUMBER: 918498 ODOMETER: 055050M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 12650D81
000 9838A
ENG BUCK AD JERKS ON ACC ICP SENSOR PERFORM ENG DIAG TO STEP 20 PASS CODES ROAD TEST AND MONIT OR PIDS ICP PID ERRATIC REPL ICP SENSOR ROAD TE ST OK
06/19/2006
WARRANTY CLAIM NUMBER: 916587 ODOMETER: 053805M
LABOR OP
CONDITION CODE
CONDITION DESC
3C7Z 8620AC BELT-W/PUMP FAN&GENE 001 6209A 69 FROZEN/SEIZED/BINDING
3C2Z 6B209AA TENSIONER FEAD ASSY 001
BURNING SMELL; BELT TENSIONER. DIAG SMELL BELT SLIPPING, TENSIONER FROZE UP ; NO TENSION ON BEL T. REPL TENSINER AND BELT, DAMAGED FROM SLIPPIN G
04/07/2006
WARRANTY CLAIM NUMBER: 912307 ODOMETER: 050422M
LABOR OP
CONDITION CODE
CONDITION DESC
2C7Z 14C708BA PROCESSOR ASY-REG CN 001 13300D 42 DOES NOT OPERATE PROPERLY
000 14200A
000 14200A1
000 14526AT
000 61704AC
000 MT14C708
LF POWER SEAT INOP SWITCH WIRE GROUNDED ON SEAT TRACK DAMAGED DRIVERS SEAT MODULE TEST SWITCH AND CIRCUITRY FOR LF POWER SEAT HOOK UP VCM NO COMMUNICA TION ON WITH DSM REMOVE SEAT FOUND CHA FFED WIRES ONS EAT TRACK REMOVE TRAC K TO REPAIR AND REROUTE WIRES MT TO REPL AND REPROGRAM DRI VER SEAT MODULE NO LABOR TIME AVAILABLE ALSO RE PL POPPED FUSE FOR MEMORY SEAT SWITCH THAT
12/14/2005
WARRANTY CLAIM NUMBER: 905515 ODOMETER: 044361M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6005E 42 DOES NOT OPERATE PROPERLY
PM 15 001 MT6005E1
000 MT6005F1X1
000 9838A
000 12650D45
000 12650D80
CHECK ENGINE LIGHT ON ICP SENSOR LOW PERFORM DI AG CODE 0341-2285 PID MONIT OR ICP .13 VOLT SPEC .18 REPLACE ICP SENSOR PIN POINT TEST FOR CODE 0341 - WIGGLE TEST UNABLE TO DUPLICATE - CLEARE D CODES AND ROAD TEST OK
12/14/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C7Z 19980AB CONTROL A/C 001 12651D 28 OPEN CIRCUIT
000 12651D2
000 19700D1
000 19980A
000 04320B
AIR COND CONTROL BLANK AT TIMES TEST NO CODES D ASH ACCESS TO TEST WIRING F ROM AC CONTROL HEAD TO FUSE PANEL WH-UT AND LB-BK OPEN CIRCUIT IN A C CENTE R HEAD
12/14/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 002 9527AT 42 DOES NOT OPERATE PROPERLY
000 6005F33
ENGINE RUNS ROUGH PERFORM INJECTOR TEST #4 AND #5 CYLINDER LOW REPLACE BOTH INJECTORS
08/25/2005
WARRANTY CLAIM NUMBER: 998636 ODOMETER: 035789M
LABOR OP
CONDITION CODE
CONDITION DESC
3C7Z 14A068CA FUSE PANEL 001 12651D 42 DOES NOT OPERATE PROPERLY
000 12651D2
000 04320B
000 04470A
000 19980A
CLIMATE CTRL UNIT INOP AT TIMES TEST A-C CTRL H EAD NO CODES R&R FINISH PAN EL AND CTRL HEAD TES T CIRCUITS PROBLEM WITH INSTRUMENT FUSE PANEL R EPL DAS H FUSE PANEL
08/25/2005
LABOR OP
CONDITION CODE
CONDITION DESC
D7TZ 13466A SMALL BULBS 003 13300D 28 OPEN CIRCUIT
000 13465AT
3RD BRAKE LAMP INOP DIAG AND TEST CIRCUITS OPEN CIRCUIT IN BULBS REPL ALL 3 BRAKE LAMP BULBS
END OF OASIS REPORT FOR 1FMSU43P83EC08188
Thanks,
Vivian
