Could I please get a copy of the OASIS for Vin # 1FTSX31P74EB68521
Thanks
Tony M:thanks:
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
09/11/2006
DEALER: Dams Ford Lincoln Sales Ltd.
WARRANTY CLAIM NUMBER: 299912 ODOMETER: 028603K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089A ACTUATOR ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F11
000 6005F12
000 6005F14
000 6005F18
000 6005F19
000 6005F21
000 6005F25
000 VERIFY60
VERIFY COMPLAINT;PERFORM OASIS NO 111 405 649;KOEO PASS; KOER PASS;CMDTC P02 31;P0299;P0404;P0478;P2262;TEST FUELPRESSURE LOW;REPLACE FUEL FILTERS;TEST B OOST RESULTS 26PSI ON HIGHWAY. DROPPED OFF INTERMITTENTLY UNDER LOAD UP HILL S TO 20PSI. TEST AND REPLACE VGT. VERIFY REPAIR.
06/28/2006
DEALER: Sunrise Ford Sales Ltd
WARRANTY CLAIM NUMBER: 020795 ODOMETER: 025459K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6C640AA CONNECTION A/C DUCT 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 6K769DA DUCT A COOLER 001 6005F13
6C2Z 6K786AA CLAMP AIR COOLING 002 6005F1
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F19
000 6005F23
000 6005F22
000 6005F9
000 6005F21
000 6646AT
COMPLETE ENGINE DIAG SHEET, PERFORM PPT AK/KA, PC/ED MANUAL AND FOUND KA10 T O HAVE 30-40% BEFORE CAM MOVEMENT. CALL HOT LINE, TURBO ON ORDER, NO STOCK CDN OR USA AT THIS TIME, CUSTOMER TOOK TRUCK UNITL UN IT SHOWS UP.
05/29/2006
WARRANTY CLAIM NUMBER: 020512 ODOMETER: 024833K
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6K786EA CLAMP AIR COOLING 001 6005F 42 DOES NOT OPERATE PROPERLY
3L3Z 12B579AB SENSOR EEC MASS AIR 001 6005F13
000 6005F1
000 6005F2
000 6005F14
000 6005F20
000 MT6464
000 12650D30
000 MT12B579
INSPECT FOR LACK POWER, ORDER PARTS CAC OFF,SCAN AND RECORD CODES MAF SENSOR ORDER AND REPLACE MAF SENSOR, REMOVE CAC TUBES AND CLEAN AND REASSE MBLE, ROAD TEST AND ALL SEEMS FINE AT THIS TIME.
05/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
1F1Z 19E889AB O RING - A/C COMP 002 19700A D8 FAILED GASKET/SEAL
OSP 045 19700A3
DYE 001 19700A4
19E889 O RING - A/C COMP 000
INSPECT AND PERFORM SSM18674, SYSTEM LOW IN FREON, NITROGEN CHANGE AND FOUND L EAK,AT COMPRESSOR MANIFOLD, RE AND RE COMPRESSOR ASSEMBLY AND REPLACE O R INGS AT MANIFOLD ASSEMBLY, REASSEMBLE AND RECHARGE SYSTEM AND INSTALL AC DY E. TEST SYSTEM COOLING TO 41'F GOOD.
05/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7821537AA RUN-DOOR GLASS UPPER 001 MT21537 33 LOOSE PART
REMOVE TRIM PANEL AND REPLACE LEFT FRONT WINDOW TRACK ASSEMBLY AND REINSTALL TRIM PANEL.
05/12/2006
WARRANTY CLAIM NUMBER: 001656 ODOMETER: 024348K
LABOR OP
CONDITION CODE
CONDITION DESC
9920124 DOOR ASY-FRONT 000 20124A 07 IMPROPERLY ADJUSTED/FITS POORLY
000 24630A
000 MT16005
CHECKED OUT DOORS, YES THEY ARE TOUCHING, LOOSEN LEFT FRONT FENDER BOTTOM AN D REALIGN LEFT FRONT DOOR AND THEN REALIGN LEFT REAR DOOR, ALL FINE AT THIS TIME.
04/04/2006
WARRANTY CLAIM NUMBER: 286206 ODOMETER: 022979K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6775A D8 FAILED GASKET/SEAL
3C3Z 6D083AA GASKET-RR COVER 001 6700A
3C3Z 6020CA GASKET CYL TIMING GE 001 6646AT
3C3Z 6710BA GASKET SET-OIL PAN 001 6209A
3C3Z 6626AA SCREEN OIL PUMP 001 6007D
3C3Z 6753AA GASKET OIL LEVEL IND 001 6007A
5C3Z 6N639AA TUBE TURBO OIL SUPLY 001 17757A
3C3Z 6C315AA SENSOR CRANK TIMING 001 9438A3
W300024 004 12650D30
3C3Z 9N693HA RING-SEALING 001 12650D57
3C3Z 9N693JA RING-SEALING 001 MT6007A38
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001 MT6007
3C3Z 6619FA GASKET (OIL PUMP) 001 MT16738
3C3Z 6731AA ELEMENT ASY OIL FILT 001 MT7000A
CXO 10W30LSD12 003 MT6701
CXO 10W304LSD 003 MT6781AUP
W300013 004 4602A
W300051 004 VERIFY60
F81Z 8287EA CLAMP ASY-RAD HOSE 001
CVC 7A 001
6C2Z 6K786AA CLAMP AIR COOLING 001
4C3Z 9F452A TRANSDCR-EGR BACK PR 001
3C3Z 6710AA GASKET SET-OIL PAN 002
3C3Z 6710CA GASKET SET-OIL PAN 001
3C3Z 6N640AA GASKET TURBO TO MANI 001
3C3Z 16738BD INSULATOR HOOD 001
DYE 003
MT7000 TO REMOVE OVERLAP TIME WHEN REMIOVEING TRANS. MT6781 TO REMOVE OVERLA P TIME WHEN REPLACING OIL PAN GASKETS. MT6701 TO REMOVE OVERLAP WHEN REPLACI NG REAR MAIN SEAL.S, UPPER AND LOWER OIL PANS AND BED PLATE SEAL. ALSO REPLA CED TURBO PEDISTAL FOR CHUCK MISSING FROM EAR. REPLACED CLOGGED EGR VALVE. R EPLACED CRANK POSITION SENSOR FOR BEING BREAKING APART INSIDE BED PLATE. HAD
04/04/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F836BA PEDAL & SENSOR ASY 001 9758A 33 LOOSE PART
REPLACED ACCEL. PEDAL ASSY
END OF OASIS REPORT FOR 1FTSX31P74EB68521
:thanks: Thank you for the info.
Not a problem.
