OASIS RESULT: 1FTSX31P74EC68604 USA: EN 16-JANUARY-2013 / 05:04:08 EST/ APP1
Local Time: 16-JANUARY-2013 / 3:04:12 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2004 F-SERIES
BODY STYLE: F-350 S/CAB PICKUP 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: D1
ENGINE CALIBRATION: 4F710N0A
PAINT COLOR: Dark Green Satin WB
PAINT CODE: FW
RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.0 X 16" Forged Aluminum Wheel
FRONT TIRE: LT265/75R-16E OWL A-T Tire
GROSS VEHICLE WEIGHT: 9700 LB. GVW
CLAIMS:
Customer Comments DELAYED ENGAGEMENT
Tech Comments HOTLINE I.D. 4CYHX018 VERIFIED CONCERN. CONNECTED WDS AND MONITORED DESIRED LINE PRESSURE AND COMPARED TO ACTUAL LINE PRESSURE. PRESS WAS LOW,ELECT TRANS TST REMOVED VALVE BODY AND SOLONOID PACK REPLACED LINE PRESS SOLONOID REINSTALLED RETEST OK
Customer Comments CHECK FOR OIL LEAK
Tech Comments CHECKED FOR OIL LEAK REPOSTION LOWER INTERCOOLER TUBE AND CLEAN OFF AREA
Customer Comments BRAKE LIGHTS INOP
Tech Comments CHECKED ALL FUSES ARE OK.CKECKED FOR POWER AT TAIL LIGHTS, NONE REPLACE BRAKE LIGHT SWITCH & MUILTIFUCTION SWITCH AND RE TEST OK
Customer Comments 05S34 FUEL INJECTOR CONTROL MODUAL
Tech Comments INSTALLED FICM HARNESS REPAIR KIT, AND REPLACED ICP CONNECTOR. REPROGRAMMED PCM. ROAD TESTED OK.
Customer CommentS RECALL 05B29 CHARGE AIR COOLER DUCT
Tech Comments REPLACED CHARGE AIR DUCT
Customer Comments 05E15 EXHAUST PRESSURE SENSOR
Tech Comments REPLACED EP SENSOR AND CONNECTOR. ALSO PREFORMED CUSTOMER ASSURENCE TEST DRIVE.
Customer Comments 59B01 CUSTOMER ASSURANCE ROAD TEST
Tech Comments PERFORMED ROAD TEST
Customer Comments BANGING OR CLUNK ON BUMPS FROM FRONT END
Tech Comments CHECKED OASIS, NVH DIAG.L,FOUND LOWER BALLJOINTS EXCESS PLAY (OVER 3 16IN) REPLACED LOWER BALLJOINTS, RAOD TESTED.
Customer Comments DRIVERS DOOR OUTSIDE HANDLE INOP
Tech Comments CHECKED OASIS, VISUAL INSPECTION,FOUND OUTER HANDLE SEPERATED , R&I DOOR PANEL, REPLACED L.F. OUTSIDE DOOR HANDLE.
Customer Comments BANGING OR CLUNK ON BUMPS FROM FRONT END. BALL JOINTS LAST RO DID NOT HELP
Tech Comments INSPECTED AND REPLACED FRT SWAY BAR END LINKS AND BUSHINGS
Customer Comments SOP WINDOW REGULATOR TO CORRECT MAKING NOISE AND JUMPING WHEN GOES UP OR DOWN
Tech Comments EXCESS PLAY NOISE IN LF REGULATOR, VERIFIED CONCERN LAST VISIT, REPLACED REGULATOR, VERIFIED REPAIR.
Customer Comments BANG NOISE FROM FRONT END
Tech Comments REPLACED LEFT FRONT STABILIZER LINK
Customer Comments C S THE VEH. IS RUNNING ROUGH AND THE EXHAUST WAS SMOKING, LACK OF POWER
Tech Comments EEC TEST REPLACE EXHAUST VALVE AS PER TSB 061906#1401000020976000020493000000000000041469
Customer Comments ENGINE LIGHT ON
Tech Comments VERIFIED CONCERN ENGINE LITE STAYS ON WHEN RUNNING. VISUAL CHECKS OK.EEC TEST DTC S P0401,P0404,P1335. CHECKED OASIS PERFORMED TSB 06 19 6: EGR SYSTEM PERF.TEST FAILS,CLEANED VALVE,RETEST FAIL.REPLACED EGR VALVE(O6 19 6C) R&I INTAKE MANIFOLD,CLEANED ALL PASSAGES,RE ASSEMBLED. RETEST EGR PERFORMANCE PASS,RETEST EEC PASS,PERFORMED TURBO LEARN OK.
Customer Comments HOWLING NOISE ON ACCEL AND CHECK ENGINE LIGHT CAME ON. CHECK GUAGES LIGHT CAME ON, TOW HAUL LIGHT CAME ON. TRANS TEMP DROPS TO ZERO WHEN THIS HAPPENS
Tech Comments PERFORMED A SELF TEST CODES PO404 P0401 P0488 PO528 P0700 P0 710 PO713 P1780. REPROGRAMED FICM PCM TCM REPLACE THE EGR VALVE , REPLACED COOLING FAN CLUTCH ROAD TESED AND RETESTED OK
Customer Comments HIGH PITCHED WHINE ON ACCEL AS IT SHIFTS FROM 1ST TO SECOND. DOES NOT DO IT ALL THE TIME
Tech Comments TESTED SYSTEM CODE P0299 REMOVED TURBO AND REPLACEED CHRA ASSEMBLY REPROGAMED PCM, TCM AND FICM
Customer Comments CLICKING NOISE FROM FRONT ON TURNS. AND BOTH HUBS WILL NOT UNLOCK
Tech Comments REPLACE BOTH FRONT LOCKING HUB.
Customer Comments FAN CLUTCH REPLACED ON RO 279685 ON 09 02 09 AT 77330 MILES
Tech Comments SELF TEST HAD CODES P0480 P0528 HAD TO REPLACE THE FAN CLUTC H CLEARED CODES.
Customer Comments C S HAS TO HOLD STEERING WHEEL TO PREVENT IT FROM GOING TO THE LEFT DOES NOT THINK IT IS ALIGNMENT ISSUE
Tech Comments
PERFROMED STEERING DIAG. FOUND LEFT UPPER, LOWER BJ SIEZED. REPLACED. ROAD TEST, FOUND STEERING BOX BINDING. REPLACED. ROAD TEST. CUST CONCERN RESOLVED.
Customer Comments FRT DRIVESHAFT U JOINT WORN
Tech Comments REPLACED FRONT DRIVESHAFT. CARDAN JOINT NOT SERVICEABLE.
Customer Comments C S WITH 4WD ON RATTLING METAL ON METAL NOISE DIAG AND REPORT.
Tech Comments MT TIME TO REPLACE JOINT REPLACED PASSENGER SIDE FRT AXLE U JOINT.
Customer Comments PINION SEAL REPLACE
Tech Comments REPLACED REAR PINION SEAL
Customer Comments REPLACE OIL PAN
Tech Comments ADDED DYE TO OIL AND PINPOINTED TO LEAKING OIL PAN. REPLACED OIL PAN AND GASKET. HAD TO EXTRACT 3 BROKEN STRIPPED OIL PAN BOLTS
Customer Comments CUST STATES THAT THE FRONT WHEEL BEARINGS A MAIKEING NOISE
Tech Comments REPLACED LF WHEEL BEARING
Customer Comments FRONT END FEELS LOOSE
Tech Comments REPLACED ALL 4 UPPER AND LOWER BALL JOINTS, EXCLUDER SEALS, AND HUB SEALS. BALL JOINT PLAY, UPPERS 1.0 1.1MM LOWERS 1.2 1.4MM
