VIN #1FTNW21F43EA21380
Can someone run an Oasis report on this truck please, thank you very much.
TWH
OASIS RESULT:
1FTNW21F43EA21380
USA
EN
07/15/2009
11:00:14
FCXWS447
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/24/2002 BUILD DATE
08/01/2002 SALE MILEAGE
00644
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 0 6Y06 100107 * FUEL * A96 51 27
AWS Claim Key: 36018 Trx Code: L63 Labor Hrs: 0
Dlr Cd-Sub Cd: 01681 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 541-9632161 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2002 Doc #:05949301
Cust Comments: VEHICLE WAS SHORT 8 GALLON OF FUEL
Tech Comments: PUT 8 GALLONS OF FUEL IN TANK
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 6 * * * * * * * 16258
AWS Claim Key: 890661 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:046959B
Cust Comments: W CAMP 03B03
Tech Comments: 03B03 OWNER NOTIFICATION LETTER
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 6 2B01 030701 F7TZ 12K073 A D21 42 16258
AWS Claim Key: 890660 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 08301 - * Name: MOUNTAIN HOME AUTO RANCH Ph: 208-5873326 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:046959A
Cust Comments: W CUST STATES ENGINE HAS DIED 6 TIMES,THEN RESTARTS OK,MAINLY WHILE DRIVING BUT ONCE AT IDLE,FUEL AND CHECK ENGINE LIGHT COME ON
Tech Comments: COMPLETE ENGINE PERFORMANCE DIAG, NO FAULTS FOUND COULD NOT DUPLICATE, TEST DRIVE MANY TIMES, FINALLY WAS ABLE TO DUPLICATE PROBLEM, BUT STILL NO CODES WERE SET REPLACE CAM SENSOR
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 40 2I04 030008 F7TZ 12B533 CA D03 28 95071
AWS Claim Key: 12958966 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08325 - * Name: DAN WIEBOLD FORD Ph: 208-4664615 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2006 Doc #:08920212
Cust Comments: HARD TO START AND SMOKES
Tech Comments: DIAG HARD START & FOUND DEFECTIVE GLOW PLUG RELAY CON. CODE 28 DIAG GLOW PLUG SYSTEM & REPLACED DEFECTIVE GLOW PLUG RELAY QC. OPEN CIRCUIT
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 40 2E03 030008 F81Z 9C968 AB D42 42 95071
AWS Claim Key: 12958967 Trx Code: E72 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08325 - * Name: DAN WIEBOLD FORD Ph: 208-4664615 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2006 Doc #:08920211
Cust Comments: CHECK POOR RUN AND ENGINE NOISE
Tech Comments: RUN DIAG SHEET & GOT CODE 1211 & MONITORED PIDS & EBP WAS HIGH AT 16.5 DEFECTIVE IPR VALVE & EBP SENSOR CON. CODE 42 RUN DIAG SHEET & REPLACED DEFECTIVE EBP SENSOR & IPR VALVE & CLEARED CODES & ROAD TESTED QC
1FTNW21F43EA21380 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 01-AUG-2002 24-OCT-2002 156600 USA 67 * * * * * * * 122008
AWS Claim Key: 15925308 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08325 - * Name: DAN WIEBOLD FORD Ph: 208-4664615 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2008 Doc #:15724301
Cust Comments: 07S57 RECALL
Tech Comments: RECALL REPLACED CAMSHAFT SENSOR
Reactions: TWHRanch
