My VIN is 1FTSW21R88EA73664
thank you very much,
Standard Claims List For Model Year 2008
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 2 7D01 170101 7C3Z 13008 BA L29 42 515
AWS Claim Key: 102176 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2007 Doc #:163496A
Cust Comments: CUST STATES BOTH HEADLIGHTS FOGGED UP
Tech Comments: VERIFIED AND REPLACED BOTH LAMP ASSEMBLIES AND RECHECK OP MT TIME NO LABOR STUDY TIME
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 12 2E02 * * * * * * 13513
AWS Claim Key: 1008109 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2008 Doc #:174959B
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 12 6E01 * * * * * * 13513
AWS Claim Key: 1008108 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2008 Doc #:174959A
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 17 1F01 * * * * * * 19805
AWS Claim Key: 2291431 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2008 Doc #:003197A
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 19 2G01 * * * * * * 23197
AWS Claim Key: 2472561 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02744 - * Name: CAMPBELL FORD LINCOLN-MERCURY, INC. Ph: 269-6848300 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2009 Doc #:050899A
Cust Comments: RECALL 08B07
Tech Comments: 23197 DONE IT.
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 25 6F02 011103 F81Z 2521452 AA G02 07 29296
AWS Claim Key: 3928347 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2009 Doc #:009884A
Cust Comments: CUST STATES BOTH FRNT & WINDOWS SCRATCHED
Tech Comments: VERIFIED AND EPLACE BOTH FRONT GLASWS ANS MLDGS PER TSB 07 10 05 AND RECHECK
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 27 6X02 010904 7C3Z 17683 FB L65 01 31516
AWS Claim Key: 4230658 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2009 Doc #:011792A
Cust Comments: CUSTOMER STATES WHEN EXITS VEHICLE DRIVERS SIDE MIRROR GOES UP
Tech Comments: PERFORMED BCE TEST CODE B2324 STORED.PERFORMED PPT D17 OK,D19 NO,D2 0 YES INDICATING MIRROR IS CONCERN REPLACED LEFT MIRROR CLEARED CODES RETEST
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 28 1H03 030008 8C3Z 9E461 A E29 42 33442
AWS Claim Key: 4525208 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 02744 - * Name: CAMPBELL FORD LINCOLN-MERCURY, INC. Ph: 269-6848300 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2009 Doc #:059446A
Cust Comments: CHECK ENGINE LIGHT RUNS ROUGH COLD ENGINE
Tech Comments: 33442 CHECK LACK OF POWER. PERFORM EEC TEST RETRIEVED CODES P0404, P042E, P1335. PERFORM KOER TEST. PEFORM AIR MANAGMENT TEST(EGR) FAILED. CHECK FUEL PSI OK. TEST DROVE CONFIRMED CONCERN EGR VALVE STICKING. TRIED TO EXTRACT EGR VALVE WITH TOOL. TOOL BROKE 2ND TOOL. TRIED REMOVING VARIOUS DIFFERANT WAYS COULD NOT GET OUT SO REPLACED T BODY HOUSING AS WELL. CLEARED CODES
1FTSW21R88EA73664 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 02-JUL-2007 148580 USA 32 6N06 031201 8C3Z 19A414 A D50 55 35847
AWS Claim Key: 5120761 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09629 - * Name: SIEMANS FORD, INC. Ph: 269-4655344 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2010 Doc #:017025A
Cust Comments: CUST STATES KEEPS GETTING MESS. AIR FILTER PLUGGED
Tech Comments: DIAG & ADV PLUGGING W/SNOW TSB#09 6 8 INSTALL GRILL COVER SNOW DEFLECTOR AND REPLACE FILTER MINDER AND FILTER PER TSB COVER MUST BE REMOVED WHEN TEMPS GREATER THAN 50 OR 32 IF TOWING ALSO FUEL ECONOMY WORSE W/COVER ON REPAIR RETEST OK NOW
Reactions: 08smoker08
Thank you sir i appreciate it greatly,!!!!
